Not too bad for old folks.
Started by Bibbyman, December 21, 2012, 10:15:12 AM
Bibbyman
Mary made the run to West Plains with a load of flooring lumber (1800 bf) on Monday.  We wanted to get another load ran this week.  The buyer is closed on Monday and Tuesday of next week and we have plans pending for the rest of Christmas week.   So Tuesday morning I loaded the deck with 9' red oak logs.  We didn't get a crack of dawn start and didn't start making lumber until about 9:00.  We took a quick lunch break and got back to work before we stiffened up.   By 2:00 we had made 21 ties and had our bundle of 900 bf of 4/4 flooring lumber – almost 1900 bf of sawing.
After a coffee break,  I went back out and loaded the deck with 11' red oak logs and staged some plump 10' logs to load on later.  I also pulled the blade and put on a sharp one. The weather prediction for Wednesday afternoon was trending bad with Thursday just awful.
Wednesday morning, having set up the afternoon before, we got a quick start with first slab pulled at 8:05.  At 11:15 Mary was throwing the bands around 900 bf of flooring lumber.  We'd produced 16 10' and 11' 6x8 beams - for over 1500 bf in three hours of sawing.
Looks like we were sawing about 500 bf/hour.  One could say there is a bit of cheating in the numbers by including the board feet in the ties and beams.  But once the log is down to a cant,  it wouldn't take too much longer to break it on down to lumber.
It's a good thing we jumped in and got-it-done as the weather did turn just awful on Thursday.  It was not a fit day out for man nor beast.  The wind was hitting 40mph sustained and gusting higher with blowing snow.
Mary's off to West Plains with the load right now.  I'm just getting some things ready for Christmas shutdown.
One side note,  sometimes you just get a blade that cuts and cuts and keeps on cutting. We sawed all morning on the one blade.  It cut super well right up to the last log and still cut true but I had to slow down.  I would have changed it but we were all but done.  It was a blade I'd sharpened about 5 times,  I'm guessing.
Sawing since '94
Ga Mtn Man
There's a good reason she's called "Pro-sawyer". 8)  My complements to your blade-sharpening guy. ;)
drobertson
Awsome work bibby! and yesterday was brutal! yall have a Merry Christmas !  Oh yea, I have had blades work like that as well, they are cutting so good, you just hate to take them off,   david
Good to hear you can still getRdun.
Many members here know what work you had to do.
:christmas:
WmFritz
I need a nap after reading Bibbymans post.   zzzz_smiley
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
OneWithWood
You and Mary rock !
Yesterday was brutal with up to 50mph gusts blowing through the barn.  I only got 550 bf of cherry and ash sawn before I threw in the towel (which promptly got wrapped around the mill )
One With Wood
Bibby, you were and still are an inspiration to me.  There is a lot of pride that goes into keeping on keeping on.  Even for old ole folks.   whiteflag_smiley   Throwing in the towel is not an option....yet.   ;D
Chuck White
Good job Bibby & Mary!  :christmas:
hackberry jake
Now that's keeping the blade in the wood! I have a feeling I would learn a thing or two if I were a fly on the wall at your mill for a day. If I put out around 600bf a day my back lets me know about it for the next three.
Bibbyman
Quote from: thecfarm on December 21, 2012, 03:08:20 PM
You 2 still have it.  ;D
We still have it but not as much off it.  Seems like we go so long then hit a wall and have to stop.  We've had days, even this year, where we've sawn more in one day.  Wasn't that long ago we would run about all day and produce a good bit more.  2500 bf wasn't that uncommon - day after day.  But now one hard day has to be followed by a softer day to recoup.
Sawing since '94
Bibbyman
I guess everyone gets blades that perform better than others and blades out of the same batch that tend to not do so well.  What I don't do is segregate the good from the not so good and then go back and try to figure out why one does better than another.
Well,  I did hang this "good" blade on another nail.  Tuesday we'd used three blades.  One had time on it when we started so we really used two and a bit blades to saw the same amount of footage of flooring lumber as the one blade did on Wednesday.
