How Much Fuel per Day
Started by Magicman, December 05, 2012, 09:18:12 AM
Reading the "diesel upgrade" thread, made me wonder just how much fuel do we use in a day's sawing?  I crank the 40 hp Lombardini in the morning and only shut it down for lunch.  I disengage the clutch after each cut and am at idle on the return.  I have never added fuel to the 5 gallon tank during a day's sawing, and there is usually about ½-¾ gallon left in my fillup can.  Obviously, I have never run out.
How does this compare with other Diesels and with gassers.
drobertson
I am running the 04'-05' 51hp Cat, and only once did I get close to 5 gallons in a day. I disengage the motor as well when returning unless of course I am making several boards in a row before turning.  I do shut the mill down when stacking, loading, or anything else that will take a few minutes or more.  Not sure why, just like the quite I guess.  Its hard to figure how much fuel per bd.ft because cutting ties will make more footage with fewer cuts than sawing 1" boards straight through the log.  One time I did figure the cost on a particular job and If I figured it right it was under 2 cents a bd/ft.
dboyt
I can cut 1,000 bd ft and still have a little fuel left in the 4 gal tank.  Running a manual mill, 23 h.p. Briggs & Scrapiron.
Alyeska Pete
I run a 51hp Perkins (which some manufactures re-lable as a Cat) on a Cook AC 36D and burn almost exactly 1/2 gal an hour for an 8 hour day. I usually saw alone (one sure sign of an addict). It runs all day except for lunch and I do idle it down when I return the head. I also idle it down while I'm moving material in or out of mill. I never disengage the engine clutch except lunch and quitting time. Also never de-tension the blade except to change it out. It stays tensioned over night and weekends too. I run a mud saw (hydraulic), cut mixed hardwoods and EWP. I usually run a band between 15 and 20 hrs. before it starts to dull. (1 5/8" X 1" X 0.050" Cook SS) I use diesel fuel for lube and on average use 1 gallon per 100 hrs. of sawing.
haywire woodlot
I was looking at my statement from the card lock yesterday, and I came up with these figures.
Over a 5 day period, I cut 5000 bf of 1x fir.
Average about 6 hours per day running time.
Over that time I used 101.27 L of marked mid grade.
Used  5L for chain saw gas, so 96.27L went through the mill in 30 hrs.
96.27L/30hrs= 3.2L per hour?
Or
96.27L/5000bf= 0.019L per bf.
166bf/hr
This is worst case for consumption too, because of cutting 1x material and it was all sort 8' and 10' logs. The per hour figure does seem a little high.
Dave
haywire woodlot
On nov 23, I cut 922bf of 6/4 cedar, average log length was 16'. Blade in the wood by 9, had a coffee and lunch, last log was done at 2 o clock, 5 hours running time.
Used 15L fuel.
15L/5hrs= 3L/hour.
15L/922bf= 0.016L/bf
184.4bf/hour.
This is pretty much ideal conditions for my 1 man operation.
Dave
terrifictimbersllc
My 5 gal tank will run out somewhere around 7.5 engine hours.  Kubota 42hp.
haywire woodlot
My post would be probably more useful, If I had mentioned that I was running a '92 LT 40HD G24, with the 24 hp gas onan.
Dave
Chuck White
I can usually do a 9 hour day (about 6½ engine/mill hours) on a tank of 87 Oct. gas.
I figure somewhere just over 3 quarts of gas/hour!
Hey Aleyeska Pete;  Welcome to the Forstry Forum!
This is a great place to hang out, lots of info here!
SPD748
I'm told by a sawyer that operates a mill similar to mine (handset Frick w/6-71 Detroit Diesel) that I can expect to burn 25 gallons per 8 hour day with average 'idle' time for loading and turning. We'll see :)
-lee
Frick 0 Handset - A continuing project dedicated to my Dad.
410 Deere, 240 Massey... I really need a rough terrain forklift :)
Sawing Since 1-19-2013 @ 3:30 pm
Serving Since 2002
"Some police officers give tickets, some gave all."
redbeard
Probably just under a gallon per hr. It would be less if it wasnt for the 5.5 hp gas briggs that runs the hydraulics. My TK B 20 has the 30 hp kohler its a guzzler.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
hackberry jake
My mill used to have a 13hp Honda. It mightve used 2 gallons in a 6hr day of sawing. My new 20hp Honda v-twin probably uses 3 to 3.5 gallons in a 6hr day. The fuel per board ft is probably about equal though since the 20hp doesn't bog as bad in thick cuts. You boys are harder workers than I am. "8hr day and only shut it off for lunch"? I'll saw for an h or two then go to the house for some sweet tea. Fire it back up an saw for an hr or two then talk with whoever shows up. Fire it back up and saw for an hr or two then shut down do an hr lunch. Then decide if I'm up to sawing anymore or not. If I saw too much it seems like work  8)
haywire woodlot
For ease of comparison, my LT 40's 3L per hour, works out to .8 US gallons per hour. :)
Dave
Ohio_Bill
5 ga per  7 hr  day    LT40 with  D42  Kubota
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor – Loader ,Bob Cat 763 , Riehl Steel Edger
Dave Shepard
When I was edging as I sawed it was about 3 quarts an hour. Not sure now, probably about the same. I also figured about $.017/ft.
Sawdust Lover
38hp Kohler on a 2000 Timberking. 1 gallon per hr. Defitnatly not a hybrid!
mikeb1079
QuoteI can expect to burn 25 gallons per 8 hour day with average 'idle' time for loading and turning.
is that right?  that seems insane.  do detroits really guzzle that much fuel?  how could a man make money burning that much diesel?
homebuilt 16hp mill
barbender
It's all a out the cost per board foot- hopefully if you burn 25 gallons you saw out 5000-6000 bf. That's the same amount per board foot as a.bandmill guy that burns 5 gallons to cut 1000bf, if my math is right ???
haywire woodlot
The rule of thumb for 71 series detroits diesels in continuous load applications, like tugs, generators, mills etc, is 1 gal per hour per cylinder at full rated power. A 671 should burn 6 gal per hour. I think that's based on n-60 injectors, it only goes up from there!
Dave
Don_Papenburg
What is the 53 series rated at in gals. per hour?
xlogger
My 34 hp Kohler is close to one gal per hour on my Tk2000.
steamsawyer
I usually end the day with more fuel than I started with.  :D  ;D
Sometimes when you make that wrong cut and mess up a board,  ::)  :-[  well thats the next one you use for "fuel".... Just sayin.
Alan
J. A. Vance circular sawmill, 52" blade, powered by a 70 HP 9 1/2 x 10 James Leffel portable steam engine.
Inside this tired old mans body is just a little boy that wants to go out and play.
Great minds think alike.....  Does your butt itch too?
Alan Rudd
Steam Punk Extraordinaire.
Just askin..... are you burning wood in that John Deere shown in the pic?    ;D
Gasawyer
My worstfuel usage was 25gal gas in 13hr day sawing white pine total of 6000bdft. With an lt40hdd with 35hp Wisconsin. Most days are 10-15 gal days for 2500-3000 bdft..
Woodmizer LT-40hdd super hyd.,Lucas 618,Lucas 823dsm,Alaskian chainsaw mill 6',many chainsaws large and small,NH L555 skidsteer, Int. TD-9,JD500 backhoe, and International grapple truck.
POSTON WIDEHEAD
Quote from: steamsawyer on December 06, 2012, 04:49:51 PM
Alan
:D :D :D I never really thought of it that way Alan, DanG you make your own fuel.  :D
