sawmll shed begins!
Started by lyle niemi, August 17, 2012, 12:04:18 PM
lyle niemi
Me the backhoe and the ladder got alot done today.
 ;D  Every step is one step closer.   :)
lyle niemi
Quote from: Magicman on September 03, 2013, 10:59:17 PM
You bet! Im hopeing by the end of the week I will have to put lights in the mill shed......Winter is coming :snowball:
lyle niemi
Finally ready for tin 8)
Ain't no grass grows under your feet...  way to go, and looking good for winter snow a comin.
Maybe next month for you? Or maybe this month... geesh it is already into September.  ::)
Sam H
Just curious why your going with a 16' ceiling, that's very high. I've got a 12 foot ceiling in my 20x60 mill and its plenty high. What kind of mill do you have there?
In between mills. Cook edger and cat claw equipment
lyle niemi
Quote from: Sam H on September 04, 2013, 10:40:45 PM
A building can have many uses if it is built big enough
lyle niemi
OK, I promise this will be the last pic for a while, just had to show you that the tin is up and the millshed is almost ready for winter
Buddyw
That is truly a nice building lyle !
I need to get started on putting a shed , building , tarp , or even a teepee would be something over my mill.
I just can not make my mind up if I want to go through the scuffle trying to build a building myself with no help or just make a phone call and pay someone to build it.
I have even been looking into these carports, some of them don't look bad.
lyle niemi
Quote from: Buddyw on September 05, 2013, 08:14:25 PM
Building something like this is alot of work by yourself! If ya have the money and if there is a contractor that will do it for you it might be worth it. The reason I went so big and tall with my building is that if I ever go sell the place the building can be used for other applications other then a millshed
lyle niemi
Built and hung half the big door today, hope to get the other half done tommorrow
WoodenHead
Very nice building Lyle.  Job well done!
Putting up a building yourself is a lot of work (particularly one like Lyle's!).  But if you have the skill and if the opportunity cost works in your favour, go for it.
redbeard
Great job Lyle! Very impressive.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
slider
I totally agree with going tall.That way if you need to expand you are not limited to the gable ends.Good job lyle.
al glenn
lyle niemi
More progress made today! The building is dang near closed in. I couldnt figure out where to put my main entrance but I soon figured something out. As you can see I put it right in the big door, I cant see anything wrong with that :snowball:
lyle niemi
I couldnt combine yesterday cause of the rain so I built a little motor room for the mill, it should control the noise and the heat, I installed a slider window so I can have the motor in sight all the time while Im sawing. I think it will work good!
I also found this old 966 loader which I might purchase in a week or so, I gots to get permission from the real boss first!! a know who Im talkin about..lol
GAmillworker
Super nice building you have built.  I would need to do a lot for my boss for her let me buy a loader like that.
Thank the Lord for second chances
Lyle,even in the winter that engine enclosure will get toasty warm.Mayby you can duct some warm air to the sawyers box.If you weld up some diamond tread about an inch apart and run engine coolant through, your feet will be toasty warm.[with a shutoff valve for the summer] Frank C.
lyle niemi
Quote from: GAmillworker on September 18, 2013, 07:57:00 PM
Thanx, when I first dragged that old mill out of the bush, I would never of guessed I would go this far...lol
Lyle,tell mommy its for combining logs.You can't beat the "big guns" for handling logs farm loaders and bobcats work but a loader like that is a real spoiler.Does it need work.??  Frank C.
lyle,when will it stop?   :D  Good idea from bandmiller about keeping your feet warm.
dblair
if you put doors and heat on that loader you might get one of the children to load logs while you saw sometimes . your operation is really getting big . really nice building , as I have said before . I've got one of those doors in a door also . it appears your getting ready for the sawing season , next month , maybe ?
old Appomattox Iron Works circle mill.
lyle niemi
Quote from: bandmiller2 on September 19, 2013, 07:09:35 AM
The loader seems to be Ok, but Im sure if I lk I could find some thing to fix on it..lol
Your heating idea is a good one!
lyle niemi
I got rid of some more noise today, I insulated my little motor room with some 3 inch styrofoam, It made a big difference!
lyle niemi
I was just looking at this thread again, I think I had more energy at that time..lol
