215 MPH wind...at your service
Started by GDinMaine, May 08, 2013, 06:12:42 AM
GDinMaine
Most of the time I can only run the mill for about 3-4 hours before I have to go to work.  Getting the mill ready only takes 10-15 minutes, but when I'm done I like to clean it properly.  It has been a bit of a chore to go around with a brush and get the sawdust cleaned off.  It takes about 30 minutes to clean, pack up and cover the mill.
I had this bright idea that I could do the longest chore far faster if I used a leaf blower to clean the sawdust from the mill.  It works fast and does a far better job then a brush.  I can even blow out the radiator, although a compressor does a better job at that. Anyone else does this or can you think of any harmful effect?  The only drawback is the noise of the leaf blower interrupting the silence I created by shutting the mill off.
Ohhh... that last thought is a bit on the philosophical side, but true.
It's the going that counts not the distance!
WM LT-40HD-D42
That's how I clean mine off.  It will also move the sawdust from your walking path.
A member uses one to help burn a brush pile.
alecs
When I used to work in machine shops, it was always frowned upon to use compressed air or a brush that had been in contact with the shop floor to clean up the mill or lathe after work.  The idea was not to force dust, dirt, and chips into places where it would later cause a problem, like the machine ways, lead screws, etc.  So to the extent you might be unknowingly blowing sand or dirt into places where there are bearings, tracks, hydraulic cylinders, electronics, or other susceptible parts, this might cause a problem.  On the other hand, I'm sure your sawmill is designed for more punishment than a Bridgeport mill in that regard.
danreed76
Quote from: GDinMaine on May 08, 2013, 06:12:42 AM
Interesting concept developinging here... using my sawdust blower to move leaves...
Woodmizer LT40 Hydraulic with resaw attachment |  Kubota MX5200  | (late)1947 8N that I can't seem to let go.
Nomad
     A leaf blower is a staple on my truck, just like peaveys and a chain saw.  I used to just do the 60 MPH cleaning, until a nice young lady from the DOT stopped me and said if she caught me going down the road like that again...  dadgum you, Charlie!
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Chuck White
I use my leaf blower (Stihl) every time I get done sawing, and sometimes just a quick blow-over at various times through the day.
Besides the fact that the blower is faster than a brush, it can remove sawdust and debris from areas a brush can't get to.
I like to blow through the alternator once in a while, as well as the main air intake for the engine!
Also good assurance that you don't have sawdust build-up that could later cause a fire or interfere with the operation of the mill!
petefrom bearswamp
Been using this method since 2000, works good.
My mill is stationary and it is cleaned every day
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
JohnM
Gabor, I saw this title and thought it was going to be about your trip to Mt. Washington this winter. ;D  And I do believe Ray just helped us with next years Winter Solstice bonfire!
Quote from: thecfarm on May 08, 2013, 07:08:15 AM
8)
Every year my wife and I have friends over for a Solstice gathering (read: a reason for a potluck and a big fire) and every year it's a struggle to get the fire going.  Three days of rain before this past one equaled 2 gal of old motor oil to get it going.  So bring the blower next year, GD!  (actually I seem to recall you mentioning it that night...?)
[thread highjack completed]
I'm curious about possible damage as well?  ie putting dust where it doesn't belong
JM
Lucas 830 w/ slabber; Kubota L3710; Wallenstein logging winch; Split-fire splitter; Stihl 036; Jonsered 2150
dboyt
Every mill I've ever worked around is designed for a dusty environment.  The only problems I can imagine are around any electronics, if the fuel cap is loose (or off), or if the engine's air filter isn't properly installed.
mesquite buckeye
I also use a leaf blower to clean dirt off logs before cutting. Note that we rarely have mud on logs, usually it's ;D in the form of packed, dry dirt. Also blow off mill between logs. One precaution, though. Turn off the engine before stirring up all that dirt, or it goes straight into your air filter.
GDinMaine
So much for my original idea.  :D
  The thing is that I don't actually own said leaf blower. I had to borrow it from a fellow at work to see if it will do the trick.  I will be on the lookout for one tho.
John,  The Mt. Washington trip only had 75MPH wind with -39F windchill.
I promise to bring leafblower for the bonfire this fall.
WM LT-40HD-D42
AdamT
I prefer the hooking up and heading down the road method of cleaning my mill when on portable job. It only takes about 1/2 mile and she's no longer covered in sawdust.
I've had many customers offer to blow off my mill with their blower, but I always tell them no thanks. I'll make plenty of wind on the way home!
2017 Wood-Mizer LT40HDD35-RA
2011 Wood-Mizer LT40 HD
It's better to have it and not need it then it is to need it and not have it
Nomad
Quote from: AdamT on May 08, 2013, 05:39:14 PM
Quote from: nomad on May 08, 2013, 08:29:18 AM
     Be careful with that.  The fine she quoted me was not something I'd want to have to pay.  On your head be it.
Lucas DSM23-19
Peter Drouin
this is what i use
120 psi will cleen things
works for me :)
A&P saw Mill LLC.
License NH softwood grader.
A fella at our tractor pulls duct taped a leaf blower to the hood of his old case,he calls it his polish turbo.He said it helps. Frank C.
kelLOGg
The only reason I bought a leaf blower was to clear sawdust from the mill.  Now, I'm thinking maybe gutters, too. ;)
Bob
The Stihl blower is my friend.   ;D
Jay C. White Cloud
I second Magicman!  I have been using one of these for 20 years.  I think it is one of my "go to tools."   You can "air broom" with it, kindle fires, or use it as a power draft for wood pottery kilns,  many, many, uses besides blowing leaves.
Quote from: Jay C. White Cloud on May 09, 2013, 10:12:51 PMmany, many, uses besides blowing leaves.
:o  Ya mean that is will also blow leaves  ???  :D
Nomad
Quote from: Magicman on May 09, 2013, 10:20:35 PM
     Huh.  I've never tried it for that!
Lucas DSM23-19
Chuck White
I use mine to blow out the leaves and dust that swirl into the garage.
Remove both vehicles and wear a mask when doing this job!  ;)
GDinMaine
Now that I have to buy one of these things, do I really have to go for the high $$$ item or a Ryoby, Echo or similar brand will do fine. The one I tried is a $200+ item and I plan on spending far less.   Should I get the one that blows the highest speed "wind" or the lesser one ??? ???
Here is my rant about cheap stuff:
I base my opinion on a cheap lawnmower that I bought close to 10 years ago and it just refuses to give in.  For one season I mowed my 1.5-2 acre yard with it (before getting tractor) at 6 hours/session and it sees regular use on the more scene scale to this day.  It is starting to smoke a little on start-up, but still works very well.
rant finished
WM LT-40HD-D42
GDinMaine
Quote from: Peter Drouin on May 08, 2013, 08:35:14 PM
this is what i use
works for me :)
Peter,  I got the idea for blowing sawdust off the mill from your original post last year. I lack the far more macho engine driven compressor, but will spring for a wind machine.   After all I will have to take it to John's bonfire in the Fall.
WM LT-40HD-D42
GD,those old lawnmowers seem to run forever I've never bought one ,find them at the dump and put a new plug in them,got 4 or 5 in stock.The way you tell if their worn out is they take a long time to get back to speed if you overload them,a newer tight mower will snap back quickly. Also blue smoke is a fair indicator. Frank C.
