Timberpro TF 830B information
Started by CTL logger, August 06, 2012, 06:00:04 PM
CTL logger
I am thinking of updating my forwarder, i need something with a little more capacity. When the processor is eight days ahead of you it's a little overwhelming trying to catch up. Just wondered if anybody owns or operates one and what you have to say about one. Good or bad
1270d
They re huge!  Ken crawford says they re very nimble though.  If the cab fits the bunk fits it is said.   What do you run now?
Bobus2003
Have had a little experience with a Timbco 820 Forwarder. Big machine, Easy to run, 20 ton Capacity.. Just a PITA to get moved job to job..
CTL logger
I am currently running a 574 Cat forwarder it's very under powered for any type of grade and the loader struggles to lift much
snowstorm
is your fowarder the cat eco log or the cat fab tech?
CTL logger
lumberjack48
Quote from: CTL logger on August 07, 2012, 04:57:12 AM
Have you opened the valve bank up, this is the first thing my father did when buying a new loader. He wanted all the lifting prudential it had.
CTL logger
Yes I have adjusted the valves for Max lift capacity I could live with the lack of HP if the loader had greater lift could put bigger main boom cylinder but don't want to put 2 grand into something I don't want to keep.
Jamie_C
I believe that Verboom Grinders has one, they were running their harvester 7 days a week and only needed to run the forwarder 5 days a week to keep up.
Cat forwarders never gained much of a following up here, there are a few around but John Deere has the lions share of the market. If you can't get the Timberpro i would be looking at a big John Deere, they will move wood in a hurry.
CTL logger
Thanks Jamie c I've looked at Deere they have attractive financing rates but have heard they had problems with the cab rotation but I do like the concept. Also like the Komatsu forwarders but wouldn't have much dealer support down here Anderson Equipment is a joke when it comes to forestry equipment.
Jamie_C
I haven't heard anything bad about the cabs up here yet but most guys are still running the old "conventional" cabs.
1270d
Only problems iv e heard of with the new jd cabs is the a/c hoses were rupturing from the twist.  I believe there was a factory update though.  You would also find the john deere to be much, much more manuverable than the tank like cat.  Course anything is more agile than a cat.  The 1910 jd is 20 ton capacity I think, also propably 400k plus
bushmechanic
Yep my money is on the John Deere also,pick up a 1710 and that will run circles around those Fabtek Cat's.We have a 1263 Deere harvester and a 1010D forwarder and the forwarder is parked a lot of the time waiting for wood to be cut.
barbender
Those Timberpros look like beasts, I don't know of anyone running them in the woods up here. They are widely used on the pipeline work for hauling and placing mats, they are slick because of the 360° rotation, they can drive out on the mat road with a load on, and place the mats at the end. I run an 02 Ponsse Buffalo, it's the only forwarder I've ever ran so I don't have anything to compare to, but it runs up hills with a full load no problem, the crane is strong as well. You can grab 2 20" 16' pine logs and lift those without it grunting. I think they are rated for 18 metric tonnes.
Jamie_C
I ran a Ponsse Buffalo King for a little while and found it's hill climbing ability almost pathetic when compared to Rottne or John Deere machines. We had the dealer out and set all the driveline pressures to maximum and it still wouldn't climb hills with a full load like other machines would. It would go over relief and just sit there, once you figured out how to work around this it was a good machine. The loader power and speed are fantastic and the comfort level is second to none.
barbender
That's odd, Jamie. These machines have a lot of power, sounds like something was definitely wrong with that machine. The dealer up in your area is a private company, not the Ponsse company itself? Just curious.
Jamie_C
It wasn't a lack of power, they have tremendous "power" ... it's the way the set the pressures for the hydrostatic drive. The hill climbing ability is hampered by relief settings that don't match the machine size in my opinion. In the maritimes the Ponsse forwarders have a bit if a reputation as poor hill climbers. I have run Rottne and John Deere forwarders on hills so steep that when you approach the bottom of the hill the nose digs in and when you are climbing the hill you have to stand up if you want to see the ground in front of the machine and they didn't struggle at all with full loads. Put a Ponsse in that position and you won't get 10' up the hill. Now on more "normal" hills they do okay and will hold there own. Even with a new drive pump and all settings set at factory maximum i used to watch the regular operator have to back down a hill with a full load on because it would go over relief and just sit there. It made for some interesting times and i was glad i was in the harvester seat most of the time.
CTL logger
I have only owned one forwarder probably got the worst one first don't want to make the same mistake twice I haven't really talked to my Deere dealer yet I think the Rottne is a good machine but know a guy who was broke down a month or better because the only mechanic in the country was in Sweden and not to keen on all the metric hydraulic fittings and bolts but they're solid machines. I know  komatsu or valmet puts sae fittings on their forwarders. I have had my cat stop on a hill before it won't spin the tires it just stops and won't go have to back down and find a better way up and it wasn't that steep
barbender
That sounds maddening Jamie. I'll have to find some bigger hills to try, I'm still pretty new to this forwarding gig. Not to mention,northern MN isn't known for real steep terrain ::)
1270d
Come to think of it, ponsse has some machines set up with a winch in the bunk frame to pull itself back up steep trails.   Saw it on youtube somewhere.
Has anyone ever heard of a 6 or 8 wheel forwarder tipping over forward?  The guy that skids behind me worries about it alot.  Im pretty confident that if my 1270 will go down with the crane and head hanging off the front, he s safe.
newstick
I have rin the tp on thw pipeline and they work great. I don't know how they would be in hills though. A little hard on fuel but realy lift and operator friendly .
Im am owner operator of Newberg Forest Products.We are a convental logging company with a Timbco feller buncher, two John Deere skidders , a strokeboom delimber, and a Serco log loader with circle slasher saw.
In the summer time my other company builds Handcrafted Log Homes. I love the woods!
Jamie_C
1270d ... if you can get the harvester down the hill safely then the forwarder should safely follow. Keep your stumps as low as possible on the really steep hills and keep your trails as straight as possible. If there are any sudden hummocks on the hill then fill in around them to smooth it out. Tell him to put on the seat belt, it will help him feel a bit more secure when your not bracing yourself to stay in the seat. The machines get easier to roll over on their side on the really steep hills so be a little more careful.
barbender ... when your running a tracked harvester and have to have your seat belt on all the time to stay in the seat and the machine is "on it's toes" as we call it when working down the hill then you know you are in steep country. I have cut a lot of hills that you have to keep building "level" spots for the harvester to sit so you can safely cut the trees around you and then put the head on the ground to ease yourself down the hill similar to what an excavator oparator does. Makes for a fun day :)
1270d
The hills we re operating in now are steep enough to make the rear of the harvester lift at times.  Ground is sandy and fairly smooth.  I've worked in hilly ground quite a bit, but these are the steepest I've been in.   We always run straight down on the steep ones
barbender
Yes that sounds a bit steeper than what I am used to :o There are pockets of steep country around this area, but I haven't ran in them. I know the Ponsse machines that are working in the western US drive up the mountain empty and load and haul down hill. Doesn't work if you have up and down hill terrain between you and the landing though. How did the transmissions etc. hold up on the Deere and Rottne forwarders? If you are running straight up hills that steep with a full load on, it maybe wisdom to have the relief say enough ;D. Your conditions sound like they are on the far fringes of extreme :o
Ken
Quote from: Jamie_C on August 10, 2012, 07:39:06 AM
Jamie C
You and I have different ideas on what constitutes a "fun day".  Rubber tired or leveling cab machines would sure be nice on days that you are working on a steep hill with a tracked machine.
