To treat or not to treat?
Started by eddiebo, August 31, 2012, 03:33:09 PM
eddiebo
I will be milling fresh cut standing dead pines soon, and was wondering if I need to treat between layers of lumber for termites as I stack to air dry? ???
If you are ashamed of HIM, then surely He will be ashamed of you in His Kingdom.
PC-Urban-Sawyer
I'd say build your foundation for the stacks of cinder blocks, 18 - 24" high off the ground. Put a sheetmetal cap on top of each cinderblock, angled down on each side. Make your foundation framework of treated lumber. Stack 4 - 8' tall.
Generallly termites require ground contact or a path from ground for their "mud tubes". The cinder blocks and tin serve to isolate the stack from ground contact.
Good Luck!
Herb
