Sorry, this sawing is pretty cool...
Started by mmartone, January 15, 2013, 08:21:07 PM
mmartone
I'm having a good time milling some of these logs, sorry if I'm a PITA. Heres a log we did this evening, the cant made 5 2x10x16' pieces. After the cuts we flipped the logs over and found this beautiful heart all the way up the log.
Dont make fun of my engine, it was on the mill when I bought it.
Remember, I only know what you guys teach me. Lt40 Manual 22hp KAwaSaki, Husky3120 60", 56" Panther CSM, 372xp, 345xp, Stihl 041, 031, blue homelite, poulans, 340
mesquite buckeye
Very cool. What wood is it? ??? ??? ::)
Looks like an old honey locust.
mmartone
rooster 58
      Awesome wood!  Looks similar to larch, without the knots ;)
mesquite buckeye
Quote from: mmartone on January 15, 2013, 08:38:05 PM
Long leaf yellow pine...
Is that funky, or normal for that tree? I've never seen one cut open.
dgdrls
Dandy looking planks!!
What year and model is your Mill?
DGDrls
haywire woodlot
Quote from: mmartone on January 15, 2013, 08:21:07 PM
I wouldn't dream of making fun of it, but what is it?
Dave
Bogue Chitto
I have cut long leaf also.  Its  fine wood.
drobertson
Delawhere Jack
You'll be just as excited when you mill you 1,000th awesome log! :) :)
mmartone
Some of them have that dark heart on them, not all. The engine is a military surplus opposed 4 cyl 84 cid, just like a small aircraft engine. The mill is an 86 lt4 manual. It only cuts to 2" not 1" like the flyer says that came with it, just gotta plan ahead!
Well said Jack.  Every log is a box of chocolates.
mm, do you know why it will not drop below 2"?  What is hitting what?
mmartone
Theres some framework on the up/down carrige that stops on the rail guard over the top rod. The scale only goes down to 2" also.
My 1987 LT30 won't go below 3". It may have been 2" at one time. It was just how the early mills were made. You can't saw to the bed. It can be a real pain in the butt when you have to keep putting stock under the wood you are sawing, if only sawing boards.
trapper
My LT30 manual of about the same vintage as Jeffs will go to 1inch.
LeeB
Couldn't you add some height to the bunks? Possibly something out of aluminum or ss square tubing.
Buck
Respect is earned. Honesty is appreciated. Trust is gained. Loyalty is returned.
Live....like someone left the gate open
Cedarman
It would be possible to add 1" of metal to the bed rails and the slides at the end.  Those old mills were designed to only go down to 2". I don't know the reason.  It was a happy day when I put in our 96 mill with hyd.  Don't miss that old LT30, but it is still sawing today about 15 miles away and the owner is happy as can be with it.
OK, I was/am not familiar with the specifications of the older sawmills.  I certainly would not modify the sawmill, but I would be looking toward building a jig.   smiley_idea
slider
Nice wood but that engine had me captivated ,glad you told us what it was.How about parts.Can you still get them.
al glenn
mesquite buckeye
The easy way to deal with this is to stick a 1" board under your 2" board to make the last cut. Make sure it is a good one, or you end up with 3 crooked boards.
The mill I borrow in Missouri works like that. I think it is the old original Woodmizer design. :(
mmartone
Parts are available here.
http://www.saturnsurplus.com/4a084.htm
ITs smooth being an opposed, but I need some decent 1.5" mufflers for it.
I havent tried putting aboard under it, still have to do something about the stops, the are less than 1" tall
isawlogs
   Take a 1 inch board and screw a 2x4 on edge to its side. First 2 inch board you cut in two the 2x4 will be cut and leave you with a board stop for futur use  ;)
   Marcel
Per MM and isawlogs, we used to use a similar jig (just a 2" base with a 1" fence for a lip). Would only clamp the jig and just set the cant on top. Leave the saw set for the 1" board and pull the board after each cut.
Also worked quite well for processing the quarters of logs when making 1/4 sawn too.
