Cutting Cherry for House trim
Started by tomkat001, November 28, 2012, 04:14:47 PM
tomkat001
I am thinking ahead for my new home in a couple years. I am thinking about sawing up a bunch of cherry to make into trim boards I will run thru my my molder.
My question is how thin can I saw the boards without having a lot of warping? I usually plane the boards to 5/8 inch before they go thru the molder.
Boardwalk Jr. , JD 5075E with 553 loader, Stihl 290 Farm Boss,
VictorH
How thin you make the boards will have less affect than other factors such as - The logs you are cutting from, whether there is a lot of sweep in them or stress within them.  How well they are stickerd and how much weight is on the stack.  1/4 sawn would be more stable but you lose some wood in the process.  If the aim is to have 5/8 finished then 7/8 should work and 1" would give you plenty but will require more planing to get to the 5/8.
Victor
I would add 1/4" to the desired finished dimension when rough sawing.
GeneWengert-WoodDoc
The thinner you cut, the higher the yield, but the greater the risk of warp.  So, the target of 1.00" seems best.  As mentioned, log quality is important.
Jemclimber
I'm with victor and WDH. When I've made paneling, I cut it at 7/8 and had plenty to plane out a little cup down to 5/8.  That was with 10 and 12 inch wide boards.  Narrower trim boards at 7/8 should give you plenty of extra meat to make your pieces.
lt15
The good thing is that the planed trim does not to be absolutely flat like a table top because the thinness will allow for it to bend a little.
Al_Smith
There definatly is some merit to that because I'm not sure a house was ever built with perfectly straight walls and 90 degree corners .If so I've never seen any .
