2005 LT-40D SH
Started by Amax, June 04, 2013, 11:52:09 AM
Amax
Hello everyone,
It has been quite a while since I've posted.
Anyway, finally I have the opportunity to purchase  ;D an LT-40 Diesel Super Hydraulic.  It's a 2005 model.
I'm hoping to get a demonstration soon.  Was looking for some guidance on what you guys thought this might be worth assuming fair to good condition. The guy wants me to make the first offer... The mill has about 1MBF on it and I'd say about a 75 - 25 split soft wood to hardwood has been milled.
Al∏
A man sooner or later discovers that he is the master-gardener of his soul, the director of his life.
James Allen
Every man dies. Not every man really lives.
William Wallace
drobertson
Not sure what to say, I paid over 30k for mine new at the end of 04' 51hp cat, super, less than 3k hours less than 1million feet, would not sell, (never say never), for less than 25K,  take the demo, give it a going over, don't act too excited, there are more to look at. Might consider having a wmz tech give you some insight, without seeing it I would be scared to suggest any number,  I will say this, it took about 1000 hrs to work out some of the bugs in mine, so it is very possible this machine is ready to rock, the very reason I wish not to part with mine.  on the other hand, it could have hidden issues that takes a good day of sawing to show face,  hope it all goes well for you,  give wmz a call, 800-553-0182 go through the menu and pick sales,  david
Chuck White
Call Wood-Mizer and ask them if they can provide you with the Wood-Mizer Orange-Book price on the mill.
Bibbyman
Even the most experienced among us would need more info. ElectricAl recently went through an LT40 Super that was a rolling wreck.  The one you're looking at could have been well maintained and ready for service.
Sawing since '94
Nomad
     It's 8 years old and has seen minimal service.  How many hours on it?  How long has it set since it was last used?  Outside or under cover?  How about the maintenance on it?  Some things need to be done whether it's had hours put on it or not.
Quote from: Bibbyman on June 04, 2013, 01:22:03 PM
     Or not.  The advise to call WoodMizer is good advice.  They can tell you what it used to be.  It's gonna be up to you to figure out what it is now.
     Personally, I'd take a real hard look at it and hopefully run it.  See if it's been polished up like a used car.  Look at the rails, masts, and chains to see how much rust or pitting there is.  Check the engine maintenance.  Check the hydraulics for water, leaks and hose condition.  Will all the fittings take grease?
     8 years old.  Is it the original battery?  How about the engine coolant?  Does he have any maintenance records?  Has it been moved often?  Sitting in one place that long will raise Cain with tires and wheel bearings.  Any critters living in it?  They can do a number on wiring.
Give it a real critical look!  Don't get starry-eyed.  Then call WoodMizer back and talk it over with somebody.  You should be able to come up with a reasonable offer.
     Hopefully it's in great shape!  But be careful...
WoodMizer LT50HDD51-WR
Lucas DSM23-19
CalebL
When I found my mill (2005 LT40 HDD34 with debarker and setworks) it was relatively close to a woodmizer location.  I had the previous owner drop it off and I paid to have Woodmizer do a gold service ($370 at the time) on it BEFORE buying it.  That way they could tell me the condition of the mill before paying for it which helped me determine how much to pay for it.
I realize that is not going to be possible for most but it helped me tremendously in making the decision to buy it.  My mill had around 400 hours on it and I gave about $17k for it.
2005 LT40 HDD34
2000 Cat 226 Skid Loader
customsawyer
Go and look at it, get the serial number then give WM a call. Give them the serial number and they will be able to tell you what all they have helped to fix.
www.thecustomsawyer.com
I would use the above research for your benefit and for bargaining power.  My opinion is that he is on a fishing trip wanting you to make an offer.  He knows what he wants, but is trying to up the price with your offer.  Personally, I will not make an offer but I may "low ball" him which will flush him out and he will immediately squeal and reveal his asking price.
