Perhaps I Need a Bigger Bobcat
Started by logboy, September 23, 2012, 10:22:14 PM
logboy
I've been sawing up White Pine into 1" x 8" x 16' with the Lucas to fill a couple thousand bdft of orders. Tonight I grabbed a hold of this guy with the grapple to load it into the mill. I'm determined, but so far the log is winning. I dont think its quite a ton, but its over 1,500 pounds.
I like Lucas Mills and big wood.  www.logboy.com
Okrafarmer
Use your pallet forks for that bad boy. You save a few pounds compared to the grapple. I can lift a 2,000 lb. log with our 751 Bobcat with forks. Each machine has its limitations, but yours should be able to handle a bigger log than ours does. You may not realize just how much the log weighs. That looks like bigger than 24" diameter, and since it is 16' long, that is still quite a heavy log, even though it is white pine.
Now selling Logrite tools!
logboy
That grapple is actually really light. Too light actually, since I keep bending the arms. I would guess the weight is very close to my forks. I can grab it by myself and drag it.  I need to upgrade to a bigger one with different arms that close all the way onto the bottom.
You can lift a ton with your 751?  I am nowhere even close to lifting that. Here is half of a 2 ton cottonwood log I slabbed. I had to slide the forks on the ground to move it. I wish I had my old man's S250.
Okrafarmer
How long is that cottonwood? It doesn't look like I could lift it, but then cottonwood is lighter than a lot of other woods. White pine is one of the lightest of all.
Our old 751 can't lift a log any higher than about 3 ft. if it is too heavy to balance on the machine. I haven't weighed any of the logs, but I recently lifted a red oak log that was 24" diameter, 10' long plus trim and dumped it in the dump truck. That was the maximum capacity. I had to rock the BC back and forth to get it to go up past a certain stage. Our 751 also is older than your machine and is from back in the days of the shorter wheelbase. Your wheelbase looks longer, so you should be at least as stable, maybe better.
POSTON WIDEHEAD
Eat more grits and the back of that Bobcat will set down.  :)
Woodsrover
Weekend_Sawyer
Ha! I was in China back in 87' and saw that same problem, they had plate steel on a mule cat and started up a hill and the load shifted.
Jon
Imagine, Me a Tree Farmer.
Meadows Miller
Gday
Don't We All  :) :) Just scoot it upto the mill one end at a time if you want alot of control of the log  I have done it heaps of times thats the beauty of logs they roll  smiley_thumbsup I have had to do it heaps with the chamberlain The biggest was a 5' dia Gery box that would have weighed about 5 ton per log   just kept pushing and rollin as I dropped the tree where their shed was going to go and I was not coming back to mill it for a while I rolled them about 80 to 100 foot away :) :)
:D :D :D :D Donkeys having a baaad day there  :) :)
Regards Chris
4TH Generation Timbergetter
ladylake
With forks you can get the log a few inches closer to the log to the skidloader which helps.   Steve
Thehardway
A buddy of mine had a couple pieces of 1" steel plate cut and bolted to the back of his Case skidsteer as counterweight.  It worked well and gave him an added 500lb lift capacity before tipping point.  Would probably work for you too.  Also, the higher the lift, the less the capacity, don't lift that log more than .25 inch off the ground.  No need to lift it any more than that to move, especially using a grapple.  It won't be any easier to move at 2' high than 1".  Most operators use a lot more fuel, time and wear on hydraulics by lifting loads higher than is necessary trying to lift objects to waist height where we would manually carry a load.  It is human nature.  We aren't used to bending over and carrying anything a distance 1 inch or less off the ground as it would be difficult for a human,  not so for the machine.  Of course if money is no object, get a bigger skidsteer or even a mini-loader. :D
That cat needs some weights on its a$$.I'am on tippy toes with the BC's all the time just too lazy to put the forks on the big sweed.Really you need some of the add on weights,that big pine log is well over a ton. Frank C.
SPD748
Quote from: POSTONLT40HD on September 24, 2012, 07:05:37 AM
Quote from: Magicman on September 24, 2012, 07:32:03 AM
Short on horsepower  ???
:D :D :D You guys are too much! :D :D :D
-lee
Frick 0 Handset - A continuing project dedicated to my Dad.
410 Deere, 240 Massey... I really need a rough terrain forklift :)
Sawing Since 1-19-2013 @ 3:30 pm
Serving Since 2002
"Some police officers give tickets, some gave all."
logboy
When I upgrade one piece of equipment, I end up finding the limitations of another piece of equipment. Its like a dog chasing its tail.  I just picked up a few big logs for slabbing. My old clunker forklift can lift 3000 pounds. Guess how much each log weighs.
logboy
QuoteEat more grits and the back of that Bobcat will set down.
I'm a northern Yankee, so you wont find grits around my breakfast table. But I did eat quite a bit of them in the Army at Fort Benning, GA and Camp Shelby, MS. I learned if I dumped a ton of sugar on them and mixed in a little syrup they werent half bad.   And the drill sergeants werent about to let us throw food away.   :D
Okrafarmer
I have to lift the log high off the ground to put it in the dump truck. The oak log I lifted was very heavy, put the machine to its limits.
Thehardway
You might be better off to invest in a knuckleboom truck instead of a bigger bobcat loading a dumptruck.  Could eliminate a couple pieces of equipment for picking up logs?
SAWMILL BUDDY
If you roll that grapple under the log will be right next to the bobcats front end. You can carry a lot more weight that way.
Okrafarmer
Quote from: Thehardway on September 24, 2012, 02:41:27 PM
We have a knuckleboom truck, but I use the Bobcat to get into people's back yards to get logs, where a knuckleboom can't go.
logboy
Its not an option for me, as I just bought a flatbed this summer. I absolutely need a skid loader.
Just found a little log hauler arch on Craigslist, if someone is in the market.
*Craigslist links not allowed.*
POSTON WIDEHEAD
Quote from: logboy on September 24, 2012, 07:22:01 PM
LOGRITE builds the best log hauler I've seen. GREAT customer service and you support a sponsor and the sponser supports you. These log haulers you see on Craig's List are not what they seem.
I know a guy that bought a hauler off C.C. and the welds broke.  :D  ......I laughed my tail off at him.... :D :D :D......I'm talking LIVE ACTION! I had to take the backhoe and help him out.
wood monger
White pine and Cottonwood are light woods when they're dry but when they are green and full of water they're quite heavy.
Sawdust Lover
I bought a bigger tractor to handle the logs and found that I started getting bigger logs and know I'm right back where I was with a smaller tractor. I figure if I cant lift them with a 65hp tractor they are to heavy for my 2000 Timberking.
logboy
This is the heaviest log I ever slabbed (actually for another forum member). 20' long, 36" diameter White Oak. Apparently took 2-3 skid loaders to put on the truck for transport. Guesstimated to weigh in the 9,000 pound range.  I'll be begging the wife for a payloader when I start doing those all the time.
QuoteWhite pine and Cottonwood are light woods when they're dry but when they are green and full of water they're quite heavy.
Trust me, I know full well how heavy the Cottonwood was. It bent every cross-member on my trailer. It calculated at over 2 tons.
barbender
That white oak is beautiful, what in the world was the 20' slab for? A board room table or something?
