need ideas for bookshelf back
Started by Dan_Shade, February 15, 2013, 08:19:06 AM
Dan_Shade
I'd like to do a solid wood back in a book case that I'm building.
How do you guys normally do this?
lots of dull bands and chains
isawlogs
 Dan,
I did a solide wood back for a bookshelf I did for my son. I used tongue and groove pine panelling, cheap ( key word here for me ) and looks good to boot.
   Marcel
pigman
Dan, solid wood would be nice, but some stained thin plywood hidden by a bunch a books would be a lot easier. If you use solid wood, Marcel's idea would be best. You could use the same wood as the rest of the case. You could also use frame and panel construction, but that would be a lot of work for the back of a case that is not seen unless the bookcase was not against a wall.
Axe Handle Hound
Similar to what isawlogs said, I like to use shopmade shiplap in 4 to 6 inch widths.  Looks really nice when you get done.
Tree Feller
T&G, shiplap, frame and panel...all three options suggested are good as all three will accommodate movement of the back panel.
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
Dan_Shade
I was thinking of using 3/8 thick shiplap
Axe handle Hound,that looks good.
Dan,I was thinking I would like to see a picture of the book shelf when done,please??
Quote from: Dan_Shade on February 15, 2013, 02:54:59 PM
That would work, but I tend to just make mine from 4x1s, planed and jointed you get 3/4". Well working in metric it's sawn 100 x 25, then machined to 90 x 19. Makes for a very solid back that add a lot of structural strength to the unit. If can be fixed solidly to the back of the unit and support the shelves. No need to worry about cross-grain wood movement because the shiplap or T&G allows for it. The Shiplap profile is easier to make on a router table
I use solid wood as it's also cheaper for me. I can saw that myself for minimal cost, where I would need to buy expensive imported hardwood ply, that wouldn't match the woods I'm using anyway.
Planman1954
A simple lap joint works well, and can be done simply on a table saw from thin stock. Be sure to stain the lap before assembly to avoid the bare wood showing with wood movement! This holds true for T&G joinery also.
Oh, and Axe Handle Hound: Nice cabinet!
Norwood Lumbermate 2000 / Solar Dry Kiln /1943 Ford 9n tractor
Dan_Shade
what is the standard thickness for the backs that you guys use?
terrifictimbersllc
For solid wood, I'd stick to around 3/4 for a bookcase. Maybe to 9/16 if you have one or more fixed shelves you can nail the boards to.
isawlogs
 Well I did not need the strenght on the back, so I bought some 5/16 TG waine scotting and used that. SYP at its bestess.  ;D :D :D
   Marcel
drobertson
My first thought was some t&g car siding, axe handles looks good! and the 5/16 t&g is a good idea as well,
I have used 3/8" shiplap to back a cabinet with glass doors, and it worked well and keeps the weight down.
hackberry jake
Wouldn't it be stronger if the boards ran at a 45 degree angle?
Quote from: hackberry jake on February 16, 2013, 01:50:22 AM
Yeah, but at some point you have to say it's a book case, not a house foundation  :D
Then there is the fella that comes along and uses hardboard with birch veneer bonded to it. Make grooves on the back edge of the sides for the hardboard to slide up the back, done. ;) Cuts down on the heft and no worries about the back moving.
isawlogs
Maybe that guy has more money and time then the most of us.   ;D :D
   Marcel
I don't know if that would stand up to scrutiny. :D
Axe Handle Hound
Quote from: WDH on February 15, 2013, 11:21:15 PM
Thanks for the compliments everyone!  I don't remember exactly how thick the back is on the cabinet I made, but I don't believe it's any more than 5/16" at most and I'd agree with WDH that 3/8" is more than adequate.
Dan,
This cherry hutch that I posted about earlier this summer has a 3/8" shiplapped back.
bama20a
Was that the same hutch you built for Danny & Lorraine ? That was some kind of nice work,
It is better to ask forgiveness than permission