The "good" blade measured .910 from back of blade to bottom of gullet.   The others were wider.  Two by only a little and the widest at .940.
The set on the "good" blade was about .018 with some teeth a little less and some a little more.  The set averaged the same from side to side. This was after use.  Two of the other three had about the same set.   The wider blade had a little more set at about .020.  Again, this was after they were used.   I try to set about .022.  If I'm getting .020-.024,  I'll go with that.
The logs were all red oak with a mixture of fresh, standing dead, and a few with a couple months age.   Many of the logs were pretty clean but some had mud packed on them.  We cleaned the dried dirt off the ends of several before sawing.   About "run of the mill" sawlogs.
All the blades were Wood-Mizer DoubleHard .045x1.25 by 7 sharpened several times on the CBN sharpener.
I don't know if I learned anything.   I can see no defects in any of the blades.  Sometimes I have found a twist in a blade.  I sometimes have blades that have been yanked off on return and are warped and I've attempted to straighten.   Sometimes the blade just hits something right off the bat that you didn't see.
Sawing since '94
Peter Drouin
Thats a great job you did :christmas:
A&P saw Mill LLC.
License NH softwood grader.
hackberry jake
I think some of it might be how straight the two ends get welded together as well. And theres some things we just can't see, like heat treatment differences.
Tree Feller
Quote from: hackberry jake on December 21, 2012, 06:52:25 PM
I don't know diddly about band blades but that was my first thought...the heat treatment was just right on that particular band.
Bibby, I always enjoy reading about the sawing you and Mary do. It's always informative and entertaining, too. Mark one down for the old farts club!   :laugh:
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
Ohio_Bill
Wow Bibbyman and Mary , Congratulations.  At that rate if you only sawed 20 hrs per week it would be over a half a million feet a year.  You all have done a great job of maximizing your material handling efficiency. I see you are sawing ties again. I was wondering if you will be hauling them or will they be picked up by the buyer.
Have a wonderful Christmas.
Bill
:christmas:
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor – Loader ,Bob Cat 763 , Riehl Steel Edger
paul case
Not bad indeed. You and Mary must work well together.
I just love it when a plan comes together. Nice work.
PC
pc
Bibbs,I've noticed the same thing with some bands going above and beyond.I think most likely they led a charmed life and didn't hit unseen grit.Love red oak I can take a band that dives and rises in pine and it will cut perfect in oak,only complaint its so DanGed heavy. Frank C.
Bibbyman
Quote from: paul case on December 21, 2012, 07:31:59 PM
PC
I'd like to say we work together like Fred Astaire and Ginger Rogers dance.  But in real life we're more like Fred and Wilma Flintstone.   I get "the look" about a hundred times a day – when I make a slab too heavy or not a wide enough face or when I make a misscut or leave a toe board up or let a flitch come off wrong and about hit her.  Well,  about everything I do comes under her critical review and judgment.
Sawing since '94
Lud
I know that "look" as I'm on the receiving end of plenty of them from La Boss......but the smiles and hugs and kisses balance them out.
Youare right to be proud of your teamwork and productivity.  Kudos and  :christmas:
paul case
Quote from: Bibbyman on December 21, 2012, 10:15:13 PM
PC
I’d like to say we work together like Fred Astaire and Ginger Rogers dance.  But in real life we’re more like Fred and Wilma Flintstone.   I get “the look” about a hundred times a day – when I make a slab too heavy or not a wide enough face or when I make a misscut or leave a toe board up or let a flitch come off wrong and about hit her.  Well,  about everything I do comes under her critical review and judgment.
Sounds like you need a hug!  I dont get the look often and when I do i cherish those moments.
It seems like she could get a lot more done if you werent causing her to have to give you the look all the time. Take some well deserved time off for Christmas week.
I envy you  by the way. I wish I had a market that would buy all I could saw. PC
pc
