Did something I haven't done in a long time
Started by Joanie, August 30, 2012, 05:13:18 PM
Joanie
Yes I had the mill a singing cutting pine 2x8x16s, droped down to 2", half way through that sound of blade in metal.
I sawed the adapter clamp, I felt so stupid. The blade was a brand new Timberwolf my couson gave us to try out, 4th log, had to change the blade. So yes after many hours and boardfoot sawed, whenyou get on a roll you can forget about that little clamp. >:(
Yes this gal loves Grease and saw dust. Oh and my cat and my honey.
Lt40hd 24hp Onan, Husky 359 that runs when it wants to, Polan Wood Shark at the mill,starts every time, 1994 Jeep YJ.
tyb525
4th lo, you might've been due for a fresh blade anyways. Depends on the size of the tree though.
customsawyer
Don't worry about the small stuff. Everything is small stuff. ;D
www.thecustomsawyer.com
Yup, your lax moment has visited us all and we do get humbled occasionally.  I guess that it just goes with the territory.   The sun will shine bright on a new day tomorrow, so let's all just enjoy it together.
Delawhere Jack
Guilty as charged. I hit the main clamp pad on my second day with the mill. I was amazed the blade actually cut through 1/4" of steel about 1 1/2" wide. :-[ I'm guessing resharp will tell me that band is toast.........
giant splinter
Joanie
You are in good company,I bet there are many of us that have done the same thing and though Im not sure I suspect no one has cut all the way through a clamp as yet.
If anyone has perhaps they should post the blade brand and specks.
I admit to doing this my self (once) and I have been extra careful to eyeball the hight position of the blade when I'm cutting close to the deck.
Hang in there ...... I suspect it is much worse the second time you do it.
roll with it
Okrafarmer
I hit one once. I'm a member of the club, too!
8) 8)
Now selling Logrite tools!
Chuck White
Yup, I'd pretty-much say we have all hit "mill" iron!  :o
woodmills1
It really isn't your sawmill till you cut into it
and roll a log off the left side due to no stops up ::) :D
tyb525
I have cut a stop once, and on a couple occasions I have been able to stop about 1/4" away from one (good thing about a push mill)
I sawed the corner of the clamp once.
Sixacresand
Yep, I cut into log stops and clamps.  Mostly when I get too hot and tired (hot Stupid).   :D
Brucer
Now if you were to upgrade to a newer mill with the 2-axis clamp, you wouldn't have to worry about leaving saw marks in the clamp for everyone to see. Trust me, you cannot leave sawmarks in that clamp.
Bruce    LT40HDG28 bandsaw
mometal77
Life happens it could have been worse right???
Too many Assholes... not enough bullets..."I might have become a millionaire, but I chose to become a tramp!
Nomad
     Sliding the blade across the top of the clamp is the fastest way I know to take the set out of the teeth. ::)
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Sixacresand
Well I know better than milling on Sunday.  First thing I hit a log stop.  Then I burned my hand on the muffler, which I ran cold water on it for 20 minutes to take the fire out of it.
Joanie
Okrafarmer
