time between cutting and milling
Started by penfrydd, April 22, 2013, 06:51:32 AM
penfrydd
Only have done firewood in the past.  Doing a good sized cut of hemlock in the coming year.  Can I cut them throughout the summer and haul out in late fall, or, as I understand with hardwoods, should they be at the mill within a week or two of cutting?
penfrydd
It is always best to saw them as soon as possible after they are felled.
justallan1
Welcome to the forum Penfrydd.
I'm rather new at this, but I've sawn a few old dead logs and quite a few right after they were fell and there is a considerable difference.
I can walk right through the ones that I fell, where it's a bit slower going on the ones that have been on the groung awhile.
I don't know, but would think that if it's sawing slower it's dulling blades faster. Someone with more experience can tell you if that is correct or not.
Allan
Quote from: penfrydd on April 22, 2013, 06:51:32 AM
penfrydd
pemfrydd,welcome to the forum. As I quoted,do you mean a mill that you would sell too,your mill,or are you bringing in a portable mill? I have cut hemlock to sell at a mill and I have cut some to saw at my place.
CCC4
If you are selling them by weight you better haul them as quick as possible. If you plan on cutting them and sawing them for yourself...you would be better to go ahead and saw them soon as possible. If fell and let lay all summer they could check. I know nothing of hemlock though.
mesquite buckeye
Lots of conifers bluestain when cut in summer. Depends upon whether you like it or not. You shouldn't get any real degrade like splitting for many months. :)
I don't think hemlock gets the blue stain. In fact I'm pretty sure it don't. I cut some for my mill early summer and than went this winter to clean the tops up. They was nice and bright inside. Now I know the white pine I have will stain. The bugs will go right at the pine.
ahlkey
I actually cut a lot of Hemlock last year and waited over six months before I sawed them and they were in great shape.  I did seal the ends with anchorseal and make sure they were not in direct sunlight so that might of helped a lot.
FFLM
I have sawn hemlock that had been felled for close to a year, looked just as good as if I had felled it that day.
208 Jack, 372's and F450 Stroker
