what band blade works for you, need to order, thinking about changing
Started by drobertson, September 08, 2012, 11:09:34 AM
drobertson
I thought I would pick some brains on band blade choices and why,  My inventory is at a critical low, been on resharpes long enough, I have a hankering for maybe trying something different. I will post what I use now, but I would like to hear some reports on all the different makes.  Thanks,   david
POSTON WIDEHEAD
David, on my Woodmizer, I saw mostly Pine and a little Oak when every now and again.
I use the 10 degree Woodmizer blade which is really excellent on Pine and very good on Oak if I slow down a bit.
If I was sawing nothing but Oak, I would go with a 4 degree blade.
What mill do you have? I know you told us on another thread but I don't remember?
David
Dan_Shade
There are a lot of factors to having the best blade.
I have a 25 HP engine on my mill.  I use 10° for  except white oak, hickory and locust.  I use 4° for those.  I run Woodmizer blades..
lots of dull bands and chains
drobertson
David, I have the 40 super, 51cat, 13'2" blade, I just ran some old, old wmz resharpes and they still got the job done. I ran some simmons resharpes on some pine a few weeks ago, just like a planer. Unbelievable. My sharpener is face grind only. this is why I am asking. wmz blades are the D-4, very hard. I have some but not worth at this point for another resharp.  I hate to sound tight, but it is what it is. I will tell what works for me, I just need to hear some other inputs. I am open minded, and need to know how you guys sharpen the used blades. I Lost my sharpener lady, she was a good one for sure, 4 bucks a blade, 4 miles away.
Peter Drouin
HI drobertson, I have the same mill as you A 2008. I use WM 1 1/4 x55x7s .and I use them on all kinds of wood , All I use. Go buy a sharpener and setter. and you will be all set. this is my setup
  I hope this helps, good luck
A&P saw Mill LLC.
License NH softwood grader.
drobertson
I have never had/seen a reason for me to change band brand or manufacturer.  Of course, I do use WM Resharp/Replacement service so I never run short or low on bands.
hackberry jake
I'm sure different mills work better with different bands, but I have tried most of the major manufacturers and timber wolf and monkey blades are my favorite two.
LaserZX
I have been looking for other options too and found Countrysawmill and Knife in Ohio to be a next place I am ordering blades.   I talked to Steve and he gave me like 4 major brands to chose.    I am going to order a assortment and try it out.   I am using WM Double Hard now and found them to be good but I am a rookie so maybe I can learn something with different blades.
customsawyer
I run the 10° blades. They work well on most everything and give me decent cutting speed. If I was doing lots of hard hardwood like hickory and white oak I might go to the 4°.
www.thecustomsawyer.com
hackberry jake
Menominee saw is a sponsor of the ff. they carry simonds, wm, monkey, and lennox. The last time I ordered bands I got two wm, two monkey, three simonds, and three Lennox. All in the same box, you can't beat that.
Chuck White
Quote from: customsawyer on September 08, 2012, 06:28:00 PM
Same here, I use the 10° for everything!
It's a general purpose blade!
Good luck in your search!
WH_Conley
Bill
Dave Shepard
WM 10° for most sawing, and 4° for locust and white oak, although I've sawn a lot of oak with the 10°. Most of my sawing is EWP. We use the Resharp/replacement program.
I've had good luck with all the bands tried.Be aware if you use resharp they only do their own.I think Cooks will sharpen any bands and you'll get good service from their offerings.If I was cornered and plied with many cold beers I'd fess up to prefering Timberwolf bands. A serious bandmill operator should consider sharpening his own,its not for everyone,but cheaper in the long haul. Frank C.
drobertson
thanks brothers!, this is pretty much what I wanted to hear, I have been using the cook's super sharp, this blade is a face sharpen only.  the gullet is deep.  I do like the wmz blades but I know my sharpener wont work on the hardness of the blade.  I have heard about the timber wolf blades just have not tried them.  It is a tricky thing with blades, and everyone has their preference.  I just wanted to know what most folks ran, if for nothing else to know what works.  I hope yall have a great week end,  david,
paul case
I really like the simonds red streaks. The ones I use are 1¼x 7/8x 042. They are about $6 cheaper than the timberwolfs and they sharpen with the face grind very well. I cut almost all hardwoods mostly oak. I have tried cooks ss, timberwolf, and kasco but my fav by far is the simonds red streak. PC
pc
ladylake
Same as Paul, Simonds cut real good and take a lot of sharpenings.  Steve
MartyParsons
Hello,
I have been using the WM Silver Tip. .042 7 degree on the small mills. LT10,LT15 LT28 and LT35. The .045 7 degree Double Hard seems to use more HP and does not seem to work well until I get over 25 hp. I was using the .045 9 degree on these mills before I switched to the .042 7 degree.
They are working well.
The .042 7 degree is something new for the WM Silver Tip line.
M
fat olde elf
In the past ten years I have used Simonds,Timberwolf, Lennox and WM with similar results.  I sharpen my own bands and for others as well.  i usually run 10 degrees, 7/8 and .042. I have 12 Cooks supersharp in my shop waiting for Ross Keddle to buy 8 eight more and send me the cam for my Cats Claw sharpener. I have one sample supershop that I haven't used to date.  The best deal I have found on bands is to go to the Pig Roast and win 10 WM bands. I have done this for past 2 years and I am very grateful to the Forum and WM. Say your prayers......
Cook's MP-32 saw, MF-35, Several Husky Saws, Too Many Woodworking Tools, 4 PU's, Kind Wife.
Okrafarmer
I have had really good results in hard hardwoods, including pecan, with the Munkfors blades. They are expensive, but the results were incredible. I am about to try the Woodmizer Double hard, I hope I am as impressed with them. BTW, after switching sawmills, I still have some of the 11' Munkfors blades left, and they are for sale on the Fore Sale site. I just figured I'd try the WM blades since I never tried them before, and now have a WM mill.
8)
Now selling Logrite tools!
Truth be known if someone switched bands on my mill I wouldn't know as long as they were sharp and set well.Try them all but then settle in to your favorite and buy all the same,makes it alot easier when you set and sharpen. Frank C.
drobertson
yea frank you got this right. I have a baker sharpener and setter. I have found that I really don't need to set very often. These cook super sharps are getting 6 to seven sharpens. and that is not to shabby.  Have a good day.    david
