Got a new tool.
Started by customsawyer, January 15, 2013, 04:31:20 AM
Tree Feller
Congratulations on getting a great machine, Jake. With an operation as big as yours, I'm sure it will be put to very good use.
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
Amelia Farms
A friend has been storing his NH skid steer in my barn for a couple of months. He tossed me the keys and said "run it like you stole it".
I am a little embarrassed at how many hours I have put on the machine in those 2 months.  :D
Woodmizer LT40, wish it was hydraulic.
scsmith42
Jake, nice score!
I'll give you a hint; if when the 1-1/2" round bar bends that supports the forks, replace it with cylinder rod from hydraulic cylinders instead of normal cold roll steel. It will support more load w/o bending.
Tom's 3638D Baker band mill
Quote from: Raider Bill on January 15, 2013, 07:37:20 AM
Jake get one of those grinder attachments and bring it up to Tenn next time you stop by! We can see how it works cleaning up some of my woods.:D
Jake, you know how hard Bill is on borrowed equipment in his woods. It tends to burn up. :D
rmack
nice machine!
looking forward to the videos  :)
the foundation for a successful life is being able to recognize what to least expect the most... (anonymous)
Welder Bob
2012 LT40HDSD35 Yanmar Diesel Triple
1972 Patrick AR-5
Massey Ferguson GC2410TLB Diesel Triple
Belsaw Boat Anchor
Raider Bill
Quote from: SwampDonkey on January 15, 2013, 11:15:26 AM
Sure burn one dozer and I'm labeled forever ;D
Mooseherder
Sweet piece of equipment Jake.
Sure is going to come in handy. :)
pineywoods
Nice.. Now you won't have to coerce Danny into toting boards. ;D Recon you can teach him how to drive it ?
fat olde elf
Good for you.Jake......Gee, Danny gets sick, misses a few days, and you get a new skid steer.......... Had a little experience with New Holland some years ago
and it was very positive...They make good stuff......Keep the faith...Paul R.
Cook's MP-32 saw, MF-35, Several Husky Saws, Too Many Woodworking Tools, 4 PU's, Kind Wife.
sigidi
Sweet ride Jake, you'll love it mate. I got a smaller bobcat version and it is the ducks nuts I reckon ;D
Busy Beaver Lumber
Awesome addition to the family. Wish I had something like that. Just not enough need for one yet.
Woodmizer LT-10 10hp
6 x 10 dump trailer
Grizzly 6in Spiral Cut Joiner
Twister Firewood Bundler
Jet 10-20 Drum Sander
Jet Bandsaw
Save a tree...eat a beaver!
Holmes
Very nice tool. It appears to be a BIG one. 8)
Think like a farmer.
NWP
You'll wonder how you ever made it without one.  That NH looks just like my Case.
1999 Blockbuster 2222, 1997 Duratech HD10, 2021 Kubota SVL97-2, 2011 Case SV250, 2000 Case 1845C, 2004 Case 621D, John Deere 540A, 2011 Freightliner with Prentice 120C, 2012 Chevrolet, 1997 GMC bucket truck, several trailers, and Stihl saws.
clww
Nice piece of machinery you have there! :)
Many Stihl Saws-16"-60"
18-Wheeler Driver
customsawyer
Thanks for all of the replies. There was so many questions that I not sure I will answer them all but here goes.
1st. Bill is not allowed to drive or borrow this one.
2nd. Danny is if I am not looking. :D
3rd. I checked on a couple of different brands but lift, weight, and tires + price were the deciding the factors.
4th. In the second pic, if you were ever wondering what a monkey with a math problem looks like, there you go. ;D
www.thecustomsawyer.com
SAWMILL BUDDY
You'll like that skid steer. If something happend to mine I'd have another tomorrow.
Sixacresand
Way to go, Customsawyer  I will have to stop by and check it out.
clww
Are you the monkey, or the problem? :D
18-Wheeler Driver
That is a really sweet looking machine!  I am sure that we will get to see just how big a log it will pick up (or won't pick up  ;D).
Bill Gaiche
Very nice. bg
New Holland L230 Skid Steer Loader
Specifications
Skid Steer Loader
Manufacturer   New Holland
Model   L230
Series
Production Status   current
Operating Performance
Size Class - Operating Capacity   2701 - 3000 lbs
Rated Operating Capacity (ROC)   3000lb1360kg
ROC with Opt Counterweight
Tipping Load, Standard   6000lb2722kg
Breakout Force, Bucket   8585lbf38.2kN
Operating Weight   8300lb3765kg
Bucket Capacity, Heaped
Lift Arm Linkage Geometry   vertical
Engine
Manufacturer   FPT
Model   F5C E9454
Cylinders   4
Engine Type   diesel
Aspiration   Turbocharged
EPA Emission Std - Tier Rating
Gross Power   90hp67kW
Net Power   84hp63kW
Peak Torque @ 1400 rpm   251lb-ft340N•m
Displacement   195in^33.2L
Powertrain
Travel Speed, Single Speed   7.5mph12.1kph
Travel Speed, Two Speed   12.2mph19.6kph
Drive Chain Size   ASA #100
Hydraulic System
Std Hydraulic Flow   22.5gpm85L/min
High Hydraulic Flow   34.6gpm131L/min
System Relief Pressure   3000psi207bar
Dimensions
A. Operating Height, Maximum   161.3in4096mm
B. Hinge Pin Height at Max Lift   131.1in3330mm
C. Dump Height at Max Lift   104.5in2655mm
D. Dump Angle at Max Lift   55°
E. Dump Reach at Max Lift   30.7in780mm
F. Rollback Angle on Ground   33°
G. Rollback Angle at Carry Position
H. Ground Clearance   9.5in243mm
I. Wheelbase   52in1322mm
J. Length w/ Std Bucket on Ground   142.7in3624mm
K. Length without Bucket   117.6in2986mm
L. Angle of Departure   27°
M. Height to Top of Cab   80.4in2042mm
N. Width with Std Bucket   78in1981mm
O. Width over Tires   76in1930mm
P. Turning Radius, Rear   70.4in1789mm
Q. Turning Radius, Front w/o Bkt   56.2in1428mm
R. Turning Radius, Front w/ Bkt   84.8in2155mm
Tires
Tire Size   14 x 17.5
Service Capacities
Fuel Capacity   25.5gal96.5L
Cooling System
Hydraulic Reservoir   6gal22.75L
Hydraulic System, Total
Other Features
ROPS
Self Leveling Bucket
Loader Controls, Standard
Loader Controls, Optional
barbender
Skid steers are just plain handy. Kind of like a leatherman tool on wheels. Jake, you either have to scuff that machine up and get it dirty, or shine and polish yourself, cause the 2 of you don't match at this point ;D
Jemclimber
Quote from: customsawyer on January 15, 2013, 07:36:19 PM
That was funny. Still has me laughing.....  :D
lt15
Raider Bill
Somebody's got to knock the new off it :D
I agree, and he may as well use a Pro  :D.
Holmes
Just because he burnt up a bull dozer does not qualify Raider Bill as a pro. ;D ;D ;D
