sawing foam
Started by xlogger, March 20, 2013, 05:41:58 AM
xlogger
I have a local small factory that makes CNC tools that what me to cut up some big foam blocks today into smaller pieces.  Has anyone ever tried this before? I don't see why the mill should not be able to do it. I was thinking about putting a  bag over dust port to collect the dust so it would not get mix into my wood dust that I pill up for some reason, not sure what I'm saving it for now.
redbeard
I have a couple really fine tooth bi metal blades with hardly any set that never did work  for wood cutting. A guy I use to get some carbide blades from wanted me to try them. I have used them on plastic pipe. They would work great for cutting the foam. I would keep the blade speed slow your probably going to have to clean blade and wheels a few times.
Chuck White
I would also recommend some clean water lube to keep the blade cool.
If the blade heats up, the foam could melt and stick to the blade, then you'd have a real mess!
billporterfield
Why not look into a "hot wire foam cutting settup" remove blade and rig a cutting wire. just a thought.
http://www.demandproducts.com
bandmiller2
Logger,I'd stop by their plant and get some scrap pieces to try, you may have to change nothing from your regular procedure. Frank C.
wdncno
I recut some foam dock billets for a guy in the fall. No problems, a lot easier than wood.  If you're doing a lot, you're going to have to deal with the dust.
Brad_S.
I did some once, they 4x8 panels that needed to be cut down. I had to add some 1/2 sheets of plywood backers because the force of the blade pushing against the fairly thin (2") panels was causing them to bend and flap, in one case breaking the panel and in other cases not leaving a square cut. By sandwiching the foam in plywood, I added support and didn't leave clamp marks. I didn't cut the plywood, just used it to support the foam.
pineywoods
For the rigid stuff, scrounge up some nicrome wire, a defunct electric clothes drier is a good source. Stretch it across a wooden bow. Hook your battery charger to each end. Not much limit to the size you can cut. I've used this method to slice 2 inch thick sheets into 2 one inch sheets.
For  the soft upholstery foam, use the wife's electric carving knife..
Jay C. White Cloud
Hello Xlogger,
I mill reclaimed and factory second stress skin panels on a regular basis.  It works fine and is so fast that I have never had a blade heat up enough to burn the material.
Good luck,
jay
"To posses an open mind, is to hold a key to many doors, and the ability to created doors where there were none before."
"When it is all said and done, they will have said they did it themselves."-teams response under a good leader.
Quotecut up some big foam blocks
My first question would be what is this foam like?
And what size "blocks" are we discussing?
Foam like in a mattress is one thing, but high density foam like used in a watercooler or the sheet goods is another.
Or does "foam" identify what it is and I'm not in tune with what that might be??
taylorsmissbeehaven
I don't know what kinda foam your working either but had a buddy in the mountains built a machine to cut grooves in 4x8x 2" thick sheets of foam for some type of alternative building project. Took a couple of attempts but he got it. One attempt had a blade that got so hot it melted the pieces right back together!!! :D Anyhow sounds like a good project. If you have time I'd like to check it out,lend a hand if possible. Send me a PM if your interested I'm right around the corner from you. Brian
Opportunity is missed by most because it shows up wearing bib overalls and looks like work.
alecs
If it's foam for CNC tooling, it's probably something like RenShape, which is essentially like monolithic Bondo.  I've cut it using regular woodworking tools (router bits) and it's fine.  I don't think it would pose much trouble for a bandsaw.  The dust, however, will go everywhere, as others have said.
http://www.freemansupply.com/RenShape450MediumD.htm
From that website:  "RenShape 450 can be machined using standard woodworking tools and will not result in objectionable dust particles when planed, milled, sawed or drilled. It resists warping and can be easily painted and finished for appearance and prototype models. "
Not sure I agree about the dust, but the rest sounds consistent with my experience
sealark37
For polyurethane foam, use silicone spray to lube the blade.
xlogger
I cut it today and it did fine, no problem. Dust did go everywhere. He was pleased.
Great.
Would be nice to know just what it was.  ::)
and...... no pics, didn't happen.  ;D
Jemclimber
Hey Piney,
Will a digital battery charger work or does it have to be the old analog style? I've wanted to do this for other projects.
lt15
xlogger
Come to find out it was for blanks for demo on their machine to make. The foam was the hard type like you use in coolers. They had several large pieces but they only wanted one cut today it was about 30X30" and maybe 4 ft long. Sorry I'm bad on pictures.
Kcwoodbutcher
I've cut the urethane for a sign maker who did CNC work. It cut fine, no melting and the blade left what looked like woodgrain finish,
My job is to do everything nobody else felt like doing today
pineywoods
Quote from: Jemclimber on March 20, 2013, 04:56:24 PM
Hey Piney,
Don't matter. the idea is to heat the wire nearly red hot while keeping it stretched tight.
Jasperfield
I'm with billporterfield.
Remove (or don't use) the blade and use a "hot wire" powered by the mill (or otherwise) and cut the foam.
No dust, waste. fragments, etc. Just a clean, straight cut.
Jemclimber
Thanks Piney,
I'll put that up in the hard drive and hopefully be able to pull it down when I need it next.
lt15
