White All Terrain Fork-Lift
Started by RMay, April 07, 2004, 07:43:29 PM
RMay
I looked at a White All Terrain Fork-Lift for sale . Does anyone know if you can buy new parts for them . I believe White bought Oliver out but who bought White out ? ???
RMay in Okolona Arkansas  Sawing since 2001 with a 2012 Wood-Miser LT40HDSD35-RA  with Command Control and Accuset .
Corley5
Agco now owns the White name.  Parts availability shouldn't be a problem but check with an Agco dealer.  What model is it?  I've got an Oliver 552 which became the White 2-44.  They are basically a 550 Oliver utility tractor that has been reversed.  Parts are easy to get.
RMay
Thanks Corley5 I did not find the model no. on it but I did find the the lift wt. 6000# . The lift has a 6 cylinder LP gas motor and looks like it will need a lot of new parts ;D
Corley5
My 552 is rated for 5 thousand and has a 4 cylinder gasoline engine.
