Shed Lumber
Started by Slab Slicer, January 03, 2013, 09:12:07 PM
Slab Slicer
Finally got the what I think will be all the lumber I need for the shed I'm planning for this spring. I'm sure I'll need some more 4/4 for the siding, or the roof decking, but I have 2 more logs on standby for that. 99% is Norway Spruce, with some white pine mixed in. The spruce presented a challenge with the dense knots, but it was a learning experience. Here's one of the larger spruce logs that were milled.
Color coded to help ID after milling
Made this pic my avatar. 4/4 to the rear (random width for now), and full dimension 2x4's, and 2x8's in the front.
And here's what I use to move the logs around the property. A kubota BX 1500. Not a big machine by any stretch of the imagination, but it's doing the job so far. Well, on most of the logs anyway. It sure wouldn't hurt to have a bigger machine.
2016 LT35HDG25, Kubota L2501 w/ FEL, Kubota BX1500 w/FEL and custom skidding rig, Stihl MS 500i, Stihl MS362-25", Stihl MS250-20", Stihl MS192-18",  2001 F250 SD 7.3, GMC Sierra Dually 6.0 gasser, Peaqua 16" 10K trailer, Sur-Trac 12' Dump Trailer 10K
Chuck
Slab Slicer
You should be rewarded well with some good straight lumber given that careful job of stacking and aligning stickers. Maybe some weight and some covers will add to the yield too.
Slab Slicer
All stacks are covered now, and I'm looking for something to weigh it down. Any suggestions? How about some scrap slab first cuts that are stacked just out of the picture?
Chuck
I stack the low grade on the top to help with the weight.  The best stuff always goes on the bottom.  It works out pretty good.
Dakota
I keep a bunch of cinder blocks around for weights.  They are cheap and you can use them for all kinds of things.
Dave Rinker
uplander
 Do you have Carpenter Bees where you live?
Uplander
Woodmizer lt40G28.  A kubota L4600 with loader and forks.
Various Stihl saws and not enough time to use them!
Finished my house finally. Completely sawn out on by band mill. It took me 7 years but was worth it. Hardest thing I have ever done.
Slab Slicer
Quote from: uplander on January 04, 2013, 02:42:34 PM
Uplander
Yes we do. Not this time of year of course, but they do show up. Once I find them in some piece of wood on the house, I spray a little brake cleaner in the hole, and they usually don't come out, and others won't bother with that hole afterwards.
I've got some cinder blocks I can use, but not many. I do have a bunch of the waste cuts that I can throw on top of the tarp that's covering the lumber. Let's hope that does the job.
Chuck
SAWMILL BUDDY
Nice stack of lumber. Cut an old log in half and set them on top. That will hold it down. ;D
black spruce
Good evening slab slicer for softwood I put one 3x3 on top of the load center to the sticker line the total width of the batten has to be 1-3 shorter than the stack width then I strap them with polyester strapping at very tension this bring a big amount of downward force to the row and greatly contribute to reduce the grade loss in the stack then I put a cover like steel roofing the overhang couple inch....
The polyester strapping has a memory that will contract and keep a tension even when your wood shrink....
Great stacking so far good luck with your project
Sebastien
PC-Urban-Sawyer
Quote from: Slab Slicer on January 04, 2013, 06:31:18 PM
... that I can throw on top of the tarp that's covering the lumber.
You'd be better off using old roofing tin to cover your stacks. Tarps tend to capture the moisture and lead to problems with fungus and mold growing on the lumber...
Nice looking stacks of nice looking lumber. Be a shame to mess it up at this point.
Herb
Slab Slicer
Even if the tarp isn't wrapped tight on the lumber? I leave room for air to get into the stack. With only roofing to cover the top, wouldn't that allow rain to blow in from the sides, keeping the lumber from drying? Just trying to understand.
Chuck
I myself hate tarps as a long term protection. I use one to cover my wood pile by the OWB,but remove it when no snow in sight. And with a tarp once the dampness gets in,it can't get back out.
drobertson
Someone mentioned low grade on top, think it was WDH, this is the best for me, the top most often takes the abuse, I do the same, then put slabs on top when I have to for weight. Your stacks look great, and you may not have that much low grade, so use the slabs bark up, cover with two or three layers, covering the gaps,
doctorb
I find that if I don't tie any terpene down tight, I find it elsewhere after some wind.
drobertson
You got that right doc, you can figure they make sails from these things for a reason.
talldog
Don't worry about rain blowing in at the sides. Those sides are very important for wind to blow through. If you use a tarp on top,don't have it hang over the sides much.Just enough to fasten it.
