Bad Logging Job?
Started by GATreeGrower, March 05, 2013, 09:27:48 PM
GATreeGrower
Sometimes I drive this dirt road when I'm wasting time...and I noticed somebody had cut their timber.  What do you guys think about this logger's use of the road?
Not too bad given all the rain that we have had.  The road can be re-shaped nicely with a motorgrader once it is drier.  However, i would not advise driving the skidder in the ditch.
Not bad to me. BUT I would have it fixed when it hardens up. Be it regraded and or more gravel hauled in.
tyb525
Looks like he drove into the ditch to deepen/widen it, maybe for better drainage?
Hard not to make a mess of things with a big machine like that.
BaldBob
Around here the state would have shut him down for continuing to log in those conditions.
MEloggah
i wouldnt call it too tough. when we file an intent to cut with the town we let them know we plan to put the road back into shape equal too or betyter then its original condition. we usually back drag and touch it up for passable traffic aty the end of every day too.
chevytaHOE5674
Doesn't look too bad to me. Once the job is finished up that road is an easy fix with a grader.
GATreeGrower
Quote from: BaldBob on March 06, 2013, 03:42:30 AM
Thats what I was thinking originally, that it was bad practice to log when its that wet
It's hard sometimes not too log when it's wet sometimes. Even though some loggers would like to stop,but can't due to payments and putting food on the table is a factor too.
Sure a lot easier to fix this dirt road, than if it was an improved road with topping and such. And fortunate that someone hasn't slapped him with a fine for just messing it up. It will dry and it can be graded back smooth.
Obvious the road hasn't been very well maintained with lack of ditches to drain the water away. So I don't see a thing wrong with using it to get the job done and then repair it back to how it was found.
But then, it is another easy thing for the gov't bodies to do as they sit back behind their desk and issue orders to stop using their roads. Gives them the power they seek. And that power is ever increasing and surrounding our every move.
If we stopped farming every time we made a track through the farm yard, nothing would have been accomplished. The manure would have piled up, the livestock would not have been fed, and a whole lot of other related problems.  ;D
thecfarm said it well
Bill Johnson
Does not look too bad to me, and its nice to see they've put a culvert in the ditchline where the road into the block takes off.  A little grading once things start to dry up will make everything good again. So from a compliance point of view if this happened in an area where I was keeping an eye on things I won't have too much heartburn.
But if this was the final condition of the road after everything was done then that would be a different story.
Bill
Texas Ranger
not real bad, the follow up in dry weather is what will count, would like to see if they do redo (not quite a Tom) the road.
Gary_C
Quote from: beenthere on March 06, 2013, 10:09:32 AM
That is becoming more and more of a problem with cutbacks in funding.
Some of the town boards around here are demanding bonds for loggers to even use their roads. And no matter how the loggers leave the roads, they keep the bonds because they say they have to grade the roads.
In this part of the world that would be the DRY weather  :D
Unless you are going to lift the logs out with a helicopter, then logging is going to make some temporary mess of some form. Of course you should try and minimise that, but working in soft damp dirt there is only so much you can do.
Real question is what it looks like after they have left. Graded, drainage ditches reformed, a bit of gravel spread on top? All good.
Packing up and leaving it like that? Not so good...  >:(
justallan1
I'd say if they leave it like that or if someone presently lives on the road, that's a problem. If it's not being used for other things right now, I see it the same as Thecfarm, folks still have to feed their families and pay bills.
Allan
treefarmer87
I wish mine was like that >:(, im cutting up against a creek/swamp bottom.
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
1999 John Deere 748G
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
customsawyer
Wait till they leave before you get to excited.
www.thecustomsawyer.com
smwwoody
Full time Mill Manager
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
Pendu slab recovery system
KJ4WXC
log cutter
Can't comment on the logging ....but the road is fine ...the main road you can make it in two wheel drive , ....the spur road nothing a little dry weather and a blade can't fix...The logger did a good job of smoothing the road up considering how soft it is.
Timbco 475E
coxy
not bad at all have seen a lot worse  the job end will tell
KBforester
Not bad considering there are no per-existing ditches or gravel. You could argue that the road wasn't designed well... but if your like me, are your closest source of gravels is cost prohibitive to use, you make due with what you have.
Just to note, as a forester/contractor, I don't appreciate people coming into my job sites and taking pictures when no one is around to explain whats going on. Its by no means illegal (unless its posted/private property), just not very polite. I wouldn't open up someone else s brief case or laptop and start making corrections or judgments on their TPS reports. Its our office, sometimes the desk is a bit messy.
If you have a concern that they are impacting your personal or a public resource, then that is a different matter.
I've had have a fella come around to my job sites on Sundays, find the worst (only) wet hole we made on the job, take pictures, and send them out in a slanderous email to as many people as he can. Its a real nightmare. Your obviously not doing that, and your not attaching a name to the picture, but some of us lose a lot of sleep at night over stuff like this.
Trees are good.
coxy
KB,that's how some people are with the wet hole. One pictuce does not tell the whole story but it does tell a bad story.
grassfed
The big thing to try to avoid in logging and farming is runoff. You want to prevent water from picking up speed running down hill and carrying topsoil/sediment into waterways. Other than runoff you want to minimize soil compaction as much as possible. Soil compaction is not an issue on a road that will stay a road. If runoff is not occurring from the road than I don't see any problem based on your pictures.
Mike
OneWithWood
KB made a very important point.  We have a local group that prides itself on taking pics mid harvest and then publishing those pics all over the place to make the point harvesting is destroying the resource.
They never publish a pic after the grading, reseeding and closeout.
One With Wood
