Wood is Smoking Blades
Started by Pitch, January 09, 2013, 03:00:59 PM
Pitch
I've got a chunk of dry tropical wood.  It's at 8 percent moisture so very dry.  It's not the most dense piece of tropical wood, I'd say somewhere in the middle .60.  The piece is 10' long and 12" wide.  It's 2" thick and I've been trying to rip it into two 7/8" boards.
I tried cutting this stuff with my softwood blades and my hardwood blades.  With a brand new blade out of the box it will cut for about eight inches and start to send out blue smoke.  I've dulled 4 blades on this piece of wood.  I've been cutting this stuff in my woodshop with no problems (carbide).
I've ordered one of the S-Tip blades from Woodmizer, when it gets here I will try it.
If anybody has any other ideas I'm all ears.
I tried searching for info but didn't come up with much.
POSTON WIDEHEAD
Wow Pitch.....I feel for ya. You said Tropical wood....do you know the species?
I personally don't have an answer but just wanted to know if you knew.
Somebody will have an answer.
Good Luck to you.
Dodgy Loner
I don't suppose you have any idea what kind of wood it is? Some tropical species have silica in the wood (basically, very fine sand), which will dull anything short of carbide in short order. If it's just a very hard wood, then you might try a 4° blade. I've never used them, but many folks on here have recommended them for dry hardwood.
Pitch
I've tried to figure out what kind of wood it is with no luck.  It was given to someone then given to me.  I was shocked at how fast it dulled the blades.  I have planed it with standard planer blades without a problem.
I may try one of the cobalt blades from Timberwolf if the S-Tip doesn't get it done.
POSTON WIDEHEAD
Quote from: Pitch on January 09, 2013, 03:19:26 PM
Ok Pitch....don't hollar at me now  :D.....but if you have sawed this stuff in your shop with success and planed it with success......your blade on the mill is not put on reversed is it?  :)
Bogue Chitto
 Did you check for metal at the point of going dull.   ??? :)
Pitch
No reversed bands and no metal.
mesquite buckeye
Is there tension in the wood that closes the kerf on you? If so, you can stick a skinny wedge in the kerf to keep it open. I have seen a lot of this kind of thing happen when I cut eucalyptus or other highly figured wood.
mesquite buckeye
Quote from: Dodgy Loner on January 09, 2013, 03:11:00 PM
I've used the 4° blades for dry desert ironwood and mesquite. They still get hot really fast without cooling water....
They do work though.
Pitch
I won't be yelling at anybody.  This free lumber is starting to get expensive.  Just ordered a Cobalt blade from Timberwolf.
I normally cut green Fir/Cedar/Maple on my mill.
This is new territory for me.  I'm not a novice but I don't make a living with the mill.
I had thought the wood might be abrasive but I didn't have any trouble planing it with my non-carbide planer knives.
I literaly pulled a brand new hardwood blade from the box and tried to cut a piece this morning.  It went about 8" before it started to smoke and stopped cutting.
The only thing I can think of is that the combination of dry/hard/slightly abrasive is dulling the blades?
I thought about emailing Cook Woods in Oregon.  They are close by and I've purchased tropical wood from them.  I know they operate at least one Woodmizer.
Pitch
Quote from: mesquite buckeye on January 09, 2013, 03:39:33 PM
That's the first thing I thought of when I tried cutting the first piece.  I put a wedge in there and it made no difference.  This second piece didn't close at all.  Good suggestion though.
Bogue Chitto
Are you using blades from the same box every time this happens?  I had a problem with my blades diving and heating up.  Spent lots of time trying to adjust a mill that did not need adjusting.  Turned out it was a brand new box of blades that were set wrong.
Pitch
Quote from: Bogue Chitto on January 09, 2013, 03:52:50 PM
I've tried:
softwood blades
combo Timberwolf blade
hardwood blade
I thought maybe if I cranked up the water on the mill it would keep the blade cooler.  However, sometimes the mill sits for a month and so I prefer do use diesel/kerosene.
POSTON WIDEHEAD
I have to give you credit Pitch and a pat on the back.....when you ask a question, you make it a good one.  smiley_thumbsup  :D
Pitch
Hopefully this will save somebody else a lot of time and money.  I can't be the only knucklehead out there trying to saw through a dry chunk of unidentified tropical wood.
POSTON WIDEHEAD
Where you from Pitch? What kind of mill do you have?
Pitch
I'm from Northwest Washington State near Allyn, WA.  I bought my Woodmizer LT40 Manual mill in 2007.  I run heavy earthmoving equipment in the summer and I build furniture in the winter.
Pitch
You said
QuoteThe only thing I can think of is that the combination of dry/hard/slightly abrasive is dulling the blades?
Have you looked at the blades to confirm that they are indeed dull? i.e. no sharp points on the teeth?
Pitch
Quote from: beenthere on January 09, 2013, 04:10:59 PM
Pitch
Yes, I think I ruined one of the softwood blades.  I let the hardwood blade cool and tried cutting again to no avail.  I'd say it is dull.
learner
This may not help but when I get a lot of build up on the blade, I run the lube-mizer on continuos stream a few cuts.  Have you tried that to keep the blade cool?  Excessive heat will cause the blade teeth to weaken and the tension to change.  A good Old carpenters trick to make it easier sawing wood with a hand saw, or putting screws into hard wood, is to use bar soap.  Not sure how you could do that with a band mill but you might try using a milk jug full of REALLY soapy water hooked up to the lube system.
WoodMizer LT40 Super Hydraulic, MF-300 FEL, Nissan Enduro 60 forklift, 2 Monkey Wards Power Kraft Radial arm saws, Rockwell series 22-200 planer, Prentiss 210 loader
shelbycharger400
have you thought about getting a roll of plastic sheeting, a few boards and make a trough and soaking that board ?
generally its not recomended to resaw thickness wise due to tension set.
Pitch
Quote from: shelbycharger400 on January 09, 2013, 04:58:09 PM
I've thought about using water unfortunately this piece is designed to go into a desk that I'm currently working on.  The stock is mostly quartersawn and the stuff I've split in the woodshop has come out okay so far.
terrifictimbersllc
Hardest wood I've sawn yet was 24" wide planks of bigleaf maple heartwood, kept inside a dry shop for about 10 years.   I was re-sawing them into 2-3 boards for an instrument maker.  Best result was with a new 4 degree WM doublehard, with water on full to keep the tension up (LT40, lube-mizer). I looked at the tension gauge and went faster or slower whatever kept it from dropping.   Still had some wave but all boards were useful.   The only other option I would imagine might work would be Stellite (I haven't tried it).
harrymontana
good to read this post, once we were 'trying' to cut some unknown tropical hardwood logs and had the same problem. These are the possible causes:
for cutting hardwood (we only cut hardwood such as brazilian walnut etc) as we are located in Bolivia, the angle of the teeth of the blade is very important. This is not only the angle of which the teeth is i a U shape or V shape looking from the top side, but also howmuch curve goes into the teeth itself.
Then there is a hardwood such as garapa which has a very nasty glue and after 2 or 3 logs regular sawing blades get stuck and brake. For this wood you need to put some special teeth on you blade. All very expensive and time inefficient, that is why quite some hardwood mills don't like to saw this kind of wood.
Furthermore, we always cool the blade with spraying water constantly on the blade
everything on hardwood
LeeB
I wondeer if going to a lessertooth spacingwould help such as mayby 3/4 or 5/8. Something like would be found in a resaw type blade.
