FEL? defined?
Started by Ljohnsaw, December 02, 2012, 01:27:51 PM
Ljohnsaw
FEL is probably an acronym for something.  I see lots of talk of using them but I don't really have a clear picture of what they are.  I think they are the hydraulic tongs on the top of a bucket, but not too sure.  Can someone please educate me - pictures would be great as well!
Thanks,
John Sawicky
celliott
I know it as Front End Loader, as on a tractor.
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
Ljohnsaw
Quote from: celliott on December 02, 2012, 01:29:27 PM
Thanks!  Now when I read it, I can picture it, rather than a bunch of question marks floating in space... :D
John Sawicky
Okrafarmer
Quote from: ljohnsaw on December 02, 2012, 02:46:45 PM
You mean like this?
Maybe I should make a FEL-operating smiley!
Now selling Logrite tools!
I was doing something and thought about FEL. I looked in the Forestry Forum Dictionary and there it was. This is under EXTRAS kinda at the top. I forgot about that great wealth of information.
thurlow
Far be it from me to cause trouble, but maybe one of the 'regulars' could ax;  can we have a new forum category........front end loaders?  ;D
Here's to us and those like us; DanG few of us left!
Okrafarmer
Quote from: thurlow on December 02, 2012, 05:07:25 PM
:-X
Ouch, you are causing trouble!
Trouble makers get sent to Disney Land.  ;D
Ljohnsaw
Quote from: thecfarm on December 02, 2012, 05:04:23 PM
Thanks, now I know where the dictionary is located.  I've got lots of reading to do, there is lots of words that I need to look up so I don't pester you guys! :D  I did a search on "FEL" in the general Forum search - but no luck.  Apparently the dictionary is not linked to the search there.
John Sawicky
clww
There are NO bad questions, so don't worry about that.
Many Stihl Saws-16"-60"
18-Wheeler Driver
learner
FEL / Front End Loader
Otherwise known as a sawyers best friend.  Well, mine anyway.
WoodMizer LT40 Super Hydraulic, MF-300 FEL, Nissan Enduro 60 forklift, 2 Monkey Wards Power Kraft Radial arm saws, Rockwell series 22-200 planer, Prentiss 210 loader
Okrafarmer
Learner, from here I can't tell what brand of FEL that is. Is it a Massey Ferguson model 30?
learner
Pretty good call there, it's a MF 300.  Gonna retire the old girl to lighter work when we get the forklift running.  We've had a couple logs the old girl just couldn't move.  Had to use the dozer to get them to the mill.
DRB
Where I work a FEL would be a Free Electron Laser, Just goes to show you most acronyms have many meanings and that is why they can be confusing sometimes.
http://en.wikipedia.org/wiki/Free-electron_laser
Fat Albert at work.
Okrafarmer
Magicman, you and Fat Albert are classics.  ;D In your case, you have a FAL. Fat Albert Loader.
barbender
Or an SGH- Southern Gentleman's Helper ;D
Okrafarmer
Quote from: barbender on December 03, 2012, 09:30:07 AM
No, SGH is SweetGum Hauler, and Magicman would have a conniption if we talked about Sweetgummery on here.
OlJarhead
Hey MM how long are those chains?  Interesting way to load logs onto something.
captain_crunch
My setup is a little different than M_M uses
My bucket has 3 hooks both corners and middle the short chains will hook up to about 12ft for longer ones I have 12 ft chain that I hook in middle and out sides allowing me to go 18ft.
M_M's set up uses one chain to the ring in hook. His hooks are lots heavier than mine I used old PeeVee hooks seem to be strong enough to stand 2910 ford on nose. I have forks also but forks don't work on trailers with sides too well so out come hooks
OlJarhead
learner
Quote from: DRB on December 03, 2012, 12:53:48 AM
Please don't get me started on that.  At one time in my life i was an electronics engineer.
:D Okra I LIKE that!  A SGH.  I've made it my mission in life to change the way people think about our under-loved gummy tree.  On another note.
I like your idea captain.  One long chain for hooking the ends and a shorter center chain for securing the center of the log.  Better grip and a lot more safety.  I'll post pics when i get the idea i have worked out.
1woodguy
    All this time I thought it meant friendly elephant loader
And wondered why no one mentioned using a UEL ( unfriendly elephant loader)
  But then I thought this was the elephant ranching forum
Experience is a rough teacher first you get the test later comes the lesson!
Quote from: OlJarhead on December 03, 2012, 11:09:19 AMHey MM how long are those chains?
A 20' class 70 tol handle 16' logs.  When I have 20' logs, I have to use two.  I also have two shorter permanently attached chains for handling 8' logs.
Speaking of Sweetgum.  I saw this tree today.
Talk about gumballs !!!   :o
