Author Topic: What tool am I asking for and where do I get it?  (Read 3136 times)
Offline POSTONLT40HD
  • G29
« on: September 29, 2012, 09:53:12 pm »
I have seen these type of legs on benches a lot of times.
A wood worker takes.....Let's just say a 3 inch diameter limb. He or she needs to taper one end down so it will fit snuggly into a hole in a bench slab thus producing a leg. What kind/name of a tool is this and where do you get it? I think it fits into a drill.
Thanks.
I'm thinking......
Offline YellowHammer
  • There's a lot more to it.
    • Hobby Hardwood Alabama
Re: What tool am I asking for and where do I get it?
« Reply #1 on: September 29, 2012, 10:04:43 pm »
I believe you are looking for a drill mounted dual blade tenon cutter to shape the rustic furniture tenon and also will need a Forstner bit to drill the mortise hole.  Several of them on the market, here's a link to one.
http://loghomelinks.com/furn/tenon-cutters.htm
Hope this is what you are looking for,
YH
Hobby Hardwood Alabama.com
LT40 Diesel Hydraulic, Stihl 028, MS440, MS660, 2 Kilns
  • G29
« Reply #2 on: September 29, 2012, 10:13:37 pm »
This is EXACTLY what I was asking for.
Thanks Yellow Hammer.  smiley_thumbsup
I'm thinking......
Offline fuzzybear
« Reply #3 on: September 29, 2012, 10:27:45 pm »
Lee Valley hardware also sells the tenon cutters and they are very good. I have a set for making diamond willow furniture this winter. Well worth the money if you are making one of a kind pieces.
FB
I never met a tree I didn't like!!
Offline SwampDonkey
  • Large Tooth
« Reply #4 on: September 29, 2012, 10:28:04 pm »
Lee Valley sells them to, they have a NY office I believe. They may be on the pricy side, never looked at them for some time. But they will be good quality. ;)
Dirty Harry
Offline Okrafarmer
  • Location: upcountry SC-- Sweetgum capital of the world!
  • Avast! Here appeareth some sweetgummery about....
« Reply #5 on: September 30, 2012, 01:05:49 am »
At first, I was going to say, a giant pencil sharpener. But yes, I want one of those in my stocking at Christmas time, too.
No matter how conventional wisdom may fly in the face of radical thought, it's still the most popular type.
Turbosawmill 8" cut GX390 Warrior Sawmill, 13hp Honda
MS290 Stihl
Genesis Hardwood Lumber
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #6 on: September 30, 2012, 07:43:13 am »
That is rough use for a drill, so I would buy a very good quality cutter and not go cheap so that you get a good quality cut without killing yourself or the drill  :).
Offline SwampDonkey
  • Large Tooth
« Reply #7 on: September 30, 2012, 07:49:07 am »
Yup, hope you have at least 6 amp drill. I burnt up a 4 amp on dowels.  ::)
Dirty Harry
Offline Busy Beaver Lumber
    • Busy Beaver Lumber
« Reply #8 on: October 24, 2012, 10:58:38 am »
David
I have about 6 different sizes of them made by veritas and they work very well. If you cut the wood when it is green, it cuts a lot easier. Worst cutting is old dried out limbs which tend to chatter and vibrate when you cut them, but they still will cut.
As mentioned you will need a good beefy drill to go with the larger size cutters and preferably one with handles on both sides so you can get a good grip on the drill because you will be fighting some decent rotational torque with the larger size ones.
Next problem is clamping the piece you want to cut the tenon on. I like to use the Rockwell Jawhorse with log holding attachment. It gets a good grip on the round logs. I prefer to elevate my work pieces and work benches to a more comfortable working height. I mounted the Jawhorse onto T shaped assembly of 8 x 8 landscape ties with rubber mounter to their bottom to get the jawhorse up higher and to give it some counter weight for when i lean into it and cut a tenon on larger diameter stock. Without the weight of the landscape ties and the rubber, the jawhorse would slowly scoot across the floor.