How many hours are on the sawmill.  One thousand (M)bf is not much use in 7-8 years.  I am assuming that you know that Roman numerals are used for lumber measurement thus M=1,000.
Amax, if it has only sawn 1000 board feet, that is not enough. If it sat outside that whole time without moving much there could be issues there. I would find out how many hours it has, that is a better indicator of usage.
Amax
Thanks for all the replies.  Plenty to help my research before making a final decision and once I get to see it and run it I will certainly call Woodmizer.  I should have the opportunity to see the mill in action as well as operate it in a few weeks.
My rookie error on how much it has been used.  :laugh: It has cut about a million BF.  Not sure how I'd write M with a line above it!
Cheers
James Allen
William Wallace
That makes it 1MMBF.
Bibbyman
http://www.youtube.com/watch?v=HFlAeUGjiYk&feature=youtube_gdata_player
Here is one of four videos ElectricAl made of an LT40 Super that had been abused to death.  From watching this series you can gain some experience as to what to look for.
Up,  sawing and in use is a good sign.
Sawing since '94
Which is what WDH said in the above post.  I Googled Roman Numeral Million, and not million bf.   :-[
I learned my bf lesson for today.   smiley_thumbsup
1 million feet is a lot of sawing, I would it expect it to have at least 4000 hours on it. That's not enough to wear it out by any means, but the number of hours gives you a idea of what components may need extra scrutiny. I'd rather buy one that had a few hours that is well maintained versus one that has low hours but has seen neglect (like the one I bought). I've spent a lot of hours getting the bugs worked out of mine, I still haven't got all of them.
Bibbyman
It's not easy to equate hours to board feet due to a many variables;  size, type and quality of logs, how the sawyer opperated,  if they used an edger or edged on the mill, etc.
Our 2002 LT40 Super has a few hundred hours less than 6000 hours.  We've probably sawn a couple of million board feet on it.  2012 was a slow year for us and I calculated we sawed nearly 200, 000 bf - 65,000 for one customer alone.  We sawed about 1, 800 bf today before thunderstorm came up.  The old battered,  edge worn mill saws as good as it did when new. Would it be worth the same as an identical mill with say 500 hours. Well,  could be if that mill had been neglected and abused.
Sawing since '94
drobertson
bibby, ten four on the hours, this does not reveal much, except that the key was on,  one main reason while idling I shut mine down, plus, I kinda like quite ;D   One must see what they are buying, and know what is expected from the product before they do so,  david
I totally agree with you guys, the condition of the mill is the bottom line. But the number of board feet sawn is really no better of an indicator of usage, because of the variables Bibby listed. Plus, the hours are the only thing metered, and you can bet the engine was running for most of the metered hours.
ElectricAl
 guess I won't be selling a Used Mill to Nomad any time soon.
He'll look right past my Spit Shine and see the pits in the parts.
Some guys are just too nit picky !
Linda and I custom saw NHLA Grade Lumber, do retail sales, and provide Kiln Services full time.
fishpimp
Quote from: drobertson on June 05, 2013, 08:55:09 PMt
I kill mine quite often too... I'd rather smoke a blade as waste 2$ in fuel ! Lol jk
Off road Liquid diesel gold is 2.50$ round here
GAB
Amax:
When you call W-M (and I hope you do) I suggest that you ask them if that mill has been reported stolen and to whom they sold it to originally.  That could give you some important history.  Gerald
GDinMaine
[/quote]
I would love to pay that for off road diesel.  It is around $3.50 here.
As for the mill.  Make the owner run it.  If you know how you should run it as well.  Try to have someone's number with you whom you can call and describe the mill.  WM keeps all the maintenance records, and can tell you what - if anything - has been done on the mill by any of the service centers or the mobile service guys.  They can also tell you what the previous owner bought from them.  If you ask for the guy's name and have the mill's serial number they couls probably look it up.
It's the going that counts not the distance!
