ever seen an oak subfloor in an old house
Started by hillbillyhogs, February 03, 2013, 09:20:02 PM
hillbillyhogs
Seeing as we have more red oak than we know what to do with... my feeble mind has surmised that a red oak subfloor run on a 45 degree angle T&G (of course) with 2 1/4 wide red oak floor on top of it would do pretty well since they would  be the same species...??
Are my assumptions correct?  Or am I crazy... ::)
POSTON WIDEHEAD
That sounds like a good strong flooring system to me.
Crazy? No way.  smiley_thumbsup
Use what you have. I would use the lower grade for the sub floor.
florida
No need for the sub-floor to be tongue and groove.
General contractor and carpenter for 50 years.
Retired now!
hillbillyhogs
Quote from: florida on February 03, 2013, 10:04:38 PM
I've thought about that for a while, you think it would be stable enough,?? I figured I'd T&G it to cut out  the movement. When my dad started building they did subfloors on a 45 square edge lumber. He said they never used oak though.  You've been doing it longer than I've been alive so I'll take that advice.
Tree Feller
Quote from: hillbillyhogs on February 03, 2013, 10:50:23 PM
T&G doesn't stop the wood from moving. The only thing that will do that is a constant relative humidity.
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
low_48
My house was built with pine 1x6 subfloor at a 45 deg angle. There is a gap between the boards, maybe shrinkage, maybe to keep it from squeaking.
hillbillyhogs
Quote from: Tree Feller on February 03, 2013, 11:03:28 PM
I understand, I was referring to up/down movement but, with 1" oak I don't there'll be much in a 14 1/2" span
hillbillyhogs
Quote from: low_48 on February 03, 2013, 11:41:31 PM
That's what they all were when my dad started building, he's 76. Always pine though. I read what the gap was for on a site but, don't remember.
Tree Feller
Quote from: hillbillyhogs on February 04, 2013, 07:24:07 AM
The gap is to keep the floor from buckling when the planks expand from moisture. In older homes the planks were probably laid green and initially butted against each other. As they dried in place, they shrunk leaving a gap.
Quote from: hillbillyhogs on February 04, 2013, 07:22:51 AM
Aha, now i see. yes, t & g would definitely help keep the boards flat. I have to say that a 1" Oak sub-floor covered with Oak finish flooring would certainly be stout. Since the two layers would be laid somewhat cross-grain I don't think being the same species helps or hurts.
Cody
Kioti CK 30 w/ FEL
hackberry jake
When I build a house, that is exactly what I plan on doing  8)
wheelinguy
Sounds strong but it also sounds really heavy! Don't undersize your floor joists!
Holmes
I would not want to the person that has to hand nail anything into the subfloor... ;)
Think like a farmer.
hillbillyhogs
Quote from: wheelinguy on February 04, 2013, 05:37:54 PM
We have always used 2x12 F.J. Hem Fir or SYP, on almost everything other than a 12' wide addition or something like that. They let some of the big builders around here use 2x8 SPF on a 20' span, no joke or stretch of the facts.
hillbillyhogs
Quote from: Holmes on February 04, 2013, 06:05:18 PM
:D  Somehow anytime I'm building something of my own I end up by myself so I almost always use nail guns!
woodmills1
worked on tearing down a large mill in Rainelle W Va.
3 inch chestnut sub floor with 3/4 oak tounge and groove on top
hillbillyhogs
My great-grandfather used to tell me about the chestnut stumps he saw when he was a kid, 2-3' across, can't find even one now. :(
woodmills1
pretty sure they all died in the 1930's or before
drobertson
all I know is that sub floors that are screwed down squeak a lil less than ones that are nailed.  Of course some folks like to hear the squeaking,  not me.
jdonovan
[quote author=hillbillyhogs }
We have always used 2x12 F.J. Hem Fir or SYP, on almost everything other than a 12' wide addition or something like that. They let some of the big builders around here use 2x8 SPF on a 20' span, no joke or stretch of the facts.[/quote]
Use the proper MSR grade, 1/180 deflection limit, 25 PSF live load 12" spacing, and its possible to get a 2x8 to meet that.
Floor will be bouncy as heck, can't throw a super bowl party or everyone will wind up in the basement, but it is in theory possible.
OK, questions.  Will you use anything between the subfloor and the flooring such as felt or house wrap?  If so, why?  If not, why not?  Will you try to hit the floor joist when nailing the flooring down?  Will you surface nail or blind nail?
hillbillyhogs
30# felt between layers, felt helps with squeaks,etc. and just give a separation of sorts between basement and first floor, believe it or not it also helps some with sound levels in between floors. 1st layer blind nailed to floor joists as well as face nailed followed by screws, 2nd layer blind nailing of course.
shelbycharger400
my house built in 1960 uses 2 x8 stringers  16 footers with a beam in the center as the tie plate i guess,  1 x 12s on a 45   with  t+g  1 1/2 wide 3/4 thick maple      Its too busy, but too costly to tear out and redo
muddstopper
My old house is built with lumber we cut and had sawed. Subfloor and roof decking are all wide boards of varying width. Nailed down on a 45 angle. We did run them thru a planer to get consistancy in the thickness department. . Most of the subfloor and decking are 1bys, popular and whitepine. Floor joist are 2x10 yellow pine 2-14ft spans with poles, and the band and some of the joists are actually sawed cresote poles. House was originaly 1x12 whitepine board and batton sideing. We removed the batton sideing, stripped to the studs, and replaced with vinyl a few years ago because we where getting water around the windows and some of the wood was starting to rot. Only bought lumber was the roof trusses.
red oaks lumber
maybe sell some oak and use that money to buy plywood.it will be lighter, move less, and a whole lot eaiser to nail into.
