Better To Split Wet or Dry? And Tree ID?
Started by plaindriver, October 27, 2012, 03:33:34 PM
plaindriver
I admit, Im a neophyte as a country gent. Moved from the big city to rural paradise and it seems to suit me fine. But Im learning just how much I dont know. I have lotsa trees on the property, nearly all are hardwoods. I can recognize the maple, and oaks. Have another kind (dont know the type) with a kinda long oval shaped leaf. This one was in good shape, but a goodly bit of the root ball was uprooted, and the tree was listing probably 30° or so. So I cut it down. I wanted it to fall in the direction it was listing, so I didnt make the wedge cut in the front, just started cutting on the backside till it started making some cracking noises, and the ground vibrating. It was about 16" dia and I measured the main trunk afterwards, and it was 52' prior to branching. I cut it up into manageable sections and using a chain and my JD tractor, I dragged it to the splitter. Just did the bottom 10' trunk, as it split due to my unorthodox felling job. This stuff is heavy! I did about 18" section, and would split it into maybe 16 sticks. The splitter won every fight. But, Im wondering, is it better to dry logs first and split later, or split now and then let them dry?
2nd: Is there a idiots guide to tree ID? This particular tree seems to make a lot of long toothpicks when split. I am saving 3 of the long (10-12') sections for future milling. (Next item on the shopping list. I think the wife needs on for Christmas*).
Kubota L4600 DT w/FEL, John Deere 750 4WD w/FEL, PH Digger,RotoTiller,Box Scraper,Disc;16, 18, 20" chainsaws;Troy Built 27T splitter; table saw, radial arm saw,turning lathe, chipper, small backhoe, Isuzu NPR 14' stakeside diesel truck; a wife that still likes me.
plaindriver
 These Pics should have been incl in the previous post.
Split it when convenient. With a splitter, makes little difference, other than to the weight.
And some reading of the ff will give you some good info to fell trees safely. A wedge that you left out would have helped avoid the trunk splitting, which can lead to injury.
a bore cut to establish the hinge and then cutting out to release the tree would be better method for safer felling.
Search on "bore cutting" for some good reading.
stavebuyer
The tree is hickory. Cutting a " heavy leaner" from the back without bore cutting the heart can get you killed. Hickory is great firewood but will rot quickly if left unsplit with the bark intact.
stumper
PLEASE PLEASE PLEASE find a chainsaw safety class.  One with hands on training.
Not that it will help you in TN,but the local school is putting one on now. They have a bunch of evening classes from learning how to maintain a saw,cut trees down,welding, I forgot the others.
I would prefer to split it as soon as I could,I feel it dries better.
I have a nice book from the State Foresty Dept in Maine that I use.
OlJarhead
I split green whenever possible!  Of course, I do it by hand and that makes all the difference.  Splitting green with a good wedge head axe or maul is my choice always.
Splitting seasoned wood is like splitting marble!  I hate it but I'll do it to stay warm :)
Old country saying:  Cold?  Split firewood and it will warm you twice.
Old Jarheads saying:  Cold?  Fall, De limb, Buck, Split and Stack firewood and it will warm you several times ;)
OlJarhead
I should add that all I have is Ponderosa Pine (not ideal at all), Fir (a little better) and Tamarack (best for me) in my area.  No hardwood at all.
Pine gives a lot less heat then Tamarack and can produce a lot of Creosote but I have a chimney brush and use it often.
Fir is about 10-20% better for firewood then the pine and Tamarack is 1 1/2 times better :)
plaindriver
Thanks to all for the sound advice. I just spent two hrs on you-tube, watching vid's of pro's felling trees. In retro, I VERY should have made the wedge cut first. I was just afraid that it might have weakened the tree too much, and promoted a premature falling. On me! There is sure a lot of good and interesting stuff on YT. Thanks again.
levans
plaindriver,
If you want some hands on some time let Me know, I'm in Jamestown just up hwy 127 from you and would be glad to help you out on chain saw use some time.
Larry
John Mc
One thing to keep in mind about videos on YouTube:  anyone can claim to be an expert.  The fact that they put something up on YouTube doesn't make them one.  I've seen some real disasters waiting to happen on YouTube tree felling videos.
doctorb
I am still interested in the title question of this thread.  Is it easier to split green wood than seasoned and, if it is or it isn't, why?
If with a splitter, no appreciable difference in the "ease" to split, other than the weight of the piece if having to lift it to the splitter.
If splitting by hand, then likely splitting green is easier.
