popular end splitting
Started by slider, December 11, 2012, 07:19:48 AM
slider
  I thought this splitting was caused when the tree was drying but these logs were just cut when i took the pictures.Any thoughts.
al glenn
Jemclimber
I see it a lot, and not just with poplar, could be stress released from cutting or possibly from the impact when felled.
lt15
My first thoughts were that is normal for Poplar, but since it had just been felled, I would agree with Jemclimber's response above.
I think that it is tension in the log, too.
rooster 58
I've seen this happen with soft maple as well. I'm not sure if it was stress or my bucking techniques
Tree could of been felled over a sight knoll,rock or even another stump and gave it a good whip. I've done that a few times.  ::) I kinda doubt that was a drying crack that quick.
Chuck White
I saw quite a bit of Poplar and I see the end-checking a lot.
Most of the logs will have check ranging from "barely noticable to deep", so it's not unusual.
Fairly popular for yellow poplar to have growth stresses (tension in the outer growth layers).
Here is a pdf published by Dan Cassens that could help explain the dilema of growth stresses and how they show up when dropping a tree and when breaking a log down into parts.
http://www.fs.fed.us/ne/newtown_square/publications/technical_reports/pdfs/2004/316papers/Cassens1GTR316.pdf
slider
I didn't drop them but i don't think it's from falling.These creek bottoms are soft here.I have also seen it before,just curious .
al glenn
GeneWengert-WoodDoc
Definitely growth stress.  There is no prevention treatment.  It will cause warp in drying and splitting.  Oftentimes, a small amount of drying creates enough additional stress to make checks even larger.  Article coming about this in Sawmill and Woodlot magazine.  We see this in many species, including yp, walnut, hickory, alder, pecan, eucalypts.
customsawyer
I agree that it looks like growth stress.
www.thecustomsawyer.com
So I take it that was milled,you could just about see it move on the mill? Probably not that bad. But I suppose drying in a stack it would move alot?
slider
Thecfarm,the last popular i sawed came in split the same as this.Some movement on the mill but not much.As for drying ,the top boards twisted some but the rest were fine.Now i try to cut them a bit long to get past the split in the finished boards.What's strange is these trees were strait .You wouldn't think they had stress.
al glenn
QuoteWhat's strange is these trees were strait .You wouldn't think they had stress
The link'd article by Cassens helps explain that. ;)
customsawyer
They might be strait but the pith is off center.
John Bartley
Quote from: customsawyer on December 12, 2012, 07:17:56 PM
That's what I thought too, but when I look closely, I think that the pith is at the centre, right where the cracks join, and the dark spot where the pith "looks" to be is really a branch knot.
whuddya think?
John
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
GeneWengert-WoodDoc
Compression wood results in the pith being off center.  Tension wood also but not all the time.  Growth stress does not have that effect.
