End coating
Started by Lnewman, March 18, 2013, 11:07:20 PM
Lnewman
Can you delay end ceiling a log if it is below freezing outside?
Stihl 170, 210MS, 290MS, 441MS and Hudson bandsaw
GeneWengert-WoodDoc
Anchorseal comes with antifreeze, but a log end with ice (or mud) cannot be coated...you would be coating the ice and not the wood.
The hard coatings (tar and elastomeric coatings are soft) will often cause planer knife damage, so cut off 1/4".  That is a lot less than cutting off a 2" or longer end check.
The wax coating is sometimes sprayed on and that means wax is on more than the end.  So, be sure to get well over 130 F to remove all wax before using the lumber in the manufacturing plant.
tyb525
Mesquite, I was talking about trimming maybe 1/4", just enough to get rid of the wax. anchorseal is meant to prevent cracks due to drying out, but you still need to end trim at some point.
OneWithWood
I end coat the log so there is no need to end coat individual boards.  The end coating on the board gets trimmed off when I cut to rough length before jointing, planning and cutting to width.  Never had an issue with end coating fouling any blade or migrating out into the field of a board.
Turning blocks do present some issues but I would think a band saw could eliminate any coatings before turning.
One With Wood
I have not had any issues with the wax end coating either, and I have used a lot of anchorsealed lumber in the shop.  I do like you, too, Robert, and end coat the log, not the boards.  This confines the anchorseal to the end grain as any that gets on the log gets slabbed off.
Lnewman
Has anyone used latex paint or pruning sealer ?
Lotsa people try both, and eventually find Anchorseal. But you can try it and find out why, if'n you'd like.
Let us know how it works. ;)
And I don't mean that to sound flippant. Some don't like it because of how it doesn't stop  moisture vapor movement and others getting it to stick to wet ends.
Tee
Could I put Anchorseal in a garden sprayer and leave it there between uses? That seems like it would be convenient; pick it up shake it a little and go. Never used it so I have no idea if it would clog the nozzle or not.
mesquite buckeye
That works.  Ooops. Well, maybe not, I was thinking Timbore. Bet it clogs it up real good.
OneWithWood
Quote from: Tee on April 18, 2013, 09:09:47 AM
You would need to put a much larger nozzle on it and be sure to clean the nozzle after spraying.
One With Wood
Ruffneck
I've been using Bailie's end sealer. The other day I applied some
to the end of a freshly cut Ponderosa Pine. Once it dried, I could
see the sap flowing heavy. Will I need to reapply the sealer?
Should I wait for sap to stop flowing before application?
Thanks!
I wouldn't worry too much. Pine isn't usually end sealed anyway, and the stray sap probably helps to seal it as it oozes out and dries.
Compensation
Do you have to buy anchorseal from their website or have you seen it out and about?
D4D caterpillar, lt10 Woodmizer, 8x12 solar kiln, enough Stihl's to make my garages smell like their factory :) Ohh and built Ford tough baby!
Nomad
Quote from: Compensation on May 05, 2013, 12:40:29 AM
     WoodCrafters here carries Anchorseal.  I think there's at least one other place in town that has it too.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
shinnlinger
Ive used paint and anchor seal, the anchor seal didn't really do much for me as I still had significant checking in bowl blanks.  Maybe I did something wrong?
As to cutting off a bit on the end of boards, I usually sticker stack right off the mill, which means the ends have been chainsaw cut when they were still in log form.  As good as I am with a chainsaw :), Usually the first thing I have to do is square up the end of the board, which means I'm  cutting at least 1/4 inch off.   Cutting off the sealer on the end is kind of a moot point as I have to do it anyways.
Shinnlinger
Compensation
With the wax I use for now I have some urge to mix in either food coloring or dye of some sort so I could color code lumber for when it is stacked. Maybe in a second or third coat. I have only sold some mantles to people and always thought it would help some if they could look at a chart and dive right in to their stack. Maybe make them feel a little more at home or more willing to come back due to organization. Anyone done this?
Jay C. White Cloud
OneWithWood
I color coat for species and customer.  It helps a lot when unstacking the kiln charge and distributing to customers and bins.  A few of my steady customers have me mill and dry multiple species and they like the color id.  One end is coated by customer and the other by type of wood.
One With Wood
Al_Smith
I bought mine from some place in Ohio which was the cheapest at the time even with paying Ohio sales tax .Since then the price has escalated a tad bit .Actually all the stuff I have laying in logs now is tar sealed .Roof tar is actually less expensive ,messy though .
To get the original formulation (and better formulation), you have to call UC Coatings and order it.  You can only order the new "green" version on the website.
