Cherry chest build
Started by pineywoods, December 15, 2012, 08:53:11 PM
pineywoods
This is a "daddy-do" project for my daughter. She calls and says "Pop, I need a special chest. Only thing I can find is over $400. Could you make me one if I sent a Picture ?" I raided my stash of air dried cherry. (Does this make me a board hoarder ?). Glued up some wide panels using biscuits and tite bond glue, to make a big wooden box. First pic is dry fit before glueing.
This pic is a pineywoods exclusive. How to make sure the top fits. Just don't forget where the screws are.
Trim attached, first coat of stain (minwax poly) applied,awaiting second coat and wrought iron handles.
SAWMILL BUDDY
jamesamd
Piney Your the Man.
Swwwwwwet.
Jim
All that is gold does not glitter,not all those that wander are lost.....
Tree Feller
Love the way you separated the top from the chest.  :)
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
Okrafarmer
Looks like some good old Louisiana artistry-- and engineering-- at work!
Now selling Logrite tools!
Never cut a lid off like that.  Hmmmmm.....
isawlogs
 When I first saw the pic a thought of how deep the chest was....  You sure took care of the depth issue for me when you sawed the top from the chest.  :D :D
Nice, I am certain she will be all over you with hugs.  8)
   Marcel
POSTON WIDEHEAD
Quote from: WDH on December 16, 2012, 07:59:56 AM
There's more than 1 way to skin a cat.  ;D
T Welsh
pineywoods, YES, you may be a hoarder if you stash wood! (sounds like a Jeff Foxworthy joke). I like the way you cut the top off! Work well doesn't it! Tim
Okrafarmer
Quote from: T Welsh on December 16, 2012, 09:37:42 AM
As long as you have your blade tension and alignment and everything all worked out. Would hate to have it dip! (That would never happen, now would it?  :o )
Tree Feller
Any major tearout on the exit side when cutting off the lid?
Cody
Kioti CK 30 w/ FEL
pineywoods
To answer a few questions...The sawn-off top is my way of compensating for my lack of woodworking skill, which is not exactly WDH level.  ;D Hey, it works. I use the same technique to get all the legs on a table or stool the same length, just mount it on the mill upside down. No tearout on the exit side, BUT it's best to mount the box at a slight angle so the exit is gradual. Saw SLOWLY. Don't forget where any screws or nails are. The sawn off edges will need a little dressing with a belt sander. The finish is minwax dark walnut poly..Why walnut on nice cherry boards ? Cause that's what the daughter wanted. Didn't have enough walnut lumber hoarded back, got plenty of cherry, sooo...The dimensions are a bit weird, but that's what she wanted..To be delivered the day before Christmas..Ho Ho Ho..
Okrafarmer
That's what a good engineer does, he makes things work!
Planman1954
Norwood Lumbermate 2000 / Solar Dry Kiln /1943 Ford 9n tractor
Lud
A nice chest and a sharp way to take off the top.   Were you able to solve the puzzle of a continuing snug fit from lid to chest?
I'm sure she'll be ecstatic!! 8)
pineywoods
Quote from: Okrafarmer on December 16, 2012, 11:28:45 AM
No dip, climb or dive, but it wouldn't matter if it did, the lid would still fit perfectly. Come to think about it, that might be a new way for an unusual custom feature...
Piston
Great looking chest!  I like the stain you chose as well.
Quote from: pineywoods on December 19, 2012, 11:35:39 AM
That is a really neat idea, I imagine everyone who looked at the chest would have to think "how on earth did he get that top to fit so perfectly"   ;)
-Matt
"What the Lion is to the Cat the Mastiff is to the Dog, the noblest of the family; he stands alone, and all others sink before him. His courage does not exceed his temper and generosity, and in attachment he equals the kindest of his race."
Okrafarmer
And then everybody would be wanting one!
There was a man from Kalamazoo,
Who found a mouse cooked in his stew.
Said the waiter, "Don't shout,
And wave it about,
Or the others will be wanting one too!"
Oops, turned this thread to food.  :-X
Norm
haywire woodlot
I've done that on a smaller scale on the table saw to open up small boxes, using the mill is a fine way to go, you could clamp a board to the backside, where the blade exits to to prevent any tear out.
Dave
pineywoods
Here's the finished job in it's final resting place.. But there's another problem. DIL saw it and now she wants one. I should have paid more attention to WDH. Not only about how to build, but he could have warned me that when 2 daughters are involved, plan on building 2  ;D
Planman1954
Looks great! Now....get to work! 8)
Slab Slicer
Nice work Piney. Where did you come up with that much cherry. I can't seem to find any good cherry around here. I'm always looking though.
2016 LT35HDG25, Kubota L2501 w/ FEL, Kubota BX1500 w/FEL and custom skidding rig, Stihl MS 500i, Stihl MS362-25", Stihl MS250-20", Stihl MS192-18",  2001 F250 SD 7.3, GMC Sierra Dually 6.0 gasser, Peaqua 16" 10K trailer, Sur-Trac 12' Dump Trailer 10K
Chuck
Piston
That looks beautiful!  Great Job  8)
-Matt
Quote from: pineywoods on January 02, 2013, 08:36:10 PM
Piney, I have THREE daughers  :'( :'( :'(.  I did get past having to build three chests, but there is more and more furniture that they need.  Why am I feeling so tired?   :).
I am interested in your chest top detail.  Say more, there is some interesting features that I can see from the pic.
