cascade
Started by slider, December 02, 2012, 08:45:47 AM
slider
I tried cascade for the first time on some pitchy pine yesterday.I know mm and customsawyer use it but what about the grit in it.I'm concerned about my pump.Did i buy the wrong kind ?
al glenn
think Magicman buys the liquid Cascade.
customsawyer
www.thecustomsawyer.com
POSTON WIDEHEAD
No problems with the liquid.
slider
Liquid is what I was using  but it has some forme of grit in it that i was worried about.
al glenn
customsawyer
I just put about one good squirt into the 5 gal. jug and then shake it pretty good. With that small of amount I haven't seen any bad results. Keep in mind that I only have about 400 hours on that mill and not all of them have had cascade in the lube. I only use it when the pine is going to have heavy pitch.
They said it, liquid Cascade, and I have never seen anything other than liquid in a jug.  The contents of your jug must have been contaminated in some way??
What many folks do not know is that Cascade is formulated to not foam and make bubbles.  That makes the jug filling much simpler.  I have tried the generic brands, but they foam, and did not seem to work as well as the real stuff.
Dawn dish soap and Murphy's work, but they foam badly.
Remove the squirter.
And add one glug per gallon of water.  I probably use too much, but it works.  The great majority of my sawing is Pine, so it is always filled with a Cascade mix.   :)
terrifictimbersllc
Out of the bottle it does looks gritty , especially the colder it is, but I think it all dissolves in water.  I've never seen anything left in the bottle and it doesn't clog the metal screen in the filter module.
shelbycharger400
Ugh O....
Magic is using a container not within Its original intended use.
I once used the cascade powder formula , flushing a radiator or heater core. That stuff didnt disolve very well at all.
Shotgun
Quote from: Magicman on December 02, 2012, 09:04:18 AM
Magicman, I have scoured The Dictionary of Units of Measurements ( http://www.unc.edu/~rowlett/units/ ), and I don't see the term "glug" as a unit of measurement mentioned anywhere. Can you refine this term a bit, please?
;D
Norm
Joined The Forestry Forum 5 days before 9/11.
learner
Even the Woodmizer folks(allthough they won't admit it hehe) swear by cascade.  As I see it, plain water first, then water+cascade, then water+cascade and pine-sol for the really gummy stuff.
But what is stickier than Pine?  I say follow Magics advice.  If the cascade seems gritty, try heating the mixture so it can disolve better.
WoodMizer LT40 Super Hydraulic, MF-300 FEL, Nissan Enduro 60 forklift, 2 Monkey Wards Power Kraft Radial arm saws, Rockwell series 22-200 planer, Prentiss 210 loader
POSTON WIDEHEAD
Quote from: learner on December 02, 2012, 09:38:00 PM
Oh yeah....start heating Cascade, Pine Sol and other ingredients and they'll arrest you for something.  :D
Chuck White
Tamarack is by far, the most pitchy of anything I've sawn to date!
glug. Maybe a new word for the forestry forum dictionary?
Okrafarmer
Quote from: Shotgun on December 02, 2012, 06:30:21 PM
Quote from: Magicman on December 02, 2012, 09:24:20 PM
No.
Glug : Teaspoon = Whack : Cord.
Now selling Logrite tools!
Okrafarmer
Seems like we had a thread once a while back about whacks, and other noncomittal units of measure.
Including things like Tad, Smidgeon, Hair, Whallop, Mess, Boat-load, and Wee Bitty.
red
Okrafarmer
How many glugs per slosh?
rmack
Quote from: Okrafarmer on December 02, 2012, 10:15:05 PM
I think a glug is between a dollop and a snort... 2 snorts to a slosh.
the foundation for a successful life is being able to recognize what to least expect the most... (anonymous)
Welder Bob
2012 LT40HDSD35 Yanmar Diesel Triple
1972 Patrick AR-5
Massey Ferguson GC2410TLB Diesel Triple
Belsaw Boat Anchor
Okrafarmer
Quote from: rmack on December 02, 2012, 10:24:45 PM
:-X
Dude, you're not supposed to snort it.
terrifictimbersllc
In the glossary right before grit,  grits , and grog.
JohnM
;D
Norm
:D :D :D
And absolutely everyone here, whether they have a mill or not, knew exactly what he meant! :D
JM
Lucas 830 w/ slabber; Kubota L3710; Wallenstein logging winch; Split-fire splitter; Stihl 036; Jonsered 2150
rmack
Quote from: Okrafarmer on December 02, 2012, 10:27:34 PM
:-X
sorry, left coast thinking from my long distant past.
long story short, quit whining about the soap.  8) :D
Welder Bob
1972 Patrick AR-5
Belsaw Boat Anchor
Tree Feller
From Dictionary.com
World English Dictionary
glug  (ɡlʌɡ)
— n
a word representing a gurgling sound, as of liquid being poured from a bottle or swallowed
[C19: of imitative origin]
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
