Water going into the oil on Cat518
Started by logloper, January 08, 2013, 11:45:17 PM
logloper
My 518 has been sitting for a bit now, been using another skidder. Decided to start running two skidders, so we hauled the 518 up to the job today. When we parked it a few months ago, it was working great. Now in 15-20 minutes it sucks the water out of the radiator into the  oil. Like all of the coolant. It starts blowing out the blowby tube and going everywhere. Anyone have any ideas?
sawguy21
Did it freeze up? At the very least you have a blown head gasket, worst case scenario a cracked head or liner.
Migal
My thought's exactly but I didn't want to be the bearer of bad new's Overhaul was my thought's Sorry. GL and have a  :new_year:
Stihl learning and picked up my Log Master LM2 Cat 34hp 02 21 12! 230MF+ the toys that go with it! MS361 MS271 Stihl PB500 Echo 48" LogRite 16ft Bass Tracker Pro' Abua Garcia 5600 bait caster, Wood working equipment' Lake Lot never enough time! oh don't forget the fridge with ale! Loving Wife Rebeca
Bandmill Bandit
Tear down time!
That is a very bad "leak" and if there was anti freeze in it when it sucked dry over a 20 minute time frame, I am guessing there will be crank damage. I am gona guess a cracked sleeve or head.
just did a quick search on Cat forums tech site. That should be a 3304. Apparently they are known to have an O ring issue on the bottom of the sleeves as the hours get up there FYI. you might be lucky IF you dont run it any more till its fixed. Hope thats what yours may be.
Sorry to hear cause I am sure you need it running. Good luck on the rebuild.
loggah
Make sure and check the oil cooler also ,another place water can get into the oil.those old 518's are pretty tough a guy that used to work with me had over 40,000 hours on his.   Don
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
JDeere
As said, you will probably have to tear it down. My guess is the o-rings for the cylinder sleeves. Allowing a machine to sit for extended periods of time can cause more wear & tear than using them. The o-rings can dry out and then crack.
2013 Western Star, 2012 Pelletier trailer, Serco 7500 crane, 2007 Volvo EC 140, 2009 John Deere 6115D, 2002 Cat 938G, 1997 John Deere 540G, 1996 Cat D-3C, 1995 Cat 416B, 2013 Cat 305.5E
snowstorm
lynde37avery
518 cat = best skidder in my opinion. well worth a fix on that and keep it.
Detroit WHAT?
logloper
Thanks for the replys. I have been told the oil cooler also. What do I check on it?
Bandmill Bandit
A friend of mine that looks after a wack of irrigation pump sets says there was an up grade made available to the gasket set for the 3300 series Cat based staionary power engines in about 83 that put in a much better tefflon based O ring. Says he has quite few of 3306s and a few 3304s that he has rebuilt approaching the 20,000 hour mark since last rebuild pushing water at 600 to 1500 plus gallons a minute that have not developed a sleeve leak since last rebuild that included the new gasket and seal kit. He says some of these engines are on rebuild cycle number 4 and are close to 100,000 total hours pumping water. Says that dollar for dollar it is one of the most reliable engines he works with in the irrigation pump power plants and cummins is about the same but a slight bit more expensive on the rebuild.
loggah
The 3304 engines are not super expensive to rebuild, the convertor and transmission are something else !!!!! Don
GRANITEstateMP
We just had a similar problem on our CAT 930 loader, I think it's also a 3304 engine (1970 machine).  Tear down showed that when the head gasket got done this summer they should have done O-rings too (the head cracked when Wifey lost a heater hose and kept pushin' corn - opps!)
The fellow that put it back together the second time (should have gone to him first!) said that he did o-rings and kept it cheap (we really needed cheap) and to keep our fingers crossed.  Still going 2 months later!
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
SureTrac 12ft Dump Trailer
logloper
We finaly shut down logging for spring break-up, so I tore into the 518  today. Took off the oil pan and was going to pressure up the radiator to see where the water was comeing from. As I poured water into the radiator, it started pouring out the bottom of motor. Checked it out, and it was comeing from water pump. The seals went out around the drive shaft. Looks like a new pump will fix it. Big relief.
Migal
Congrat's that is a big relief for ya!
