My Sycamore project
Started by rockman, January 12, 2013, 09:52:41 AM
Dave Shepard
I really like sycamore. I found I had a lot of waste on the trees I've cut. Some of it turned red and almost crumbled overnight.
I've been stickering cherry at 1' intervals lately.
drobertson
I never knew sycamore was this pretty, sad to say I have passed up so much I am ashamed to say. I will get more envolved with sycamore from this point on.  thanks for the post.
hackberry jake
There has to be a happy medium with stickers. I almost wonder if you should start with stickers every 12" towards the bottom and about halfway up go to 24". The reason I say this is; say it takes x amount of pounds per linear foot of sticker to keep lumber straight. If you have 20 stickers between each layer, the weight is spread out more and you don't have as much holding force. Maybe I'm looking at it all wrong.
Norm
I've started doing the same as Dave on my stacking although mine don't look nearly as nice as his do.  :)
scsmith42
Quote from: hackberry jake on January 15, 2013, 02:01:16 AM
Jake, the total lbs per square foot is the same regardless of how closely it is stickered; however the pounds per square inch of sticker is lessened when you use more stickers.
Even with reduced pounds per square inch on the stickers, the fact that they are closely spaced helps to prevent minor wood movement.
Tom's 3638D Baker band mill
LeeB
The weight, or force, applied to the sticker spreads out at a 45° angle from the sticker so having more sickers helps to deliver that weight more efficiently.
AdamT
I've got 4 or 5 sycamore logs that I plan to Quarter saw Saturday. They're not real big, about 15".    Not sure which method I'll use once I start. If it goes well, I have a bunch of sycamore growing that are straight as an arrow, and 40' to the first limb
Dave Shepard, those stacks look awesome!
2017 Wood-Mizer LT40HDD35-RA
2011 Wood-Mizer LT40 HD
It's better to have it and not need it then it is to need it and not have it
Sometimes with smaller logs, just taking the center 3, 4, or maybe 5, QS boards out of the cant centers and rift sawing the rest is the easiest and yields the most total lumber.
rockman
OK, Today I restacked my sycamore with stickers on 18" centers, I was to danG tired to take photo's, but maybe tomorrow.
Kevin
kioti ck-20 loader backhoe, box blade, disk, log arch
Husqvarna 455 rancher
Lincoln Ranger 10,000 welder
fishpimp
Good stuff y'all ! I'm lookin forward to saw some myself!
It's beautiful !
Dave Shepard
Quote from: Norm on January 15, 2013, 07:54:40 AM
I use a stickering jig. I think I may have a thread somewhere about it. It has 9 posts on it, 24" apart. For the 12" spacing, I just eye balled the spacing between the posts. I cut grooves about 3/8" deep, and 1 3/8" wide on the post, as I use 1 1/4" wide stickers. This works really well for one person stickering. You just stick the sticker in the groove and line the near side up with the sticker from the layer below. It also keeps the stickers pretty much where they belong as you slide boards around on top. It took a few hours to build, but it has saved a ton of time. It also makes sure everybody else gets the spacing right. I don't need stacks with 24"-18"-29"-19" spacing. :D
Okrafarmer
Now selling Logrite tools!
kelLOGg
An excellent and clever idea. My stickers get knocked out of place too easily and I have to walk around to re-position them. I see 4 notches on the bottom of your base beam. Is that for ratchet straps to bind the lumber tight? Easy to add more.
Bob
Dave Shepard
Notches are for the forks on the Lull so I can move the jig around.
GeorgeK
Great Jig. I will get one made!
George Kalbfleisch
Woodmizer LT40, twin blade edger, Bobcat A300, Kubota L48 and yes several logrites!
scsmith42
Two thumbs up re that jig!  Thanks for sharing.
Dave Shepard
I used EWP because that's what I had available, but a hardwood might be better, the screws on the bottom of the uprights have loosened a little. I used 6" Headlok screws.
