gearmatic winch contdol rebuild kit?
Started by logman81, March 11, 2013, 03:49:37 PM
logman81
Does any one know where I can fined a rebuild kit for the winch control mine is leaking where the handle goes into the body of the controler.
Precision Firewood & Logging
mad murdock
Use the forum search tool for gearmatic winch control, I think quite a while back someone posted NAPA PN's for all the parts needed to rebuild one.
overtime
Dav co farmington Maine 207-778-9060 talk to John in parts they will send you everything you need
logman81
Thanks guys it's leaking past the brass bushing, that is worn out and the o ring is worn out on the shaft causing the leak. I'll give davco a call. :)
I still think they should be a sponsor here.  ;D
coxy
the brass bushing just cost me 33.00 for 1 26.00 for the other  got mine from cj logging in boonville ny
UN Hooker
$33 and $26 for a "brass" bushing? Are you sure they were brass and not GOLD?   ::)
   UN
Retired Toolmaker/Moldmaker
C-4 & C5D TF - 5500 Iron Mule - Restored 4400 Ford Ind. FEL ex Backhoe w/custom built boom w/Valby 360* grapple w/18' reach - 920 Cat w/bucket & forks w/clamp - Peterson 10" WPF - LT-15 - Cooks Catsclaw & Dual tooth setter - many Husky saws
coxy
paid 49.00 for the brake control rubbers on top of winch sad when 8 years ago it was 18.00
oldseabee
Here is web site for service and parts manual.
http://www.paccarwinch.com/pdf/J358J.PDF
Paccar winch owns gearmatic.
logman81
Thanks I have gotten parts from paccar before when I had my bone. Thanks for the help!
