450b timberjack planetary
Started by timburjack, July 14, 2012, 03:20:50 PM
timburjack
does anyone know the capacity of the planetary on a 92 450b? also what position do you check it halfway or one third? btw newbie here
Just want to welcome you to the forum. Use your Timberjack full time in the woods?
Woodchuck53
Dosen't it run out of the plug when it's full? Most everything I own does. That's how I know some of this old equipment is full.
Case 1030 w/ Ford FEL, NH 3930 w/Ford FEL, Ford 801 backhoe/loader, TMC 4000# forklift, Stihl 090G-60" bar, 039AV, and 038, Corley 52" circle saw, 15" AMT planer Corley edger, F-350 1 ton, Ford 8000, 20' deck for loader and hauling, F-800 40' bucket truck, C60 Chevy 6 yd. dump truck.
bushmechanic
If that machine has the Eaton diff's then you check it with the plug halfway.The capacity of the planetary end will be detirmined by the model because there are a few different planetary wheel ends,and each one as they get bigger holds a little more oil.
timburjack
thanks guys its not my machine, my boss just bought it. i didnt need to know the capacity as much as what angle to check it. he wants us to use it so we wont wear out his 548g.
