New member
Started by anchorhd, April 02, 2013, 10:23:38 PM
anchorhd
Hi,
Iwas lurking here for awhile decided to logn and post. I am in the process of putting a mx34 togeather.
I am in ne nystate on a 56 acre tree farm.
I can't wait!
davidlarson
Welcome to the Forestry Forum.  There are many smart and experienced people to help you with issues related to your tree farm.
David L.
Jay C. White Cloud
Welcome, Achorhd...you will love milling, I sure.
dgdrls
Welcome anchorhd,  great group of folks here.
Lots of Norwood guys and NY sawyers on the Forum.
you'll have to post some  pics of your mill when its built,
Best DGDrls
rooster 58
     Welcome to the forum ;)
Chuck White
Welcome to the Forestry Forum, anchorhd.
Lots of good people here!
Seaman
Welcome, lots'a good folks here.
Lucas dedicated slabber
Woodmizer LT40HD
John Deere 5310 W/ FEL
Semper Fi
anchorhd,welcome to the forum. You will need a cantdog or peavey. Logrite is a sponsor on the left to help you out with that. Ever been around a sawmill before? What's the plan for the sawmill and lumber?
I have no idea where Hambug,NY is to you. But there is a Logging show there on May 3-4.
http://www.nefpexpo.net/Windex.htm
I go to the one in Bangor,Maine. At that show there are sawmills that are in use,small scale logging equipment,skidders,wood processors,chainsaws, big chippers,wood splitters,really anything to do with wood. Free to get in,regsiter on line and have a good time. You can spends all day there easy.
tgalbraith
 8)  Welcome to the forum. Good luck on your new venture. :snowball:
M Belsaw, 46" insert blade, Oliver 88 power  plant
justallan1
Welcome to the forum, Anchorhd.
If you can't find an answer for your questions here, there may not be an answer!
There's folks here with all kinds of experience and willing to help.
Allan
dboyt
Anchorhd, greetings from Missouri!  Welcome to the Forum from a fellow Tree Farmer & Norwood sawmill owner!  I've run the Norwood MX34 for nearly two years, now, and it is a tough little mill.  I even towed it to the National Tree Farm convention in Florida last summer to show it off.
Take your time putting it together, and just follow the instructions.  The only problem I had was when I tried to do something different from the instructions, then had to disassemble it and do it right.  Cant hook, chain saw, wedges to open up the cut when you have to back the blade out, axe for cutting out mud and rocks in the bark, and a few wrenches (including Allen wrenches to adjust the blade guides).  You'll need at least 10 bands, 20 is better.
Pay attention to blade tracking.  First thing I did when I started my mill was to throw the blade and put a kink in it.   Keep us posted on your progress.
clww
Welcome to the Forestry Forum. :)
Many Stihl Saws-16"-60"
18-Wheeler Driver
Gasawyer
Welcome to the forum Anchorhd!
Woodmizer LT-40hdd super hyd.,Lucas 618,Lucas 823dsm,Alaskian chainsaw mill 6',many chainsaws large and small,NH L555 skidsteer, Int. TD-9,JD500 backhoe, and International grapple truck.
dukndog
WM LT-15G25 w/PwrFeed, Mahindra 3510, Husky 385xp, Stihl MS261 and a wife who supports my hobby!!
swampbuggy
Welcome to the FF and to MX34 ownership. As you can tell these folks like pictures! Good luck with your build. Dan
If it was easy, everyone would be doing it!
mesquite buckeye
anchorhd
Thanks for the info.
I cut my 1st pine today. I need to cut the logs a little longer so both log dogs secure the log and the cant is not perfecty square. I will adjust it tomorrow.
ND rancher
Welcome to the forum! Now we need photos.  Keith
TimberKing B-20.  Have been bitten by the bug! Loving life !
dboyt
Congratulations.  I see much sawdust in your future!  It will take a while to get everythng dialed in perfectly, but if you pay attention, it all comes together.  One thing that helps is to put a carpenter's level on the flat side of the log when you make your second slabbing cut.  If the mill is level, it will tell you when the log is square to the blade.  I still do that from time to time to make sure it is still in adjustment.
 If you need to, you can shim it with a wedge to get it square
Also, keep an eye on the ceramic blade guides.  I had to adjust mine a few times before they were right.
francismilker
Welcome aboard!  There's lots of good information to glean here.  These guys (and gals) are a good bunch. 8)
"whatsoever thy hands finds to do; do it with thy might" Ecc. 9:10
WM LT-10supergo, MF-271 w/FEL, Honda 500 Foreman, Husq 550, Stihl 026, and lots of baling wire!
