what to use to clean the glass?
Started by proteus, March 06, 2013, 10:14:20 AM
proteus
I was just wondering what others used to clean the glass on their wood burners? I know it only stays clean a short time, but it is nice to sit down with a cold beverage ;) after a long week of work, relax and watch the fire :) I currently use a single edge razor blade. Does anyone have a better idea?
Greg
Was it on here I heard of wood ash and water?
QuoteI heard of wood ash and water
A friend of mine does that. After an evening fire, and before the next one, he takes a wet paper towel and dips it in some of the ashes and lightly scrubs the glass clean. Saw him do it, and found it quite effective.
On my VC Defiant, I don't clean the glass very often. When I do, I remove the glass (easy to do) and soak before using a razor blade. Maybe clean once a year as they don't get very bad - most of the time.  ;D
tempforce
i've used easy off oven cleaner.  stinks real bad tho..
cleaning up wildfire damage...
making lumber and siding out of wildfire damaged trees.
proteus
Quote from: tempforce on March 06, 2013, 11:04:32 AM
I hate the smell of oven cleaner. I think I will give the water and ash a try ;D
Thanks for the suggestions!
Greg
Corley5
Corley5
proteus
Greg
trapper
Quote from: proteus on March 06, 2013, 01:00:46 PM
Quote from: Corley5 on March 06, 2013, 12:18:32 PM
Ether
you sure your'e not trying to put me to sleep? :-\
That rag of ether is the last thing I remembered when at 5 they put me to sleep to take my eye out.
Weekend_Sawyer
Windex works fine. I clean mine about once a month.
Imagine, Me a Tree Farmer.
bill m
I never have to clean the glass in my wood stove. It started to soot up one time and I found it was because of the way I was operating it.
proteus
Bill, are you going to keep it a secret? I have a Jøtul F 500 Oslo and it is non-catalytic. It has a side door, which I use for filling and a front door with glass, which I have to clean alot(about every other day) :'(
I did try the water and ash and it did work well.
Quote from: bill m on March 06, 2013, 07:48:27 PM
Greg
stumper
I know is is much more expensive then what you gentleman use, but I use MY WIFE!!! :D
47sawdust
After installing an outside air intake on my Hearthstone Mansfield the glass seldom needs cleaning.When it does,I remove the excess with a single edge razor then clean it with a fine grit scotch brite pad and windex.
Mick
Al_Smith
If you get a good hot fire blazing away it will burn the carbon off .
southernilfarm
I use Imperial Clear Flame cleaner.  It sprays on and easily dissolves the mess.  I've used about a quarter of a 22 oz bottle this winter.  I purchased this product at my local Rural King store for a few dollars.  When I'm burning good dry elm, I never have any carbon build up on the glass.  Add some of my less dry oak, and I get more of a mess.
My Harmon TL200 stove instructions explicitly states "do not use ammonia based cleaners" and "sharp objects" on the glass.  I avoid those.
Thanks,
Mike
Kioti DK40se HST with FEL and other cool attachments.
jackfork
I have an old Country Flame insert that gets sooty no matter what I do. I use wet newspapers with ash to clean the glass.
540 acres of which appox. 300 is wooded, 10 acres of water, and rest open pasture.
Timberwolf TW-5, Stihl 180, 270, 660, Echo CS-680
proteus
I tried the damp cloth with ash and seemed to work well. Then I tried just the damp cloth and it worked just as well.  8)
Quote from: jackfork on March 14, 2013, 11:01:04 PM
Greg
tyb525
We replaced our glass with cast iron inserts. Now the glass never gets dirty ;)
clww
We use a soapy brillo pad and water.
Many Stihl Saws-16"-60"
18-Wheeler Driver
LittleB
I just take a sheet of newspaper, crumble it up and 'scrub' the glass with it.  Works really well.  I've used special wood stove glass cleaner before but like the newspaper solution better.
ddcuning
For the thick stuff we use a razor blade, to clean the rest, baking soda on a damp rag seems to work well.
Dave C
We're debt free!!! - Dave C, Nov 2015
Richard PM
Another product that works really well and won't even damage paint is Spray Nine fireplace cleaner item # 15022, But I like the wife comment the best, I'll have to try that one!
maple flats
We also use a damp paper towel, just lay it on the finest looking ash in the stove and wipe. Then I use a clean towel and it is clean. We clean it every day, in the morning after letting it go out in the middle of the night.
plaindriver
We use SOS pads + water. Any real stubborn spots, we chase them with a razor blade. Lasts a day or two before loading up again. Problem is, that we burn almost 24-7 in the winter, and its tuff to get the glass to cool enough to clean it.
Kubota L4600 DT w/FEL, John Deere 750 4WD w/FEL, PH Digger,RotoTiller,Box Scraper,Disc;16, 18, 20" chainsaws;Troy Built 27T splitter; table saw, radial arm saw,turning lathe, chipper, small backhoe, Isuzu NPR 14' stakeside diesel truck; a wife that still likes me.
