skidder not running in the right gear
Started by timberjack97, February 13, 2013, 09:00:57 PM
timberjack97
I have a timberjack 360  grapple skidder  when I shift from 2nd to 3rd  it  says its in 3rd but it goes real fast like its in a lot higher of gear any ideas thanks
kiko
Is forth gear slower than third? if so then you probally have harness issues( activating the wrong solonoid. Does it pull fine in 1 ans 2 or are they slipping? With the key switch off, move the shift lever to reverse and the toward the seat and hold it there while you turn the key switch on( not start), this will propt the shifter to a dianostinc mode.  G good, o OPEN circuit, s short.
timburjack
have a friend that has a 660 that did that. one of the solenoids on the tranny could be out which makes it shift into 5th or 6th. or a wiring problem
poorfarm
how old?? i know my 380 is a huge jump from 2nd to 3rd and its a 3 speed
timberjack97
I  got it fixed  it was in the  wiring  it runs great now
