broke my first blade today
Started by mrgraphix, September 19, 2012, 02:34:19 AM
mrgraphix
I am glad i built guards when a blade come apart you know it.  I know it was my fault ass this is a homemade mill kinda learning as I go I have been meaning to put blade lube/ cooling drip on and will tomorrow also learning how to tension blade i had cut several hundred feet of oak and cedar blade was probably getting a little dull and i pushed the issue trying to finish the last log for the day.  I have to take th welder out to the mill and make a bracket for the water drip can.  also think i need to make some mods to the blade tensioner it is a baker style setup used all thread to apply pressure but all thread is bending i will try to get pics later today also i have thought of adding a spring to tensioner like baker uses is anyone familiar with bakers set up?  I know i am all over the place it is 1 am and just can't sleep thinking about what i need to fix  thanks
nothing is better than felling your own trees making your own lumber and then building something with it
Chuck White
Makes you jump doesn't it!
Lots of things lead to blade breakage.
Just going around the wheels to many times will do it too!
Kansas
95% of all the blades we put on the mills break. At least. The rest get wrecked for one reason or the other. Have a couple of people that scrap iron that stop by every few months and take our old ones.
drobertson
I remember you posting your mill in action. Can't remember if you show the blade tensioner that good. It would be a hard thing guessing how much tension is on the blade without some sort of gage. One that reads in psi.  Good luck.  You will get it,     david
I doubt that excess tension had anything to do with the blade breaking.  Breaking is just in the normal cycle of a blade.
Al_Smith
I don't have the experiance with band type sawmills that these folks do however with metal cutting bandsaws you'll get better band life if some type lubricant /coolant is used .
Even on the type built like a "Do-All" vertical saw a simple blast of compressed air over the band greatly enhances both the cutting plus the band life .
First band break your due for a skivie change,don't know if you ever get used to it.If you hear a click click and are real quick sometimes you can shutdown before the band parts ways.Look at some factory built bandmills and measure the tension spring,or just order one from them. Frank C.
I have no gauge on my mill. I can tell just by pushing down on my blade if it's good or not.Just comes in time. And for all I know I maybe be all wrong with the thumb gauge,but my lumber comes out good and the blade stays on.
mrgraphix
I had the blade tensioned with the caliper method I found on here .003 in of blade stretch in 5 inches.  It seemed to be running well i just think it was due to the fact I needed to get the blade lube set up on the mill this will be my next project for tomorrow as i have to work tonight so now I am off to bed. I think I will also add a spring into the tension set up on the mill.
grweldon
I would think that .003 in 5 inches would be very difficult to measure without a precise fixture or tool. I'm not familiar with the caliper method of tensioning, but if you are measuring tooth distance with calipers and placing the measuring points by eye... you are not getting an accurate measurement.
I would think that you would get better results by measuring deflection between the guides or better yet... between the wheels with the guides removed.
My three favorite documents: The Holy Bible, The Declaration of Independence and The Constitution of the United States.
hackberry jake
Boardwalk uses a precise compression spring. I don't know the specifics exactly but say the spring is compressed a half inch, then you know there is about 400lbs of pressure. Boardwalk put a max and min compression gauge on the spring. I usually run it in the middle unless I am having trouble keeping the band from wandering then I take it to the max. You might call Ed at ez boardwalk. He sells his parts for cheap.
petefrom bearswamp
I agree with Kansas.
When they break my tail man jumps and when I destroy them I curse.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Delawhere Jack
You mentioned that the all thread in your tensioner was bending. You might consider using an automotive scissor jack. Salvage the threaded rod and nuts from it. It's usually acme thread, at least on the heavy duty ones.
isawlogs
 Maybe the rod is not big enough to give you the tenssioning you need, lube may help, but I doubt that it is the cause you are looking for here.
   Marcel
mrgraphix
I rebuilt the tensioner and added a spring here is I pic of the mod I added a piece of tubing with a spring this should keep the all thread from working its way up the back piece. i don't think the spring was strong enough but it was all i had at the time it was a valve spring from a 350 motor.
bedway
I have found after having a number of bands break on me that most of the time you can hear a difference in sound or tracking of the band before it pops. Ive shut down my mill before my last two bands gave it up, and each was cracked half way across.
Chuck White
A blade definately changes it's sound once it gets a crack in it.
Once you learn that sound, you'll shut the mill down before the band breaks, possibly causing damage.
Kansas
On the plus side of broken blades, a customer dropped off a knife he made  for me yesterday out of a broken blade. He did an awesome job of it. I need to find a leather holster to carry it. It has the teeth on top; sharpened to perfection on the bottom, coming to a point with a wooden handle.
Mr. G,I don't think a 350 chev. valve spring is anywhere heavy enough.In a limited space like you have sometimes you can put a smaller diameter spring inside a larger one.Farm equip. dealerships are a good place to look for springs,a long one can be cut. Frank C.
Stephen1
I had an older Norwood with no tensioner gauge. I would tighten it till it sounded right by tapping it with a wrench, then on here I was told it is the key of 'D' by someone. I then used my sons guitar tuner to tension the blade. It worked out okay. but blades just break, and the 2 hours of cutting is what I was told by WM is when you change out the blade dull or not.
mrgraphix
only two hours of cutting before changing blade  oops i probably had six hours on the blade and several hundred board feet.  My wife tells me that this is the thing with building your own stuff you should know how to work on it  :D  But I haven't written the manual yet.  Now that i think about it just before it broke I did hear a ticking sound must have been a crack in the blade.  I probably had cut 400 board feet of oak and cedar when it broke that makes blade cost 4.5 cents per board foot I guess this is not really bad when you look at it this way.
hackberry jake
You would have gotten more life out of the blade if you would have pulled it sooner an sharpened it. Running a band around the wheels produces micro-cracks in the gullets. Sharpening them removes the cracks before they grow.
PineNut
When I got my mill, I started with a box of bands. I rotated through the box and sharpened them as needed. Didn't have any problems with breakage. Then recently, they started breaking. On all of them, I could see where the crack was and then where it just broke. This supports the theory that the band can just go around so many times and then fatigue sets in and they break. That is just part of the game of sawing.
Yup Roy, when they break I just smile and put a fresh one on.  It seems like they just sorta retire themselves.   ;D
Chuck White
Quote from: Magicman on September 29, 2012, 07:24:14 AM
Yes the do MM!
I have about 12-14 retirees hanging on the peg in the garage now!
Just waiting for one of my nephews to make a junk run to the scrap yard and I'll throw them on his pile!
Seems I go through about a box each sawing season.
Then I order another box during my birthday month.
I like to have plenty of new blades on hand.
