Next tree's in my sights..... Shag bark Hickory.....
Started by shelby78, January 02, 2013, 09:17:59 PM
shelby78
Doing a bit of a walkabout at the property today after skidding some more oak out i saw something in the distance.  There are lots of smaller (8-12 inch) cherry and shagbarks but i haven't seen any bigger ones.
The spot is a place i never walk thru (no trails) so i never knew i had some 20 inch shagbarks to play with. I think some poeple call these pecans also (not sure).
How does this stuff mill (Like i won't find out myself very soon). Should i do my standard half 1's half '2s or do you guys suggest a better idea? These would be crazy to do live edge but i think the bark would get ripped off to easy :(
There are 2 different tree's and i think i saw more of them further back. I may have to check the other side of the swamp to see whats over there :)
Don't think shagbark hickory are pecans. Yours look 'shagbark' for sure.
And they look slow grown and mean.  ;D
drobertson
Regardless, difficult cutting, and the logging looks pretty rough too. get'r done,
dgdrls
I believe this has been used to describe Hickory smiley_devil
Saw as soon as you drop it, and be ready for some tension in those logs.
DGDrls
shelby78
I know the tree is a shagbark but i threw the extra term in because i read it today on another site. Some poeple seem to have extra names or mix match stuff like i found in the quotes below...... I have found different regions call stuff differently or have slang terms  like , Manitoba maple which is box alder.
I though it may help someone else relate to what it was if they had sawn it before. I was also curious if anyone actually calls it pecan?
Forum Responses
(Architectural Woodworking Forum)
From contributor F:
I could be wrong, but I think they are the same. Called "hickory" by some and "pecan" by others.
From contributor J:
As far as I know, they do not separate hickory and pecan at the mills. It will end up being a mix. Sometimes our lumber supplier will call the longer stuff hickory and the shorter pecan, but it is just to differentiate between the two lengths.
From contributor E:
They both fall into the same species, but pecan is usually lighter in color with less variance from heart to sapwood. Beware that even hickory has different subspecies, such as shagbark or pignut. True shagbark hickory has a dark heartwood and light sapwood, pignut is very light even in the heartwood, sometimes pignut is referred to as pecan.
From Gene Wengert, Sawing and Drying Forum technical advisor:
In the lumber trade, we seldom separate hickory and pecan; if separated, they are called true hickory and pecan hickory. They are in the same genus, just different species. They are almost always sold as one. The fact is that there are 4 species of true hickory (pignut, shellbark, shagbark and mockernut) and 4 species of pecan hickory (water, bitternut, pecan and nutmeg).
Sometimes the color of pecan is not the same as hickory, but this can often be due to drying differences in veneer dryers or lumber kilns. The true hickory is a little stronger than pecan hickory.
QuoteI know the tree is a shagbark but i threw the extra term in because i read it today on another site
Pecan isn't an extra term for shagbark, it is a different hickory being referenced. Such that when the two woods are marketed, they may lump both together.
I got 2 of them on my land,both growing out of the same stump.
dgdrls
Some of the first material I cut was Hickory,  tough stuff, but pretty..
DGDrls
Al_Smith
I suppose I have several thousand board feet of shag still in logs in my pile .One that was tripped a year ago was 3 feet on the stump and had about 1500 bd ft in the logs which is larger than normal .I could count over 230 growth rings .
Something is killing the big shagbarks off ,don't now exactly what it is ,ants maybe . Where talking most upwards of 100 feet and 60 or more to the first limb ,straight as an arrow .
I've planed a few planks from previously milled logs and some resemble pecan in grain form and color .I think or have been told that a hickory is more closely related to a wallnut than a pecan though but again I'm not as well versed as some on this forum .Whatever it is one things for certain ,it's hard .
John Bartley
Quote from: shelby78 on January 02, 2013, 09:53:53 PM
I think that's supposed to be Box Elder.
cheers
John
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
Tree Feller
Quote from: John Bartley on January 03, 2013, 08:42:40 AM
cheers
John
Actually, it's Boxelder...one word.
