Bent backstop - LT40
Started by JustinW_NZ, March 12, 2013, 07:52:05 PM
JustinW_NZ
Ok, while sawing yesterday on a 6m long LARGE log we had to shuffle it down the mill slightly after getting it on the mill.
A gentle nudge with the tractor while the roller toe-boards were up looked like the trick...
until a knot in the wood caught and held the most forward (to operator end) of my LT-40 hydraulic backstop.
The customer and tractor operator did like to push hard with his JD tractor  :-\  :'(
Now the backstop is awfully bowed.
So I'm guessing some good heat and a straighten up should be the cure?
Or once stressed just give up and buy a new backstop?
Anyone else care to admit going down this path?
Cheers
Justin
Gear I run;
Dave Shepard
It is just mild steel, so straighten it if you can and realign. I don't allow anyone near my mill with heavy equipment, I can bend stuff all by myself. :D
drobertson
Sounds like a bummer, knots and nubs are a pain for sure, I once had a fellow try to help with the log deck, big cat, knocked the mill off the blocks, turned side ways,  just ugly, all while I was gone, saw it the next day,   Hope you get that rascal back straight soon enough, go slow,    david
My sawmill 's previous owner was setup at a commercial sawmill operation and sawing cants.  His logs were regularly loaded by the big grapple machines and both of the side supports were bent outward.
A rosebud and cheater pipe were needed to straighten both of them.
CalebL
Quote from: Magicman on March 12, 2013, 09:53:32 PM
Was it you or Bibby that made the manual backstops work like the hydraulic ones?  I seem to remember someone saying Woodmizer took a look at it and made a kit to retrofit their mills.  I have been searching for it on Woodmizer's site and on here but can't find it.  I would like to add that to my mill.
2005 LT40 HDD34
2000 Cat 226 Skid Loader
isawlogs
 It bent cold, it will bend back cold, take it off , it aint a big job put it under a press and straighten it up, theres no need to heat it, unless you don't want to take it off the mill. Either way you will need to check the square after you're done.
   Marcel
moandrich
I always say if it is already broke I can't break it, I would try to straighten.
woodmizer lt 40HD  2007
Kubota RTVX1100 2019
Kubota L3940   2009
CalebL, that was Bibbyman.  He actually invented the 4 powered side supports.
haywire woodlot
I'm surprised it bent, I got a little over enthusiastic loading a log with the hoe and tweaked the 2nd log stop once. It broke the weld where the pivot for the logstop attaches to the mono-tube. It was a lot easier to weld that back together than to heat and beat the stop back into square.
Dave
Brucer
Bibbyman "invented" the "four hydraulic side stops" and it is now available from Wood-Mizer as an option on new mills, or as a retrofit package.
My 2006 mill had that option already installed.
My friend John just showed me his version and as soon as I can get the picture uploaded I'll post it here. It's a heck of a lot simpler :).
Bruce    LT40HDG28 bandsaw
petefrom bearswamp
I agree with Dave Shepard, any breakage on my mill, saw cuts in bad places in steel etc,  is done by the only person I can blame.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
CalebL
Quote from: Magicman on March 12, 2013, 10:10:51 PM
Do you or anyone else know where I can find it on Woodmizer's site?
2005 LT40 HDD34
OneWithWood
Be sure to check the pin and adjuster thingy also.  If the backstop is bent the holding hardware is probably also tweaked.
I bent the whole shebang turning an oversize log with extensions on the backstop.
One With Wood
CalebL
Quote from: CalebL on March 13, 2013, 12:40:46 PM
I got tired of looking and just called Woodmizer.  You can't find it on their site because it is standard equipment now.  I ordered the kit.  Should be here in a couple of weeks.  Thanks Bibby!
2005 LT40 HDD34