When I used to split by hand, I'd buck off blocks to length, and then turn all the blocks on end. Then if there was a time lapse getting around to splitting, the exposed end up would dry some, the other stay 'green'. When coming around to split with a maul, always was easier to turn those blocks end for end so the 'green' side was up ( ;) learned that from laying sod ya know ). The end grain dries out and seems to absorb the blows of the splitting maul moreso than the 'green' end that isn't dry.
doctorb
Interesting, beenthere.  I have some splipery elm, which should be tough to split anyway, which has been bucked into rounds and off the ground, but stacked for 1.5 years.  Will I notice a difference?  Will my splitter handle it anyway and should I stop cogitating over it?  Using your explanion, both ends are dry  :D :D ;D
Migal
 ;) My experience, With a double bit axe Hickory splits easier dry. Hydraulic splitter either way. Sure would like to see a close up of the leave's My eyes see a lot of oak shaped ones.  :-\
Stihl learning and picked up my Log Master LM2 Cat 34hp 02 21 12! 230MF+ the toys that go with it! MS361 MS271 Stihl PB500 Echo 48" LogRite 16ft Bass Tracker Pro' Abua Garcia 5600 bait caster, Wood working equipment' Lake Lot never enough time! oh don't forget the fridge with ale! Loving Wife Rebeca
With splitter, I doubt it will, at most, be do no more than a slight hiccup as the wedge enters the wood. Past the very end fibers, the blocks are still green. I'd be real surprised if any hassle at all.
The way my Father showed us was to read the stick. Look for the longest,widest crack. also split with the way the tree grows,big end down,if you can tell. Keep away from a limb of any rough spot too. Some will say frozen wood split better. But we was splitting in the summer so the wood would dry for the heating season.
OlJarhead
Green wood is easier to split in my experience.  Dry/seasoned wood has less water in it (a lot less) and is harder so when you hit it with your ax it won't sink in a deeply.
I can mow through wet pine, fir or tamarack when its wet, when its dry I might take 3 times longer to split a cord!
JohnW
You ask will it split easier if green?  Funny, I never considered that question.  When I cut a tree, I want to get the wood off the ground.  I think it's easier to handle after it's split.  That is, it's easier to put in my wheel barrow or put in my pickup truck and haul.
stavebuyer
Relative to the ease of splitting for green vs dry, I always felt both hickory and white oak split easier when dry. Both species tend to be "stringy" when green. Those "strings" that hold the split pieces together like glue will eventually dry out and get brittle. When I used to split evrything by hand I would quarter the blocks for easier handling and then re-split after the blocks dried for a while.
Ljohnsaw
Quote from: Migal on October 29, 2012, 07:03:59 PM
I saw the leaves as well, it sure looks like white oak to me, even the bark.  Though, I've never seen a hickory...
Say, does hickory make good timber joint spikes?  Maybe you could go into the spike making business.  They go for a buck or so a piece on eBay!
John Sawicky
Al_Smith
What you had there on that leaner is a classic "barber chair " .You have to watch that because the end can split  out and either slide off backwards or flip over itself and remove your head from your shoulders .
In addition to using a bore cut it's often helpfull to bind the bottom with a stout log chain and binder .
If you are dealng with green hickory or maple you'll do better if you get it split rather than let it lie in rounds .Both woods will be growing mushrooms if you let it go too long before you split it .
Now nobody said you have to do it all in one fell swoop .So maybe you split a half a cord and call it a day .Before too long you have the whole thing done .
QuoteIn addition to using a bore cut it's often helpfull to bind the bottom with a stout log chain and binder .
And that binder would be just above the felling cuts.  ;)
A good safe guard on leaners.
Bill
When I started ( some years back ) my buddy advised me to split it as soon as you could - his goal was to get it dried for burning and according to him it dries faster when split.
Course he has a splitter - I still use an orange  " Monster Maul " all steel behemoth for smaller jobs - my buddy will share for bigger jobs .
I'm not very partial to elm - iffen I happen upon it I try to cut it " extra " short so I can split it - though it burns just fine .
Good Luck either way
That old rock maple this past April we took down in the yard would just spit the maul right back out on the recoil. :D Had to start it with the chainsaw making groves to quarter up the 200 lb rounds. Then took them quarters onto the splitter. Still split devilish hard on some. :D Destroyed the neighbors home made splitting wedge in 3 pieces. Had to go to town to get a good Garant splitting maul and hammer away with a post maul. :D
