Chainsaw driven splitter
Started by magicmikey, October 08, 2012, 10:41:56 PM
magicmikey
  A friend dropped off a splitter he purchased at a local auction. Had no idea that someone manufactured these. Any info would be appreciated. :)
mike
sawguy21
I believe that was designed to be run by the TML saw, aka Husky 35. The fill caps look familiar.
Paul_H
I've got two boxes of Husky 35 parts for you Mike ;)
Never saw one like that. looks like the long springs were added and some metal to hold the saw too. I can understand what one end is for,that's where the saw goes. But the other end has a 2 fill caps.One for hyd oil,which makes since,but another for engine fuel mix? Must have a line missing that goes into the carb,fuel tank? Or is the saw a top fill?
sawguy21
Paul I have an NOS cylinder if you want to build one. ;D
magicmikey
  Thanks sawguy21 and Paul. I will cogitate on its restoration which might not be for long ifn Paul delivers on Sundays. ;) ;D
The fuel line and grommet are missing from the saw end, possibly a semi-permanent setup?
mike
Al_Smith
Hmm interesting .Evidently it's just using one side of the cylinder .Once you hit the power from the saw engine the cylinder moves forward .When you disengage the clutch by idling down the saw the garage door springs return the cylinder .