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
GAB
In this part of VT the push is on to save as many Shaggies as possible as they give the endangered bats a place to roost in the daytime.
Also, every Shaggie I have cut to date: the butt log has been hollow, and I was not impressed with the quality of the lumber.
To make matters worst if you saw them when it is warm they smell like horse manure until they dry out.
I must admit that they make a great winter fire.
Wish you better luck than I've had with shaggies.
Gerald
hackberry jake
Watch out for the bark, I haven't cut many that haven't brought blood. The chainsaw will bounce two or three times before it actually gets through the bark and into the meat. Watch out for stress in the logs and use plenty of set on your bands.
clww
From what I've read here, tough milling. smiley_devil The #1 best firewood to burn, though. :new_year:
Many Stihl Saws-16"-60"
18-Wheeler Driver
No Shag Bark Hickory here, but whenever I get Hickory in my sights, I miss.   ;D
Al_Smith
I'll tell you what there certainly is a lot of hoopla about that danged bat and shag barks .I'll bet if there where no more shags in the world that bat would be bright enough to survive .
Bats are bats they've been around forever and don't need ding bats protecting them .Good Lawd next thing you know they'll be putting mosquitoes on the endangered species list so as not to starve the bats .In this day and age nothing would surprise me .
francismilker
Quote from: Magicman on January 03, 2013, 11:52:13 AM
lol!   It's some awesome looking grained wood but I'd hate to be on it for a whole day.  I recently posted a question about cutting a lot of hickory and have just gotten started on a pile of logs.  It's about as slow and tedious as I have came across yet but I'm gonna keep it up until at least this pile is sawed.
"whatsoever thy hands finds to do; do it with thy might" Ecc. 9:10
WM LT-10supergo, MF-271 w/FEL, Honda 500 Foreman, Husq 550, Stihl 026, and lots of baling wire!
You are absolutely correct.  It does produce some stunning lumber, and my remark was not intended to discourage anyone from sawing Hickory.  I will saw Hickory again, it just is not in my plans.   ;D
jcbrotz
I love sawing hickory :o but only if it has gone from making oxygen to board form in less than a day. If you want the  smiley_devil just let ONE set for awhile for you to try out after a week or so and then you can make yourself some smoking wood. :D
2004 woodmizer lt40hd 33hp kubota, Cat 262B skidsteer and way to many tractors to list. www.Brotzmanswoodworks.com and www.Brotzmanscenturyfarm.com
John Bartley
Quote from: Tree Feller on January 03, 2013, 08:49:39 AM
cheers
John
Either or, but different from alder  ;)
Stihl MS361
Stihl 026
shelby78
Thanks for all the info guys. I now have mixed feelings about milling it. I will make sure to have everything set-up so i can do it all in one day. You know i will post pics also.
Slab Slicer
This is not good news for me then. I felled 2 large bitternut hickory back in august. I have  a feeling I'll be sawing some pretty hard wood when I get to them. Any suggestions on blades that will work well?
2016 LT35HDG25, Kubota L2501 w/ FEL, Kubota BX1500 w/FEL and custom skidding rig, Stihl MS 500i, Stihl MS362-25", Stihl MS250-20", Stihl MS192-18",  2001 F250 SD 7.3, GMC Sierra Dually 6.0 gasser, Peaqua 16" 10K trailer, Sur-Trac 12' Dump Trailer 10K
Chuck
LeeB
Hickory gets harder as it dries for sure. Cut a couple of inches off the end of the logs if they have sat for a while. Your blades will thank you.
Slab Slicer
Will it make a difference if thse logs were sealed with anchor seal 2? That should keep them from drying fast. At least the ends anyway.
Chuck
Quote from: Al_Smith on January 03, 2013, 08:26:33 AM
Al,
Actually, pecan is a hickory.  There are two groupings in the hickory genus, Carya.  The True Hickories which contains the shagbarks, and the more common mockernut and pignut hickories.  The other group is the Pecan Hickories which contains pecan hickory, bitternut hickory, and water hickory.
The last time that I sawed a dried out hickory log, I swore that it would be the last one.  So far, it has been  :).
Slab,
Sealing the ends should help.