WM LT-40HD-D42
rmack
I paid $133.9/liter to fuel up yesterday, that's $5.06/U.S. gallon.
the foundation for a successful life is being able to recognize what to least expect the most... (anonymous)
Welder Bob
2012 LT40HDSD35 Yanmar Diesel Triple
1972 Patrick AR-5
Massey Ferguson GC2410TLB Diesel Triple
Belsaw Boat Anchor
Amax
Well finally got to make some sawdust today  8) 8) 8) which helps a lot to make my mind up about this mill.
Just cut some spruce and pine for now.  I'm going to see it cut some of our maple and then quarter sawing some of our white oak and red spruce tone wood next week.  The tone wood we grade and use for guitar tops.
Can't wait to saw some more and hopefully make an offer on this machine.  Here's some pics I managed to take before my phone battery died.
From what I can tell the mill looks in great condition for 2005 and it has had a number of upgrades.  It's the 47HP diesel, has the new Accuset2 Setworks and the De-barker.  None of the components appeared to malfunction or seemed damaged.   All the key stops, clamps and hydraulics appeared straight and in excellent working order.  I saw the process from setup and leveling right through the process and finally got to "play".  Have to say the Accuset2 is very cool and helps simplify things once you get used to it.
In addition to the mill I'd get the Re-saw attachment, the blade tooth setting equipment and I believe the pro series blade sharpener along with a few Cant hooks and a bunch of spares etc.
(memo to self... charge your ruddy phone) ::)
James Allen
William Wallace
Dave Shepard
Did it have the 51 CAT, or did they upgrade from a gas engine? Looks clean.
Looks good.  I am seeing a toggle switch that has been added to the hydraulic pump housing??
Nomad
     Looks really good!  I'm curious about that toggle switch too.
Lucas DSM23-19
Amax
Quote from: Magicman on June 16, 2013, 09:13:38 PM
He did tell me... I've forgotten.  Too much to see and learn first time through.  It was a bit of information overload.  Good news is I get to play with it again tomorrow as we're cutting the Tonewood (Red Spruce).
James Allen
William Wallace
Nomad
Quote from: Amax on June 17, 2013, 05:18:30 PM
     Okay.  Well, fire up the mill (without a log on it!)  Close your eyes, stick your fingers in your ears, and flip the switch. :D  If the mill blows up, my real address is in Tahiti.
Lucas DSM23-19
scully
I would look at the set works ,I assume it has the older version does it work with no glitches ? Witch motor does it have ? If it is a Cat hopefully it has been maintained properly . have the mast rollers ever been replaced ? There is a schedual on those ! If you call WM ask what updates they had for this mill . Pull the breather ellament and see if it is packed with sawdust if so I would wonder how well maintinance was done . No doubt this has all the potential to be a great mill but establish a good estement of what it will cost to bring it back to 100% ! I would plan on a minimum of 1000$ I know this from my own  experiance and I got very lucky ! If you know your way around machine repair you can save a bunch by doing allot yourself . My 01 super is worth 26,000 plus acording to what I have seen ,and thats after a total refurb and service . I would base most of my evaluation on the engine ,thats just me ,I hope this helps .
I bleed orange  .
I have added a couple of switches on mine.
My all time favorite and most used is the "Fast Forward".  LINK  I never have to touch the potentiometer to zip to the back of the sawmill for a measurement, etc.
Bibbyman
Has it been repainted?  Looks like parts are orange that are black on our mill. I note pins that are plated on our mill look painted.
Sawing since '94
Amax
Quote from: Bibbyman on June 17, 2013, 10:36:03 PM
Yes, some repainting has been done.
James Allen
William Wallace
Bibbyman
Quote from: Amax on June 18, 2013, 11:25:24 AM
I don't know if it changes the value, just something that looked different.
Sawing since '94
I thought it looked like it had been painted, too. That doesn't mean much, it's what's underneath that counts. But I'm always skeptical of the "Rustoleum rebuilds".
