Black Locust
Started by POSTON WIDEHEAD, September 25, 2012, 05:57:10 PM
POSTON WIDEHEAD
Had a guy call me from Valdese, N.C. today. He has a 30" x 70 ' Black Locust tree that blew over in the last 3 days. He's gonna get it sawed and loaded and said he was looking for a mill to take it to.
I gave him a price of 30 cents, International to saw it. Whether he brings it, I don't know. If he does, I'll take some pics to show.
I have never sawn Black Locust or any Locust. I run 10° blades. Would my blades do the job? It's still green.
My price of 30 cents.....to low, to high....just right?
He said he would call me back, if he does, I'm hoping to go to work or try to save him some time and money and put him on a mill closer to him. He's a pretty good clip from my mill and got my number off C.C.
Thanks!
If he brings it to you, sounds like you are stuck for doing it for 30 cents. But he won't likely refuse if you decide that is too high and want to come down from that price. ;)
Let us know if you will book another one for that amount. :)
look forward to the pics.
POSTON WIDEHEAD
Brother Been, I regularly saw hardwood for .30 and softwood for .25. I just don't know what to expect sawing B.L.  say_what
Dan_Shade
Black Locust is hard.
The tree could be hollow, and most of it around here can be pretty gnarly, it's tough to get a good cant due to bark inclusions.
I would try to saw it as soon as I could, the longer it sits, the harder it will be.  I use 4 degree bands to saw locust.
lots of dull bands and chains
Chuck White
Dave; I've sawn Black Locust with the 10° Double-Hard Wood-Mizer blades.
It saws pretty good when it's fresh cut, just have to slow the feed a little bit after sawing Pine & Hemlock.
If you have some blades with less hook handy, you might want to give them a try.
I just don't think I'd go out and buy blades special to cut a few logs.
Delawhere Jack
I've milled a little locust, not sure if it was black or honey. It came from standing dead trees that came down in a storm. The largest logs were 18-20", I used 9deg bands and didn't have any issues....other than that the logs were gnarly...
westyswoods
Sure don't claim to know much, my experience with BL here in WI is most everything over twelve inches is hollow. The larger the greater chance of it being so.
Stay Safe and Be Healthy
Westy
POSTON WIDEHEAD
Some good info guys.
It would be nice if ya could buy a box of mixed degree blades for emergencies.  :)
dgdrls
Post,
If it's like yellow Locust cut it soon as you can and get some 7 deg or 4's
I cut yellow that was dried for maybe 2 months on my LT10 with 9deg blades and she was shaking like a Hawaiian hula girl  :o
DGDrls
hackberry jake
Around here 30" would def be hollow. They start getting a soft spot in the middle around 12"
SPD748
David,
If you end up with the job and need help let me know. I'd be glad to run down and offbear for ya.
-lee
Frick 0 Handset - A continuing project dedicated to my Dad.
410 Deere, 240 Massey... I really need a rough terrain forklift :)
Sawing Since 1-19-2013 @ 3:30 pm
Serving Since 2002
"Some police officers give tickets, some gave all."
POSTON WIDEHEAD
Quote from: SPD748 on September 25, 2012, 08:11:43 PM
David,
-lee
Black Locust?  :D  I may let you do the sawing. I'll off-bear! smiley_thumbsup
I heard that black locust is hard  :D.
hackberry jake
I have only cut one large tree worth of logs of black locust. If you have a band that doesn't have much set, I might throw it on and use it as long as its sharp. My experience with black locust wasn't bad at all.
POSTON WIDEHEAD
Quote from: WDH on September 25, 2012, 08:25:33 PM
Arn't you the guy that puts kids in bins?  smiley_kid
Dave Shepard
I've sawn a lot of black locust. I use 4s, but 10s work also. Trouble is finding sound and straight logs around here. The dust makes me sick. Glad I have the wireless remote so I can get away from the dust. I've also set up a 42" barn fan to blow towards the mill. :D
mikeb1079
i've only sawn a few black locust logs.  all but one behaved fine.  it was the butt log and it was hollow in the middle.  eventually i just gave up on it and turned it into firewood.  i was running 4 degree doublehards from wm.  if the logs are in decent shape and green i bet they wont be too bad to saw.
good luck :)
homebuilt 16hp mill
Full Circle
I've used only 10 degree blades in locust (honey and black) with good results, but no 30" logs.  I only recently used both 10 and 7 degree blades on a job with hickory and silver maple and believe there was a noticeable improvement in quality of cut/feed rate with the 7's.  Not telling you what to do, but I'm looking forward to trying the 7's in some locust.
Just watch for stress more than you normally do.  Turn often.... ;)  I think locust is worth the little bit of extra work it can take sometimes.  As a side note, I don't wear a mask when I mill, but I might next time I mill any quantity of locust.  It leaves me with cold-like symptoms for part of the day after milling.  Not bad, but noticeable.
Hope you get the job.
-Roy
fullcirclefarmandforest.com
POSTON WIDEHEAD
Dan_Shade
I need to wear a dust mask with locust, it makes me sneeze
David,
I swear that I have never had any dealings with goats.
Delawhere Jack
Quote from: POSTONLT40HD on September 25, 2012, 07:21:21 PM
That's "knot" a bad idea. So......who's idea was it?  :D :D
(The Resharp guys might not be so keen on it though......... One box with 3 each of 5 different bands....... :-\)
POSTON WIDEHEAD
Quote from: Delawhere Jack on September 25, 2012, 09:22:53 PM
It was my idea.....it wood be nice if we could though. :)
POSTON WIDEHEAD
Quote from: WDH on September 25, 2012, 09:18:45 PM
David,
That you can remember.  :D
