Sweet Gum......SWEET!
Started by POSTON WIDEHEAD, February 12, 2013, 04:19:10 PM
POSTON WIDEHEAD
I sawed a few 1 x 10 x 8 inch Sweet Gum boards today. I built a shed last year and was very impressed with how it has held up in our mild S.C. weather.
I plan to build another shed to hold Custom Cut Lumber until the customer can pick it up. I'll use these Sweet Gum boards to side my new shed.
We all know how Sweet Gum acts during the drying process, but I be DanGed....I love the grain.
In fact, the shed you see in the pics is sided with Sweet Gum. The siding is now dry and as hard as a rock. Very good siding.
Tree Feller
I likes Sweetgum.   ;D
Did you nail the siding up green or was it dried?
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
Jay C. White Cloud
 ;D
I miss being able to get sweet gum and tulip poplar,  :( That really is pretty stuff!
POSTON WIDEHEAD
Quote from: Tree Feller on February 12, 2013, 04:27:36 PM
What I did Cody was, I framed the shed up first. Had the Pine flooring down and everything in place and ready for the siding.
I then put a BIG 'OL Sweet Gum log on the mill. As I sawed boards, I'd grab a handful and walk around and hang' em. The boards were GREEN and water was a coming out.  :o  I used Ring Shank nails. When a ring shank goes in....it don't come out. The boards held in place as the "circus lumber" dried  ;D.
When I put the boards up, I jammed them together. As they dried, they shrunk leaving a crack which I wanted for the ventilation. Now air gets in to the shed very well for air drying lumber.
m wood
good thinking since you already knew it would be vented storage space
I am Mark
80 acre woodlot lots of hard and soft
modified nissan 4x4/welding rig
4x4 dodge plow truck
cat 931b track loader
Norwood mark IV
4' peavy
6' peavy
stihl 034
"her" wildthing limber saw
ALL the rustic furniture  woodworking stuff
check out FB
Tree Feller
Quote from: POSTONLT40HD on February 12, 2013, 04:38:30 PM
It don't get much greener than that. Thanks for the explanation. I'm sorta surprised the boards didn't crack after shrinking that much but perhaps that spiral grain in Sweetgum helped it stay intact.
Does anyone know the MC of green Sweetgum (i.e., no drying has taken place) I know that it will sling water bad enough to warrant a slicker when turning it on the lathe.   ;D
Cody
Kioti CK 30 w/ FEL
two tired
Poston, that looks like red gum in the pictures, I have a few spalded red gum 11/2 x 8 inchers, when I learn how to post pictures I will show them.
when wondering about weather conditions call the dog in and see if he is wet
pasbonbasile
has anyone used sweet gum for laths under metal siding and roofs? if so how did it hold up? put up green or dry? got a big shed to build and have a lot of them.
thirteen- tractors, one combine, no mill yet. Looking for one. Used -to have a wm lt4hdg25
Update 9-27-15 now have WM LT40 Super Hyd. used (1996) but back into sawing. Mostly pine and oak.
thurlow
Quote from: pasbonbasile on February 12, 2013, 05:58:23 PM
In my part of the world, sweet gum was the wood of choice for laths (the unknowing may call 'em purlins) because the nails wouldn't back out;  we tried to use 'em while green, before they twisted.  Since we've started using screws, I've used other woods.........mostly yellow (Tulip) poplar.
Here's to us and those like us; DanG few of us left!
JSwigga
I wish I could get my hands on some sweet gum.  Only run across a log every so often.  Poplar on the other hand I get too much of.  Maybe I should drive it down south and trade it for some sweet gum!
60" Lucas Dedicated Slabber, TimberKing 2200 , 5 ton Nissan forklift, John Deere FEL
POSTON WIDEHEAD
Quote from: JSwigga on February 12, 2013, 06:51:17 PM
Stick with the Poplar. I only try to find ways to use Sweet Gum because it's in an abundance here.
I call Sweet Gum, "Circus Lumber". It will do more tricks than a monkey on a tricycle if you do not properly take care of it.  :D
Bill Gaiche
Just wait till MM sees this... bg
JustinW_NZ
Quick question, what is the botanical name for sweet gum?
Is it Liquidambar styraciflua? - http://en.wikipedia.org/wiki/Liquidambar_styraciflua
Just wondering what it is tis all :)
Cheers
Gear I run;
POSTON WIDEHEAD
Quote from: JustinW_NZ on February 12, 2013, 07:44:08 PM
''CIRCUS LUMBER"  :D I have no idea Justin.....hold on......DANNY!
He'll know.
POSTON WIDEHEAD
Quote from: Bill Gaiche on February 12, 2013, 07:42:06 PM
Magic may have to take an aspirin.  :D
Yes Justin, Sweetgum is Liquidambar styraciflua.
The Sweetgum that I have sawed was to be used as either wall paneling (beautiful) and outside building siding such as David's use.  Always eliminate any possibility of ground contact.
Sweetgum lumber is squirrely for sure, but my dislike for the species is not the lumber but it's ability to readily spread seeds.  Sweetgum along with Honey Locust, Black Locust, Persimmon, and Pecan are by far the species that will take over any open land in my area.   :-\
That sure is pretty.  Sweetgum just needs room to move around, and it will behave as long as you do not crowd it  :).
hackberry jake
One day scientists will come up with a new drying process that eliminates drying defects 100%. They will then be mowing down pine plantations and replacing them with sweet gum. They spring up from "gum ball seeds" or from roots easily. They grow extremely fast in full sun, and once dry, has to be one of the hardest woods to split. The tree can't be killed by man nor beast (easily). I read somewhere that it is a living fossil. The tree hasn't changed much since the dinosaurs roamed this planet.
GeneWengert-WoodDoc
I think that rather than come up with new drying procedures, we need to have the forestry scientists genetically improve sweet gum to eliminate the cross grain so the wood will not warp.  Or maybe just eliminate shrinkage in the wood fiber.
Or in my instance, just send me some genetically altered seeds that will prevent germination....period.  I do not have any warp or shrinkage problem with Oak.
I hates Sweetgum.   ;D
scsmith42
I've used it here on the farm.  The wood was put up dry and also planed to thickness.  It's worked great - no noticible twisting or distortion.
Tom's 3638D Baker band mill
It makes very good lathing especially if the rafters are 16" or 19 diamond spacing.
hackberry jake
I hear sweet gum and sycamore put up green will shrink down on the nail and the moisture from the wood causes a little rust which makes it impossible to get your nails out. Sweet!...gum