Woodmizer LT-10 10hp
6 x 10 dump trailer
Grizzly 6in Spiral Cut Joiner
Twister Firewood Bundler
Jet 10-20 Drum Sander
Jet Bandsaw
Save a tree...eat a beaver!
Offline Brad_bb
    • My timberframe blog
« Reply #9 on: October 24, 2012, 01:21:07 pm »
There are antique ones out there too, like on ebay and other places.
Offline Delawhere Jack
  • I ought to know better.....
« Reply #10 on: October 24, 2012, 05:33:03 pm »
Go Old School, use a draw knife or a spoke shave. You'll probably need one or the other to whittle the piece down small enough to use the tenon cutter anyway.
black walnut, cherry, SYP, southern magnolia, poplar, hemlock, osage orange, red oak, white oak, chestnut oak, black locust, english walnut, ERC, WP, hickory, ash, black birch, beech, honey locust, apple, white cedar, black oak, basswood(?), sassafras and a "Christmas tree" full of iron
  • G29
« Reply #11 on: October 24, 2012, 05:35:01 pm »
Good thought.  smiley_thumbsup
I'm thinking......
Offline scouter Joe
  • Making sawdust
« Reply #12 on: October 27, 2012, 07:50:27 pm »
I have 5 from Lee Valley and they work OK . A couple of years ago I bought 2 from Bosworth Tools and they are far better than the Veratis in my opinion . They are easier to line up and many times faster . They are more expensive though and unless you will be using them a lot they may not be for you . Goggle them and check them out . I really like the ones that I have . scouter Joe
  • G29
« Reply #13 on: October 27, 2012, 08:59:19 pm »
Thanks Joe......I'll take a look.
I'm thinking......
Offline LeeB
« Reply #14 on: October 27, 2012, 11:49:30 pm »
I have the ones from Lee Valley and like them ok. I wouldn't think oftryingto use the bigger ones with a 3/8 drill. I use and old real beef 1/2" drill Black and decker from when BD used to be something. You can be limited to the size stick you are tennoning but you can start with a larger size tennon and recut with a smaller cutter. The biggest one I have will cut a 2" tennon on about a 3 3/4" stick. Then I take down smaller from there with smaller cutters if I need a smaller tennon.
'98 LT40HDD/Lombardini, Case 580L, Cat D4C, Ford 851 tractor, JD 3032 tractor, Husky 346, 372 and 562XP's. Stihl MS180 and MS361, 1998 and 2006 3/4 Ton and 2005 1 ton Dodge 5.9 Cummins 4x4's, 1989 Dodge D100 w/ 318, and a 1966 Chevy C60 w/ dump bed.
Offline barbender
« Reply #15 on: November 11, 2012, 11:32:16 pm »
Another method is to use a bandsaw (shop bandsaw not your LT40 poston ;D), forstner bit and a holesaw. Use the holesaw to cut your tenon, then trim the waste off and make the taper with the bandsaw. Drill the mortise with the forstner bit. You have to do a little experimenting to find a hole saw and forstner that match up in size.
  • G29
« Reply #16 on: November 12, 2012, 04:55:11 pm »
DanG BB......your idea sounds like it would work. :)
I'm thinking......
Offline breederman
  • getting by the best way I know how
« Reply #17 on: November 12, 2012, 06:40:26 pm »
That's how I do it but I just use a belt sander to make the taper. If you don't look to hard it looks like you witteled it down. I think it looks more rustic.
Together we got this !
  • G29
« Reply #18 on: November 12, 2012, 08:19:47 pm »
Rustic....the MAGIC word. That's my whole point in building "stuff"....that rustic look. Good ideas guys!  smiley_thumbsup
I'm thinking......
Offline breederman
« Reply #19 on: November 12, 2012, 08:53:53 pm »
I use a spade bit they match my hole saw for a perfect fit.
