028 av super
Started by bagman, January 12, 2013, 08:11:41 PM
bagman
Just picked one of these saws up the other day. So i decided to clean it real well, i took the recoil off to expose the flywheel and ignition coil. took the ignition coil out to clean behind it and all the fins on the flywheel. go to put it back together but forgot to gap the coil and flywheel any one know the spec for this? or can you steer me to a manual or something to get one?
Al_Smith
bagman
Thanks Al
Also my vent tube coming out of my tank has seen its day, Are these tubes still available,   I see there is something inside the tube
Al_Smith
You should be able to get it .It should have a thing inside the tube that look like a screw which is really a check valve type thing .
The vent is part number 1117-350-5800 and the insert is 1120-358-8105.
bagman
thanks Al I will take the part number to the dealer
AdkStihl
Quote from: Al_Smith on January 12, 2013, 08:25:26 PM
12 thou give or take .
A business card....0.010-0.012".
Double the card in half to check spark plug gap.
J.Miller Photography
bagman
Thanks for the replies everyone.  Very helpful
