steam bending a spindle turning
Started by Dan_Shade, October 15, 2012, 10:00:00 PM
Dan_Shade
Have any of you guys tried to do this?  I have an idea to make a lamp with a bent shaft.
lots of dull bands and chains
pasbuild
If it can't be nailed or glued then screw it
Dan_Shade
that's what I thought.  I want to make an S-curve, but I want it round, with a hole drilled through the axis
Lud
Good luck with that......
Wood to be bent usually is split or rived so that fibers are all going the same way without shorts or cross grain.  The steam lets fibers compress or stretch , under pressure to then cool into a new shape that always rebounds to some extent.
A drilled cylinderical , smooth, straight grained spindle is a tube. A tube bender suggests itself but , IMHO, the void will collapse.
Now....rive it, turn it, bend it into your S, then slice it length wise  on a bandsaw, route a hollow down the two lengths and glue it back together might work.
Like I said at the start........good luck with that. ;) ;)
When it dries it will also go oval if you start green. It may also check and split. And the hole bored will likely collapse when bending as Lud said. If you steam it real thorough and it's straight grain it will be just like plastic in your hands. But if there is a lot of resistance than it won't work. Don't attempt using kilned wood, use air dried or green and steam it at least 2 hours per inch and that's with steam bellowing out the steam box. Never know until you try. I've steam bent lots of air dried ash.  :) Have a former ready to secure the bends, you have very little time, work fast. ;D
Dan_Shade
this is brainstorming/experiment, so no big deal if it won't work :-)
I was thinking I could fill the hole with bb's and plug the ends to try to keep the hole open.....
Dakota
How about putting the wire through, and then steam and shape it?
Dave Rinker
Jemclimber
Quote from: Dan_Shade on October 16, 2012, 07:20:05 AM
That's one way to bend largerish metal pipe. fill with sand and cap or weld the ends before bending, might work.
lt15
grweldon
Quote from: Dakota on October 16, 2012, 07:51:57 AM
I think this is a great idea!
My three favorite documents: The Holy Bible, The Declaration of Independence and The Constitution of the United States.
pineywoods
If you try that, be careful what kind of insulation is on the wire. Plastic will melt and deform under pressure.
Tree Feller
I think I would bend it into shape, slice it in two at the bandsaw, rout the groove with a laminate trimmer or a scratch stock and glue it back together.
It might require a little work with a spokeshave and sandpaper to get it back perfectly round.
Edit In:  Lud I just saw that you suggested the same thing.
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
I think that would be a mighty tricky procedure.  ;D
wheelinguy
How  about steam bending the s shape and then using a straight piece of accent wood or stainless steel tube and drill down through the s and use straight bit to hold the whole thing upright on a base and fish the wire through that?
Lud
Use two pieces of accent wood in  parallel  , straight vertical , through  the S and you'll get a dollar sign! 8)
