Went down to the woods today
Started by Happycamper, March 09, 2013, 06:43:13 PM
Happycamper
Took the old H and chain saw down to the woods today and de limbed  a cedar that had broken off and dragged 16' home. Cut it 8' and put it on the mill. Mill did a fine job of cutting it and I was happy to finally get sawing
                        Jim
Wether you think you can or you can't you're right
Peter Drouin
Nice job, whats the plan for the cedar :)
A&P saw Mill LLC.
License NH softwood grader.
rimshot
You have some nice timber out your way Jim.  Looks like a nice cant on the saw bed too.  If your mill is a 10 h.p., did you figure out a way to deflect that exhaust away from the verticle post on the head. I had a nice little elbo rigged up but they hit the top of the mill horizontal piece when I muscled the head wide open (up).
rim
LT 10 with a 10 h.p. and a converted boat trailer to provide mobility for a once permanent mill.
drobertson
Happy for you!  and glad to see the power feed block working out ;D  hope you get things worked out soon,
Where's all your snow there? The ground here is still covered with at least 6 inches in the field. Did you learn how to pick up logs from Magicman?   :D   Much easier than the CSM,the sawing part anyways??
Sixacresand
Quote from: rimshot on March 09, 2013, 07:02:41 PM
rim
I was not too concerned with where the exhaust was going, except I didn't particularly like breathing it.  Until I get the elbow thing done, I walk on the other side away from the muffler.
Happycamper
Peter,
The best of the cedar will be saved for cedar chests.
rim,
I put an elbo on right away but found that it won't clear the top so took it off till I figure something else out. Back to the drawing table.
drobertson,
I hope this week Wm comes up with a solution.
thecfarm,
Still a little snow left in the fields. Log lift idea I saw on the forum somewhere a while ago, works great
5quarter
Happy...is that a white cedar you have there? I've only sawn ERC and WRC and your log doesn't look like either of those. What other types of trees do you have? Any Maple or Birch on your place? very nice tractor BTW...
Blue Harbor Refinishing
customsawyer
www.thecustomsawyer.com
Happycamper
5quarter,
  It's western red cedar, we have a maple but it is a soft variety not like the eastern maple. Birch we have which is the hardest wood available. I burn birch for heating my house, longer lasting and has nice coals. I made my shop floor of white birch, screwed down with plugs.
                                  Jim
Happycamper
drobertson
samandothers
Very nice cedar chests!
Watch out going up those steps could be a bit tricky!   ;D
Happycamper
Stringers and treads are for an elderly lady in a trailer park. I visited her last fall and saw her entrance stairs were not well so made a new set for her.
drobertson
After fixin them steps, there will be two happy campers ;D
Woodkiller
I sawed 3 8" cedar logs in trade for 1 cedar that was pushing 18". I have it stacked and stickered for a cedar chest for my daughter. She doesn't know about it.
samandothers
You are a fine fella to help the lady!
5quarter
Happy...the floor in your shop is nicer than the floor in my dining room.  :D  WRC...very nice. Ive never sawed one with the bark on. All I can get around here are what's leftover wrc from log cabin builds. Those are some great blanket chests, btw.
