Clean forks
Started by Bibbyman, February 20, 2013, 07:45:01 PM
Bibbyman
We use our loaders for everything around the mill.   When handling logs the forks often get mud stuck to them.  Then we turn around and move lumber with them.  Sometimes I clean the forks a half dozen times during the day.
I had an idea to built something like a hitching rail to run the forks under and clean them off like a boot scraper.
But I found I could stab the forks into the sawdust pile and rip them up through it.  It often works.
Sawing since '94
POSTON WIDEHEAD
Does that sawdust pile count as an upgrade?  :)
wetdog
The size of that sawdust pile makes me think I'm not sawing enuff
hackberry jake
The best way to ensure clean forks is to serve  smiley_devil pie. They will all get licked clean.  musteat_1
YellowHammer
I jab my loader forks into round hay bales, takes the mud right off, and the cows gather round to watch.  :D
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
