Got Initiated Today
Started by Tree Feller, November 20, 2012, 06:47:52 PM
Tree Feller
I sawed up two nice Red Oaks for a friend today. Everything was going well until I ran the blade into one of the stops...ooh, that's a horrible sound. It was a new blade, too.   :-[
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
POSTON WIDEHEAD
OUCH!  :D :D :D :D :D You had something else on your mind didn't you?  :D :D :D :D :D
I can laugh......cause I've done it! Yep, had something else on my mind and wasn't watching.
customsawyer
It is always a new blade. You never do this type of thing with a old blade.
www.thecustomsawyer.com
POSTON WIDEHEAD
Quote from: customsawyer on November 20, 2012, 06:55:53 PM
You got that right!
Nomad
Quote from: POSTONLT40HD on November 20, 2012, 06:56:46 PM
You got that right!
     Uh...  Yup.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
MotorSeven
You got that right!
X4
I did manage to break my first one the other day, and i have no clue as to why ???
WoodMizer LT15 27' bed
sandhills
Because it was a new blade  ;)
Being initiated is always an ouch.
MotorSeven, they will only go around so many times and they just break.  Dull (not sharp) blades flex back more than sharp ones and this shortens blade life, but it still probably was not something that you could/should have done.  They all give it up and break, or either get too thin to resharpen.
Slab Slicer
X 2 for me. The first was less than 24 hours after buying the mill. It was the all purpose blade, and I had bought a box of 15 blades, so I had a few extras.  ;D The second was a few days later. I thnk that'll do for awhile.
2016 LT35HDG25, Kubota L2501 w/ FEL, Kubota BX1500 w/FEL and custom skidding rig, Stihl MS 500i, Stihl MS362-25", Stihl MS250-20", Stihl MS192-18",  2001 F250 SD 7.3, GMC Sierra Dually 6.0 gasser, Peaqua 16" 10K trailer, Sur-Trac 12' Dump Trailer 10K
Chuck
On no........
I think that I will go run a blade into one of the clamps or log dogs tomorrow just to commiserate  :).  A man has to support his friends.
taw6243
When blades start breaking check for pitch or buildup in the v of the drive or driven blade wheel.
tim
4500 hours on my 2004 LT40HDG28, CBN sharpener and auto setter, 25" woodmaster planer with 9'auto leveling bed and trac vac chip handling system, 1998 L3010 kubota, 2010 L3200 kubota Festool TS75 rail saw with 42", 75" and 106" rails.