Amax
Quote from: barbender on June 18, 2013, 08:20:22 PM
Used the mill again today and will run it again Thursday.  It's in great shape and has been maintained well.  A number of upgrades and repairs were conducted last winter.  Since that was happening the guy brought the mill in to his shop and basically blasted and repainted much of the frame etc.
I'm still not sure how age alone relates to the $$ value and I'll certainly call WM to confirm the maintenance claims and try to establish fair value before my final decision.
Certainly this mill seems in great condition and has been looked after and maintained.  It has 2300 hours on it which, if you assume 2080 hrs available per year based on 5 x 8 hour days per week, equates to running it for about a year in total since 2005.  Or to look at it another way only about 330 hours per year.   That does not seem very high.  I know the guy does not run it through the winter so mostly those hours have been accrued March to October.
I'm still not feeling comfortable about the $30K asking price even with all the extras, upgrades and recent maintenance.  Then again it runs great, looks good and gets me in the game.
A couple more questions...
For you guys in cold winter climates... How many of you run in the winter?  For those who don't why not?  For those who do what equipment issues do you commonly experience compared to summer running?
James Allen
William Wallace
Amax
This question is aimed at those using their mills mobile... What are you guys spending on annual maintenance and what hours is this based on?
What are the most common issues you've come to know about?
James Allen
William Wallace
pnyberg
Quote from: Amax on June 18, 2013, 08:55:46 PM
I bought my mill in the fall of 2009.  It had been used as a demo unit, and it had 6 hours on it.  Right now, it has about 1,190 hours on it.  In the time that I've owned it, I've had just under $4,000 in expenses that I've put on the books as 'Sawmill Maintenance'.  This does not include blade expenses.  $560 of that is two visits from Bob, the Wood-Mizer remote service guy.  That's just travel and labor charges; no parts.  The rest is pretty much all parts, but there's a lot of parts that are in inventory rather than on the mill.  For example, I've got replacements for both drum switches, a solinoid, and every belt on the mill on hand.  All these things will go bad eventually.  So, at a guess I'd say that I've spent around $3000 to replace parts on the mill.
If you have a mill that's in constant use then the most constant issue is maintenance.  It's just part of your life.  Other than that, stuff just breaks when it wants to.  Sometimes you might get a clue that trouble is coming, in which case a good mobile sawyer would pay attention and take appropriate action.  Sometimes you might forget to put an outrigger up all the way, and snap that sucker right off, but that would never happen to a good sawyer.
I am of the opinion that after a few hundred hours a well maintained sawmill reaches a kind of 'steady state' in which there's always something that needs attention or will fail soon, but if you're keeping up with things, the overall condition of the mill does not degenerate over time.
Hope this make sense, and good luck.
--Peter
No longer milling
customsawyer
I have a toggle switch on my mill in the same place as that one. It is used for my log deck. The switch allows you to use the mill hyd. to operate the chain on the log deck then if you flip the switch the same hyd. lever will operate the log loader.
WoodenHead
Quote from: Amax on June 18, 2013, 08:48:40 PM
A few things in response:
a.  The number of hours on the mill will depend a bit on whether the person works alone or has a crew.  Running a mill by myself, the hours don't climb too fast.  330 hours per year is definitely more than week-end warrior use.  Even with a crew and regular use, I think you would do very well to put 1500 hours per year on a mill.
b.  I wouldn't be comfortable with the $30k asking price either.  There have been low hour (500 to 1500hrs) LT40D SH for $23.5k to $25k, but you have to be patient and willing to potentially travel long distances to find something like that.  But if you are anxious to go and/or you are comfortable with the machine's history then it might be worth it for you.  Only you can determine that.   ;)
c.  Winter can be hard on diesels, particularly in terms of starting.  I sawed through the winter with an LT28 diesel.  At -16 C (3 F) it just didn't want to go and neither did I.   :D  Lubricants are that much stiffer when cold.  The electric motors have to work harder for head movement.  Winter sawing can be done, but I'm going to try to avoid it this winter if I can.
