WM LT-10 lift upgrade?
Started by francismilker, March 15, 2013, 10:47:36 AM
francismilker
Has anyone here added a manual handcrank lift to the LT-10 with good success?  If you have, can you add some pictures?  I've got an idea of how to do it but wondered about checking in to simply putting a lifting mechanism from a LT-15 model on my LT-10 if it's possible.
It's a great little mill and does what I need it to do.
"whatsoever thy hands finds to do; do it with thy might" Ecc. 9:10
WM LT-10supergo, MF-271 w/FEL, Honda 500 Foreman, Husq 550, Stihl 026, and lots of baling wire!
millwright
There's a guy near me who has one that he mounted a small 12volt winch to lift and lower the head. It seemed to work pretty good.
isawlogs
 re you talking about a head lift or a lift for logs...
   Marcel
Happycamper
I sincerely hope that wm is looking into the problem and fixes it soon.
                                  Jim
Wether you think you can or you can't you're right
francismilker
Quote from: isawlogs on March 15, 2013, 06:05:21 PM
I'm referring to a headlift.
francismilker
Quote from: millwright on March 15, 2013, 06:03:21 PM
Any chance of getting a picture?
millwright
Sorry, this old computer I have won't let me download any pics.
Sixacresand
I made this hand crank system for my LT10.  You can't tell much from the photogragh, but it uses a small cable attached to head and the other attacted to a 3/4" metal pipe which acts like a winch to raise the head.  The metal pipe goes through bored holes in two boards trimmed down to stick in the metal frame of the mill.  On the end of the metal pipe is a hand crank.  Of course, if the air assist lift cylinders on the mill are defective, the hand crank will work, but will be difficult.
francismilker
Thanks sixacresand!  I appreciate it. :)
