My first foreign object!
Started by ND rancher, February 08, 2013, 11:02:35 PM
ND rancher
  This is what I found when I was giving a new 7° a trial run. I could tell something was wrong, just not sure what, until I pulled the board off. Started digging and found this. It's not mine! I do not like FO's! The 7° was working real good on that ash until smiley_smash. I think I was on the third ash log when this happened.  Keith
TimberKing B-20.  Have been bitten by the bug! Loving life !
Hitting one of those is usually worse then hitting a nail.
Mountain State Farm
That sawdust bug bit me in the ...
ND rancher
I sunk one of those into a tree this past hunting season. A 2" elm that at 30 yards, I'm sure I didn't even know it was my side of the deer.
Couldn't believe it when that deer walked away, as I heard the "smack" loud and clear. The carbon arrow had compression failures along it so it ended up to be a $30 loss with no meat.  :(
hackberry jake
Where's the aluminum insert? Maybe the culprit unscrewed it after he pulled the shaft off of it.
Chuck White
I hit an Iron Wood tree once, years ago when bow hunting.
Couldn't pull it out, so I unscrewed the shaft and went on my way.
So far, I haven't hit a broadhead with my mill, but there's always next summer!
drobertson
I have had the misfortune of missing the intended target a few times, one had to unscrew, the other swelled at the insert and the shaft bounced back. vise grips an pry bar got them back,  I guess hitting this with the blade is better than the palm of your hand,
redbeard
Wonder if anyone has ever hit a old stone arrow head.  I bet that made a bit of a racket when you hit that arrow head ND rancher.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
ND rancher
Boy if I hit one of those! :o It could happen . We have trees that have been here for hundreds of years!
   This is a small one! If you check the rings in the oaks you realize just how long it takes to grow trees here!
POSTON WIDEHEAD
Where did you get that "TEENY TINY" chainsaw?  :D
ND rancher
POSTON WIDEHEAD
isawlogs
 Well the one in the background to the right of the tree stand sure ain't no twigg either  :D   I have yet to hit anything arrow like yet ... and I could do with out for a while too.
   Marcel
customsawyer
Is it just me or is that saw trembling a bit. :D
www.thecustomsawyer.com
POSTON WIDEHEAD
Quote from: customsawyer on February 09, 2013, 09:25:34 PM
No...it not you......it's trembling.  :D
terrifictimbersllc
Wouldn't mind a little saw I could hang on my key chain where'd you get it?
rooster 58
   Hey ND, what kind of tree is that? Would that be a Cottonwood?
isawlogs
 Thats the size of trees Danny and Jake love to play with, specialy Danny.  :)
   Marcel
ND rancher
Rooster, You are correct! smiley_clapping
hamish
Mine was a horsehoe, quite a shock finding in the near center of the tree.  Horseshoe 1 Millband 0.
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
