Pressure Washer
Started by Jeff, April 24, 2004, 12:24:35 PM
Fla._Deadheader
AND, it won't vibarate off the roof  ;D ;D ;D ;D
shopteacher
Gee, for the tight in the pocketbook person a scrub brush on a long handle would do.  Need more power push harder, need more pressure put Wildflower behind you with a big stick. :D :D
 Jeff: Need more pressure!
Wildflower: WAP, WAP pressures on.
Patty
Now there is a mental picture!  :D :D :D
Women are Angels.
And when someone breaks our wings....
We simply continue to fly ........
on a broomstick.....
We are flexible like that.
One guy with the paddle and the other with the brush hmmm  :D ;D
pappy
Tome,
I've seen the results after using "Wood ReNew tm" from
http://www.permachink.com/ and only one word describes it AMAZING.  What they claim is the truth!!!
QuoteWood ReNew is a biodegradable, non-toxic, percarbonate-based wood cleaner that brightens grayed and weathered wood.
Wet down the surface you intend to treat, then mix the concentrate with water, stir and spray on. Wood ReNew will begin to fizz and foam immediately, as it eats away dirt and grime. In about ten minutes, scrub the wood with a medium-bristle brush and rinse off.
To rinse my friend used his pressure washer and his log home came out looking almost brand new.   8)
When you get to their page click on the "Restoration" link you'll get a lot more info.
pappy
ADfields
My cheep little electric is 4gpm @ 3000psi and works fine for me, well great. ;)   I would have never believed it till a Friend came over with his and cleaned my deck.  It worked near as good as the $3000 steam cleaner I used to have at the tow company did with the burner turned off, that was 6 gpm @ 5000psi.
Andy
ElectricAl
Linda and I custom saw NHLA Grade Lumber, do retail sales, and provide Kiln Services full time.
ElectricAl
You do your washin inside? Looks like a nice pump. Is your water tank mounted on brackets on the wall? That's the way it was setup at my father's packing shed, only with taps and a shutoff valve on the spud washer.
Nice pic of the shop ;)
GAV64
SOMEONE SAID IN AN EARLIER POST THAT GPM IS JUST AS IMPORTANT AS PSI. THIS IS HOW IT WAS EXPLAINED TO ME. "IF YOUR DOG DOES HIS BUSINESS ON YOUR DECK ARE YOU GOING TO USE  A CUP OF WATER OR A 5 GALLON PAIL, IF YOU ARE SMART YOU ARE GOING TO USE THE 5 GALLON PAIL AND BE DONE WITH IT" 4GPM AND 2500 PSI IS WHAT I HAVE, IT IS AN OLDER BELT DRIVEN MODEL, SIMPSON WITH A 11HP BRIGGS. YOU CAN GET BY WITH 1/2 THE HP DUR TO DIRECT DRIVEN PUMPS AND THE $ HAS COME WAY DOWN. HOLD OFF, SAVE A LITTLE, SPEND A LITTLE MORE AND BUY IT ONCE. I SOMEHOW HAVE TO KEEP LEARNING THAT LESSON. GLENN.
ElectricAl
SwampDonkey,
We have concrete in front of the sawshop. Most of the washing is done out there. We will touch up spots inside, but really limit the water inside.
We have a well for water. The right line is a 3/4" cold supply and the left is 1/2" softened hot water for Linda's car and the JD skidsteer ;D
I drive it and Linda washes it ;)
Haytrader
Al,
She does the washin and you build the goat gates.
Sounds fair to me.
Oh, after seein the skidsteer..........
What did the plow say to the tractor?
Haytrader
Bigdogpc
My old pressure washer (about 10 yo) has an 11hp Briggs, too small tires, clunky and awkward to drag around with hoses attached and in general is a pain in the backside.  Starts 3rd pull everytime, cleans anything I have wanted to clean, cost too much when I bought it and I've been happy with it ever since.  IF ya don't need that much cleaning power, save yurself a lot of money and backache, go 'lectric.
ElectricAl
Haytrader,
I don't remember what the plow said to the tractor. :-/
1986 is the last time I pulled a plow ::)
Nice shop, and a woman willin to help out.
Couldn't ask for more.   :)
Haytrader
Al,
The plow said...........
Pull me closer John Deere.
Haytrader
Patty
Women are Angels.
ElectricAl
The little yeller feller is a kickin up his heals now ;)
