info needed backyard sawmills
Started by beaverdriver, March 19, 2013, 03:52:46 PM
beaverdriver
hi hope everyones having a good day does anybody have any info on the backyard sawmills from Vancouver Island
Chuck White
Sorry I can't give you any info, but I can welcome you to the Forestry Forum.
clww
Welcome to the Forestry Forum. :)
You're in the right place for information. Stand by.....
Many Stihl Saws-16"-60"
18-Wheeler Driver
beaverdriver,welcome to the forum. looking to buy one,or having some problems with it or....?
beaverdriver
Hi thank you for the welcome. I am looking to buy a mill just not sure which one. There are so many out there, twin blade, swing, band. Have time on a bell saw, and a Norwood. I'm going to change things around and start a portable mill business. So lots to put together. I've got the sawdust bug.
justallan1
Welcome to the forum, Beaverdriver.
redbeard
Welcome beaverdriver !  And neighbor! At least were not to far as the crow flies.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
customsawyer
www.thecustomsawyer.com
dgdrls
Welcome aboard Beaverdriver,
I found them on the web also,
No first hand experience with them
but maybe someone will chime in.
Care to share your background and how you found the FF?
best
DGDrls
dboyt
What size logs do you plan to be cutting?  Do you have a specific market in mind?  Going portable narrows things down a bit, since you will probably need to work without support equipment such as log loaders.  Consider the size of the mill and what you plan to move it with, and how easy it is to set up once you get it there.  If you will be working in residential areas, it will need to be small enough to work in tight places, and quiet enough that the neighbors won't complain.  I've used my Norwood right in driveways without even taking it off the truck, and towed it out into the woods with a tractor to get to a customer's pile of logs.  Let us know what you decide.  And welcome to the Forum!
haywire woodlot
My neighbour used to have one, the sawyer model, he used to call it "a real slick little number" The family sold it after he passed on.
Dave
JVK
Welcome to the forum. I had one for ten years. Just sold it. I considered it a big upgrade from the years of chainsaw milling. Made enough money with it to buy a new LT 50 recently. What do you want to know about this mill? I'm your man.
How about a website? I like looking at mills.
dgdrls
beaverdriver
Quote from: JVK on March 20, 2013, 12:27:46 PM
Hi jvk I was looking at the wm line on the Web they look pretty good how's the band maintenance
beaverdriver
Quote from: redbeard on March 20, 2013, 12:22:59 AM
hey red beard looks like we're both 155 clicks apart unfortunately most of its ocean hows tree Supply on the island
losttheplot
Hi Beaverdriver,
There is a Wood Mizer dealer in Errington, Vancouver Island.
Not sure if you know that already.
They had some mills in stock last time I was there.
I used to have them sharpen my bands, they do a good job.
LTP.
DON'T BELIEVE EVERYTHING YOU THINK !
beaverdriver
Hi lost the plot. didn't know about the wm dealer in Errington thanks I'll have to take a look.I'd sure like tho drive one
redbeard
Beaverdriver Lots of trees here logs always seem to find me. Going to get a few more if this wind keeps it up were getting 60+ mph gusts nice spring storm. Love Vancouver island still has a lot of remote & wild country left on it. Good luck with your mill venture.
JVK
Hi beaverdriver,
Maintenance is easy on this mill. Normal bearings, greasing and blade adjustments are simple. Having said that, I didn't know about WM ten years ago. I would look at the LT15. The price is about the same and resale could be easier.
I used my mill to cut 30' dock timbers (12" x 12" and bigger). One great thing about this mill is that you operate the sawhead from the non sawdust side. Good luck
Welcome to the Forestry Forum, beaverdriver.   :)
